Question about Intel Motherboard
Faint noise on booting.
a faint metalish sound is heard on starting my pc. i thought it to be some some loose metal piece (case cover , ...) this is accompanied by a whirring(fan) -like sound. this whirring like sound is heard sometimes long after booting up . tried to locate the source of the metalish sound. removed the case cover,tightened the screws,... .no avail the noise still persists.as for the whirring sound, tried stopping the case-fan,cpu fan to pinpoint the source . again no luck. read it some where here about the possibility of it being the psu fan. could u help ? the system runs fine. heating is not an issue. the new mobo is gigabyte.new processor athlon 4600+ sysytem very silent after a couple of minutes of booting up. power supply 400 watts
  • pils Oct 15, 2008
    hello,
    no noise from cpu fan, case fan for sure. as for the power supply do you think the above mentioned noise could be caused by the fan or could it be something else in the psu.should i change the psu in case the noise doesn't stop or except the "noise" the problem hardly matters. as i mentioned earlier the noise goes away after some time. ty
    Novelist:
    Scholar:
  • 158 Answers
The best thing i can sugest is to check all screws are tight and not just the ons on the motherboard as these have a tendancy to come undone slightly due to the cpu fan and I would also upgrade the powwer suply to a 500 wat or above as the mother board is drawing more powaer during boot up and if noise is still heard then get the case sound proofed and chack for vibration of pc also make sure it's on a level surface as this will thow the fans out during boot and check all cables are fully pluged in if you find any that are slightly loose for example the data cable to the hard drive and cd/dvd burner get this replaced as this will help with your boot up speed as the pc checks for devices connected during boot up.
hope this will help you
Posted on Nov 23, 2008
  • 781 Answers
Try this remove side cover and boot computer listen for any extra noise fan etc. also by power supply
As I think you have a bad bearing in a fan
To temp fix it
remove paper cover over center of fan and put a small and I mean small drop of light machine oil on bearing then replace paper cover.
check if this stops the noise if it does you know which fan to replace.
If it is power supply fan and if you think yourself capable remove fan and do the same to it
Posted on Oct 14, 2008
The first time i heard the noise i was cought in traffic the bike got alittle hoy it sounded like a ball bearing bouncing around when i got back on the road it stoped the bike run fine
Hi Kmercer, could be primary noise. Remove the square inspection cover and check to see if your primary chain adjuster slipped or came loose giving lots of chain slop. Chain should have no more than 1" total up and down play. Next drain the primary oil and check the magnet on the drain plug. Fiber or powder like accumulation is normal but if you find solid metal pieces remove the primary cover and do a through inspection of the chain, sprokets, and adjuster. If everything checks out ok you might want to take it to your local dealer or shop and let them listen to the noise. Good luck
Apr 06, 2015 | 2009 Harley Davidson FLHTC Electra Glide...
My differential cover gasket is leaking
Sounds like your differential maybe destroyed.Take the cover off and look for metal pieces in the bottom of housing or looseness in the gears.
Oct 24, 2012 | Cars & Trucks
Rubbing noise heard when fan is on sounds like metal against metal
hi there, you need to replaced bushing, due to loose of shaft to the bushing the stator is mis align. thats why you heard a cracking sounds. thanks
Apr 30, 2011 | Hunter Fan Low Profile III Plus 20801...
Loose Object in Vitamix Turbo Blend 4500
Vitamix has a 5-year warranty. Go to their website and they will send you an empty box with a UPS pick up tag and fix it.
Apr 16, 2017 | Vitamix TurboBlend 4500 Work Top Blender
Front tire clicking noise?
Take the car to a trusted tire store and have them dismount the tire on that wheel to look for an embedded rock or metal piece in the tread area. It may not show itself from the outside due to lack of weight on the area of interest, but an internal inspection may show it up. Try putting the spare wheel on to see if the sound goes away. Hope this helps!
Jul 01, 2010 | 2005 Scion tC
When you turn the wheel there is faint squeaking ( soft high pitch)sound. Not a grinding sound. More of a rubbing sound, faint though.
if the noise is heard when you turn and not moving, then you may have some problem with ball joints or tire rod ends.
if the noise is heard when you are moving only then it could be the brake wear indicator start to touch the brake rotor
Feb 28, 2010 | 2004 Chevrolet TrailBlazer
HL-R4266W shuts down and a faint clicking sound can be heard
I believe I read somewhere that when you open the back cover over the lamp, there is a special little black switch that needs to be in the up position when you put the cover back on, or the TV can shut itself off randomly.
Aug 16, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Metal creeking noise coming from above windshield
hree trips to two different dealers finally fixed it. Above the windshield there is a piece of molding that covers the top of the windshield. The clips holding that on were not clipped on properly and the piece was separating from the windshield at high speeds causing a medal creaking. Most likely happened when I had the windshield replaced.
May 14, 2008 | 2007 Mercedes-Benz CLK63 Convertible
Intel Motherboard Logo
95 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
