Question about Hitachi 43UWX10B 43" Rear Projection Television
Convergence problem My Hitachi has a convergence problem AGAIN. It had the same problem about 3 years ago and the convergence board was replaced under the extended warranty. Luckily I watched the technician so I knew where the board was. I removed the board and RK42 is obviously burnt. My question is, everything I have read here says replace the two IC's and the resistors, but since RK42 is obviously burnt, can I just replace that and not the IC's, or do you think a faulty IC fried the resistor? I'd rather not replace the IC's if I don't have to.
  • 113 Answers
YOU HAVE TO REPLACE IC BECAUSE IT IS BAD THE ICS NUMBER HAS CHANGE FOR STK392-110 TO STK392-150 THEY WILL SYAN MORE HEAT
Posted on Oct 13, 2008
Blurry
Ur tv have a problems call convergence,it dead.The convergence board the 2 STK convergence ICS,and some or all it resistors are dead.All these parts are dead,must be change to solved the convergence problems.The shop will cost u $300-350 for the parts and labors.
May 21, 2010 | Hitachi 43UWX10B 43" Rear Projection...
The left side of the picture has red and green stripes and ghost images. The right side does not have this problem, but the picture is not quite right. The convergence chips were replaced two years ago and...
That sounds like the convergence problem I had about a year ago, and like you, I replaced the convergence chips and that fixed the problem. It's cheaper to replace the chips if you do it yourself, but maybe not if you send it out for repair. If you can find an exact replacement board, that would fix it too, but I wouldn't necessarily expect it to last longer. The advice I read on replacing the convergence chips in my rear projection TV was that they would last 2 or 3 years and then need replacing again. So you're within that range.
Feb 27, 2010 | Sony KP-51WS500 51" Rear Projection...
Convergence on Hitachi 43fdx01B not working
ik04,ik05:stk392-110(replaced with:stk392-150)resistors:rk46,54:1,5ohm.,rk42,50:2,2ohm.,rk58:3,3ohm.,rk62:1,8ohm..try make order in "MCMelectronics".,partstore.,bdent.
Jul 09, 2009 | Hitachi 43FDX01B TV
Hitachi 43FDX Rear Projection TV
If the picture was good prior to the 3D images, I would fix it. The convergence ICs either have poor connections or are defective. The IC is an STK392-110. There may be 2 inside the set. If you have this repaired, expect a labor cost in the $200 range. Request that the ICs be replaced rather than the board changed. This will maintain all of the internal settings and require only part replacement not a complete re-convergence adjustment.
Keep us posted.
Dan
May 01, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 53SWX12B Convergence Problem and blinking light
Im thinking your convergence chips is causing all of your problems
but here's the fix to the convergence:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 04, 2007 | Hitachi 53UDX10B 53" Rear Projection...
50UX26B Convergence or Ghosting problem
new convergence pc board is worth $400-600 /repair the old because you probably won't find one and if you do the same thing will happen in time anyway,you know what you got and must ask your self .what will it cost to replace it at this time /shop around /compare prices and extended warranties////////////
Sep 08, 2007 | Hitachi 50UX57B 50" Rear Projection...
HITACHI 53UWX10BA
Hi there, Check IC601, C603 for leakage, I601 and vertical pulse detector QN05 for poor convergence check RK42 for open circuit. Best regards, Arpi
Jun 16, 2007 | Hitachi 53UDX10B 53" Rear Projection...
43fdx01 hitachi
possible convergence overdrive from the IC's. This will cause the symptom you describe. ....accordianman
Jul 17, 2006 | Hitachi 43FDX01B TV
Hitachi 43UWX10B 43" Rear Projection Television Logo
75 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
