Question about Gateway Computers & Internet
I keep losing time. everyday i have to reset the hour. ????
    Problem Solver:
  • 3 Answers
It shoulds like the timer in your PC has gone bad, that happens sometimes and you have to get it replaced.
Posted on Oct 13, 2008
Lately my I have to charge my trac phone every day even though I have not made any call.
This has to do with battery decay. Batteries lose capacity over time.
Jun 29, 2017 | Tablets & eReaders
Tip
My computer won't keep time!
If your computer continues to lose time or doesn't keep the correct time, your CMOS battery might be bad. Try this, reset the time on your computer and check it 24 hrs later if it is off by more than a few minutes or hours then the CMOS battery is probably bad and needs replacing.The CMOS battery is just about the same as your watch battery and doesn't cost much but is tricky to replace if your not careful.
on Jan 30, 2014 | Battery Biz Computers & Internet
My LG Plasma TV 42LH50YD turn off by itself after about an hour it turn on by the schedule time on. it happens once everyday around the same time. My TV is connected to a PC which schedule to restart...
Ty a factory reset to this TV; and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Apr 25, 2017 | LG 42LH50 42 in. HDTV LCD
Need to reset Netgear DGND3300 router everyday
You could try a factory reset on the router, hold the reset button on the back for 15 seconds. Reconfigure and test. If that doesn't work, go to the manufacturers site and download and install any newer fireware available. If that still doesn't work or none are available you would be best off simply replacing it. You can get some decent w-routers for $40.
Jan 26, 2013 | NetGear DGND3300 RANGEMAX DUAL BAND...
The auto mode isn't working on my zilla digital 24-7 power center, when on auto mode no lights come on?
Copy following link to identify timer:
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Is this a new timer??? Or old timer that stopped working?
Replace battery.
Press reset button to clear all memory traces before programming.
Check programming for overlaps and mismatched day(s) of operation.
Test outlet for correct polarity and grounding using circuit analyzer.
Make sure light bulb is turned ON. Timers do not reach out and rotate on-off switch.
Make sure outlet has at least 80% rated voltage shown on load label. For example 115 volts x 80% = 92 volts
About your specific programming needs:
Zilla selects 12 o'clock as changeover time between am-pm.
So if you want 8:02 to 7:59 operation, then that is under the 12 hours, but it crosses the 12 o'clock am-pm changeover.
Workaround: Shorten your times to less than 12 hours just like you have done.
But set current time differently so 8-8 falls under either am or pm, but does not cross am-pm. The timer does not actually know what the current time is, so simply fudge by amount needed.
Nov 18, 2012 | RTO Zilla 24/7 Digital Timer Power Center
When i turn on my tv., the indicator light will come on and off again three times before going off. No picture showing.
I have this same problem you can unplug it from the wall for an hour and it comes back on for several hours. However if you don't keep it unplugged for most of the day then you will have this problem everyday until you buy replacement parts.
Jan 12, 2011 | RCA D52W19 52" Rear Projection Television
IT IS AN ORVIS AUTOMATIC AND IT STARTS AND STOPS AND DOESN'T KEEP CORRECT TIME.
Thank you for contacting FixYa.
When you first receive your automatic watch, you must give the watch an initial pre-wind. If you wear it everyday, it will continue to wind itself on your wrist when you move around and walk. If you stop wearing it for more than approximately 2 days, the watch will need to be reset, but will then automatically wind itself once you start wearing it again. The disadvantage to this is pretty clear. Your watch does not t keep time if you do not wear it constantly. The advantages are that you will never have to replace a battery, the watch keeps great time when it is running, and most of all, this type of movement is exactly what the originals use! If your Automatic is losing or gaining time in a 24-hour period the watch needs to be adjusted. All of our automatics have an adjustment screw on the movement just like the originals. Any local jeweler can service these watches.
Best regards! Jewel
Aug 25, 2010 | Orvis Watches
My speedo has not been working today all the other gages went out and after about 4 hours started working again
It sounds like the connection to your dash gage may have gone lose do to everyday vibration. If everything was running fine without any check engine or service engine soon, then it's your dash gage. Before your start your truck and the key'sare in the run possition, your gages should move up then down checking it's self. Keep a eye on that. Good luck. easy fix dubble check connection.
Apr 06, 2009 | 2003 Chevrolet Suburban 1500
Changing displayed time
Go to Preferences, select Restart GPS. Then Enter Coordinates. Keep hitting the enter key until you get to the time field, now set your local time. And no, you will not lose your POI.
Mar 18, 2008 | Magellan eXplorist 100 GPS Receiver
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
