Question about Acer Extensa 4620 Notebook
No Microphone and Line in Output
In my master volume panel, i cant see the slider for microphone and line in output...how do i get it there? I cant play guitar in my laptop. Can someone please suggest me on this...
  • Acer Master
  • 5,568 Answers
Try this;
- Open the Control Panel - Open the Sound and Audio Devices folder - Click on the Audio tab to find the name of the sound system manufacturer.
Go to their website and download the latest driver software, reinstall it and then look to see if you now have access to those inputs.
Posted on Oct 13, 2008
Low sound but my speaker is 100
Check the sound mixer for a low volume slider. The output may be high but if the microphone/mixer volume is low, the output will be low.
Nov 25, 2013 | ASUS Computers & Internet
Is a microphone an output device?
no, output devices are things like speakers or a monitor. They output sound or images, microphones are input devices because they put sound into the system not out of it.
Oct 01, 2013 | Computers & Internet
When i install application or games on my sony ericsson aino it display operation failed, how can i fix this?
Sony IC RECORDER ICD BX-800 (!without USB connection!)
What you need:
- newests audio drivers in Windows 7 (updated audio-drivers)
- audio cable 3,5 M (male) both ends M-M (male-male)
- freeware application Audacity for Windows (with LAME)
Howto step by step:
- one end of audio cable connect to dictaphon's headset (earphones) jack in recorder Sony IC RECORDER ICD BX-800
- other end of audio cable connect to PC/notebook microphone (or LINE IN)
- nothing special setup (adjust) regarding Audio in Windows 7, the device for record Audio keep Microphone (default)
- in Audacity set very little volume "Input Volume Slider" and "Output Volume Slider" (for example both 0,1)
- in Audacity like Input Device set "Input (Audio device High Definition Audio)": !Don't set in Audacity like Input Device "Microphone"!
- Audio Host: MME
- Output Device set "Speakers (Audio device)"
- Input Channels set "2 (Stereo) Input"
- Sampling (Hz) set 4410
Jul 10, 2013 | Audio Players & Recorders
Where is the line in jack for my Gateway MC7321u Notebook? Is it one of the headphone jacks?
Some computers have a special jack labeled line in. If your computer does not have a line in jack, you can use the microphone jack. You can then adjust the volume of the device in control panel under sound options. The headphone jack is only for output. I have seen some computers where you plug in a cable to the microphone jack and you will be asked what kind of device it is.
Jan 17, 2011 | Gateway MC7321u Notebook
How to unmute microphone (microsoft Vista)
::Look EASIEST WAY OF THEM ALL RIGHT HERE::
[1] --> Right Click the Volume Icon at the bottom right corner of your screen [The Task bar].
[2] --> Click [Playback Devices]
[3] --> Right Click the [Speakers] Icon and click Properties
[4] --> Click the [Levels] Tab; and there you will see the Microphone Volume slider (The one at the very bottom of the "HD Audio output" and "PC Beep" sliders where you can un-mute the mic playback (By clicking the unmute icon, than slide the volume up to where you prefer it... Simple smile.gif I hope I was able to help someone with this... wink.gif
Dec 26, 2010 | Computers & Internet
My microphone only records on one side. how to i do fi it so both lines records instead of just rhe top one?
Your microphone could be a mono or single channel pickup. Look at the microphone plug and count the isolators between the metal contacts, if you count one isolator and two contacts you have a mono microphone, or if you have two insulators and three contacts you have a stereo microphone. If your computer only has a mono microphone input you may have to use your line in on your computer. If your volume is weak and you get noise on your channel you may be required to use a microphone pre amp and plug the output into the line in jack. Last make sure your computer speaker mixer is set correctly for stereo.
Sep 07, 2010 | Cakewalk Music Creator 4 for PC...
Downloaded skype. I can receive and hear the calling party, but they are unable to hear me.
This is the issue regarding the Internal Microphone in the Computer.
Your contacts cannot hear you, until you have enabled the Microphone in the Computer.
You will find the information to enable the Microphone below:
Windows XP:
1) Double-click on the Volume Control. 2) Select the "Properties" option from the "Options" menu. 3) Select the "Recording" option in the "Adjust volume for" section. Click the OK button. Check the box labeled "Select" under the microphone volume and you should now be able to adjust the volume for the microphone.
Windows Vista:
1) Right Click the Volume Icon at the bottom right corner of your screen [The Task bar]. 2) Click [Playback Devices]. 3) Right Click the [Speakers] Icon and click Properties. 4) Click the [Levels] Tab; and there you will see the Microphone Volume slider (The one at the very bottom of the "HD Audio output" and "PC Beep" sliders where you can un-mute the mic playback.
Windows 7:
1) Click on Start (the Windows icon) and type sound. 2) Click on Sound under Control Panel. 3) Click on Recording tab. Select Microphone and click on Properties. 4) Click on Levels tab. The default Microphone Boost is set to 0. Increase it. 5) Close all the dialog boxes, and the microphone will be ready for use.
Hope this helps.
Jul 07, 2010 | Toshiba Satellite P105-S9337 Notebook
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
Samson G-Track recording volume issue
Try using a computer with a dedicated sound card, not an onboard sound chip. A condenser mike can't provide very much power on its own, and requires power from the attached receiver/amplifier.
Jun 04, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Acer Extensa 4620 Notebook Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
