Question about Refrigerators
Whirlpool refrigerator ice shoot door will not fully close
Ice shoot door did not close completely. Tried to lubricate, now stuck wide open
  • Anonymous Mar 17, 2014
    The filter seems stuck. The door wont close on the filter and the filter wont come back out.
Replace the whole door chute assembly.
Posted on Feb 11, 2009
Tip
Hot point side by side with ice maker
My Hot point side by side has water and ice dispencer, when we use the ice maker the trap door stays open we have to close it by pushing it with our finger. We tried some lubricant on the hinges still stays open. We were wondering if there is a solinoid that acuates the door closed.
on Apr 30, 2008 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water and ice maker not working line frozen everything frozen even when you turn it down is it the termostat or what
It sounds like your ICE Dispenser door is stuck partway open. Defrost the access door, ice bucket and crusher then check the Ice Dispenser door to be sure it fully closes, otherwise cold air will constantly drift out and freeze the whole mechanism.
Mar 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice is forming around the auger under the ice bin. constantly have water dripping from ice cube shoot
the door that the ice comes down to fill glass is not closing; the ice chute door just above the lever to fiil glass with ice it is either jamed with ice or is broken and needs a new repair kit.you can inspect by opening door and look at approx. 3 inch door that ice falls threw to see if closed.warm air causes ice to form.
Sep 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker door does not close all the way and the ice maker switch that releases the ice when press does not work all the time
Sounds like your saying that the ice dispensor flap is not closing completely which will cause frost on the inside shoot and on the ice bucket . Could be because of a broken guide ( clear plastic piece attached to the ice dispensor arm ) . Need brand and model number to help .
Aug 20, 2009 | Whirlpool Refrigerators
Ice maker works, fills door but doesn't come out
You have a bad dispensor flap solenoid . Frost due to flap not closing completely and ice will catch in the shoot .
Jul 25, 2009 | Whirlpool GS6SHAXLS Side by Side...
Ice machine makes ice but doesn't dispense when the lever is pres
I would check for an electric "flap" that opens & closes when ice lever is depressed. My GE has one and it has been fouled before causing the ice to be stuck inside the door. Hope this helps!
Mar 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Side by side refrigerator
The ice maker is not producing ice or not enough ice
production.
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
262 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
