Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
I am not find think vantage
Please help me i am not find think vantage how to create disks and how to delete EISA partion in my pc
  • 808 Answers
Use partition manager it is easy
Posted on Jul 28, 2010
Purchased new laptop Sony Viao Model No -VGN-C2 .I have 80 GB HDD.In that i got 8GB EISA Partition .And rest of the Other Partition is only C: Drive.So when i asked my dealer so he replied me that it is a...
Well there is an array of programs out there that can do this for you. I suggest gparted. If you download the gparted iso and burn it to a disk. You can boot from the disk and then you follow the onscreen instructions. You can divide the partitions in any way you see fit. If you have any questions on using the program you can always contact me and I'd be happy to answer
Nov 27, 2009 | Microsoft Windows Vista Ultimate Edition
Say's it needs to initialize and comes up with eisa.
The EISA partition is a partition that a computer manufacturer places on the disc to assist in recovery of that maker's files. It is not necessary to have this partition if you do not intend to perfrom a factory recovery. I will include a guide below to assist you in a deletion of that partition. To initialize a disc, it can be done ways, boot the computer and it will advise you the disc has not been initialized and will initiate a wizard to assist. I attach the hard drive to another computer using an EIDE/SATA to USB adapter, it will be recognized as an external drive but will not give it a drive letter because it is not initialized. You have to go to the control panel > administrator tools > computer management > disc management. Look in the right lower pane and it will show the drive with a grayed out box to the left, it may label the drive as drive 03 or 04 etc. Right click on the drive number and choose initiate. The computer will initiate the drive and give it a letter. It will also ask you if you want to initiate the drive as a bootable drive, choose yes. Below is the guide to delete that EISA partition so you can use the drive in any laptop you see fit.
EISA Partition Delete
1. Open a command prompt as administrator.
2. Run Diskpart application by typing Diskpart in the command prompt.
3. In the “Diskpart” prompt, enter rescan command and press Enter key to re-scan all partitions, volumes and drives available.
4. Then type in list disk and press Enter key to show all hard disk drive available.
5. Select the disk that contains the partition you want to remove. Normally, with just 1 hard disk, it will be disk 0. So the command will be:
select disk 0
Finish by Enter key.
6. Type list partition and press Enter key to show all available and created partition in the disk selected.
7. Select the partition that wanted to be deleted by using the following command, followed by Enter key:
select partition x
where x is the number of the EISA based recovery partition to be removed and unlocked its space. Be careful with the number of this partition, as wrong number may get data wipes off.
8. Finally, type in delete partition override and press Enter key.
Once the partition has been deleted, exit from Diskpart, and now users can use the much familiar and much easier Disk Management tool in Windows (diskmgmt.msc) to manipulate the freed unallocated partition. Users can create a new volume (partition) with this space, or simply merge it to existing partition by extending the size of the existing partition.
Nov 19, 2009 | Toshiba MK8025GAS 80 GB ATA-100 Hard Drive
I want to downgrade my desktop acer aspire x1800 vista to xp pro everytime i run set-up it always showing me an error could not proceed,.
Most like ly the hard drive has a Vista recovery partition. That partition has got to be deleted. You'll need to open a command prompt and follow the guide very carefully or irreperable damage could occur.
Here’s the trick to delete and remove the EISA recovery or diagnostic partition in Vista. Before proceeding with the deletion action, make sure that at least a set of Recovery Disc Media has been created. Else, you won’t be able to restore your computer to working and factory default condition when any problem on PC requires reinstallation.
select disk 0
  1. Type list partition and press Enter key to show all available and created partition in the disk selected.
  2. Select the partition that wanted to be deleted by using the following command, followed by Enter key:
select partition x
  1. Finally, type in delete partition override and press Enter key.
Oct 08, 2009 | Computers & Internet
How do i get rid of the eisa partion on my hard drive, i have an acer T180 with a 160GB HD
Not quite sure if the partion is the primary or secondary. If it is secondary and you are running Vista, go into the Admin Tool in the Control Panel, select Computer Management, select Disk Management under the Storage tab. Select the partion you want to erase from the bottem partion of the screen, right click on the partion, and choose Delete Volume.
If you are deleting the primary, you will need to use the upgrade function to get a clean deletion of the old info.
Good Luck
C2Solutions
Jul 29, 2009 | Acer Aspire™ T180 PC Desktop
No internal hard disk found
Hi there.
Use the Vista CD to create the new partition, but first you have to delete the old partition first, (the 220GB partition not the 10GB one because that will be the recovery partition).
Get a calculator and work out your new partition, for example 50GB is 50x1024MB so that will be 51200MB.
When you have deleted the 220GB partition select NEW and input your newly worked out partition and carry on from there, to activate the other partition just format it.
Please post back with the results and for anymore help if needed.
Good luck and thanks for using FixYa!!
May 24, 2009 | Dell Inspiron 1525 Notebook
Unable to make partion
Domez,
Try Testdisk to see if it can restore the boot sector.
Chappo07
Sep 02, 2017 | Seagate (ST3160827AS) 160 GB Hard Drive
Acer boots from xp
take it back to store. basically a hidden, but unremovable partition is causing the xp bootup. It happened to me aswell. They will probably give you a replacement as it is an unfixable problem. Even with new hard drive didnt fix it. Sorry about that.
Mar 05, 2009 | Acer Aspire 6920 Notebook PC
How to Create EISA Partition...in Vista Or XP......
You can't. The partition was created by SONY to hold recovery files because so many people lose their installation disks. So SONY created the partition, loaded the special software on it and put options in the menu to use it.
Jan 23, 2009 | Microsoft Windows Vista Ultimate Edition
I can't make format, partions or install windows.
Hi shlmughni,
If you're trying to format this drive, and you have nothing on it you want, then I would suggest that you use a windows 98 boot disk HERE. And first thing you need to do is load dos by putting the floppy disk in your drive A: after you create it from that site of course. Then allow dos to boot up. I'd opt for the allow cd rom option when it asks. After you get a dos prompt A: type in fdisk. Go to the display partions section and see what your drive is partioned as? Once you find that out, I'd delete the partion from the main menu choice delete partion. After that create a new partion from the main menu. Creating a new Dos partion will allow you to choose the size of the partion you want, then after that it will create your new Dos partion. When that's done, exit fdisk, and go to the A: prompt and type in format c: This will format the drive all over again, and give you a clean fresh starting point in which you install your OS.
Good Luck
Mark
Jan 03, 2009 | Maxtor Hard Drive
Problem
Insert the recovery disk and re install windows.
Dec 14, 2008 | Toshiba Satellite A205-S4617 Notebook
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
62 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
