Question about Casio Exilim EX-Z120 Digital Camera
Please help My camera will turn on, shows full charged battery, when I press down on the button to take a picture, the camera will not flash nor will it snap for the picture to be taken. When I press down on the following message displays on my camera screen: ISO 100 F2.7 1/80, Can someone help me with this? Thank you Cyn
  • e_zvanut Oct 23, 2008
    I have exactly the same problem. The camera seems to work fine other than that, but when I try to take a picture, it just beeps and either says ISO 50, ISO 100, or ISO 200.
Nikon d80 dslr camera working fine and then one day turned it on to take pictures only to find an err message flashing and when the shutter button depressed it says r04. The shutter sounds but no pictures...
HiI am sorry to hear, but you will have to some professional. Regarding your d80 has common problem of sequence unit defective. I believe that is the problem and your local repair shop would charge around $75 to 235 depend on what they really want to charge. Thanks and best regard!
May 27, 2011 | Nikon D80 Digital Camera
Canon A720 IS camera will not take a picture when flash is turned on but will if flash is turned off. I see a flashing flash symbol in the LCD panel (as if it is waiting for the flash to charge) when...
Dear sir,
It seems  ur battery is weak , since it  use  AA battery put new alkaline batteries  & then try .. I beleive it will take pictures  with snap .
Regards
Raj@npconline.in
Feb 12, 2011 | Canon PowerShot A720 IS Digital Camera
Hi there, im having a problem turning on my camera. I press th on/off button and the len comes out but suddenly the led below the "M" button flashes red and gets turn off, but if I press "viewing pictures"...
when u prefer normal camera function,camera will shut off,becaz in camera mode, the flash unit gets charged,since the flashunit is defective,the camera gets off.So, change the flash unit .
Mar 07, 2010 | Polaroid i531 Digital Camera
My casio ex s880 won't turn on. when i put it on the charger cradle the red light flashes (it normally doesn't flash). Also when its on the charger it'll let me view my pictures on my memory card it just...
It happened to me. I fixed it by luck . Here is my way . fully charge the camera till the led turns green. "IMPORTANT" unplug the power of the charger first, then remove the camera from the cradle . Then I pressed power button, it worked.
Wish good luck to you too
cz
Jul 18, 2009 | Casio Exilim EX-S880 Digital Camera
Continuous flash charge
Try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 23, 2008 | HP Photosmart 735 Digital Camera
The Flash on my camera won't work
When taking pictures, you must really be allowing time for the camera's flash to be charged
before you could take another picture so that camera will have enough time to rest and it
could function normally.
But if the camera was dropped, then it's really causing those kinds of issues like flash will not work properly.
You could still try these steps below:
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Be in AUTO mode
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds so that settings will be refreshed
Turn it on and take a picture.
When you want to have just the AUTO FLASH.
- Rotate the mode dial to PROGRAM
- Press the LEFT/FLASH button until you've seen the
LIGHTNING icon with the Letter A on the leftmost part of the screen
- Try to take a picture by pressing and holding the shutter button
halfway first for 3-5 seconds and then press it all the way down
Dec 13, 2007 | Samsung Digimax S630 Digital Camera
Using flash freezes up camera
- Turn off camera
- Reload batteries
- Turn on camera
- Be in AUTO mode
If it still does not work, you need to contact the Manufacturer.
Dec 12, 2007 | Samsung Digimax S630 Digital Camera
Samsung s630 camera
Remove battery for a minute and insert it again.
There is a Battery Type setting in the Menu of your camera.
Do the following:
- Press Menu/ Ok button
- Go to Set Up 2
- Scroll down to Battery Type
Two options under Battery Type:
- Alkaline- if you are using non- rechargeable battery
- NiMH- if you are using rechargeable battery
Oct 12, 2007 | Samsung Digimax S630 Digital Camera
Casio Exilim EX-Z120 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
