Question about Technics SL-1200MK2 Turntable
Technics SL-1600MK2 The unit powers on - all lights come on - platter does not spin - tonearm does not lift.
Tonearm lift is probably a deteriorated belt. Google it, it's pretty common. The platter spinning might be due to a bad control board. You'll probably have to go to a repair shop to diagnose it.
Posted on Oct 27, 2008
How do I fix the tonearm of my Technics SL-1950 so it doesn't keep pulling to the right when in neutral balance?
The anti-skating control adds an outward pull to the arm to compensate for the inward pull exerted on the arm when a record is being played.
Setting the anti-skating control to "0" should virtually eliminate the drift you mention when the arm is in neutral balance. Also make sure that the whole unit is level as this may also affect the arm's tendency to drift.
Dec 11, 2014 | Technics Audio Players & Recorders
Arm not working. Stop/start light flashes red instead of staying solid
Don't try and force anything that won't move. Try this. With the power unplugged, place the tonearm over the record, if it will move freely, while rotating the platter by hand. Move the tonearm slowly over the surface of the platter until the end. Continue turning the platter by hand and see if the tonearm picks up and returns to the rest. See if that fixes your issue. For more information or further questions, please visit my website at audioserviceclinic.com. Thank you.
Dec 09, 2013 | Technics Audio Players & Recorders
Tonearm doesn't automatically return technics sl-d 202
Hi, at the base of the tonearm (left side) you will will find a rubber grommet or hole. Insert flat blade screw driver. Adjust until tonearm is lifting at end of record. Cheers john.
Apr 09, 2013 | Audio Players & Recorders
There is power going through my technics 1210,but the platter & strobe light still will not work
how do you know theres power to the unit if theirs no strobe light pitch adjuster light & the platter doesn't spin?
the power comes in & to the transformer first,then through the strobe switch, the transformer is what blows when you short the target light out.....i've seen this many a time when people try & change the target lights to blue neon.
Mar 04, 2013 | Technics SL-1210 Turntable
The platter on my Technics SL 1200MK2 stopped spinning. The power works fine... the platter doesn't want to turn. It feels like it just wants to be stuck?! Never had this problem with any of Technics...
If you remove the rubber pad from the top of the platter then you should be able to lift the platter off the servo drives' center shaft,
from memory the unit is not attached just held on by gravity,if the servo magnet is gone the take it in for a service and pay the man for his time,
My first problem on my 1200s was a pitch control issue and easy to fix,with a little cash,never use second hand parts unless you know what you are doing because when they fail on you while playing to a packed dance floor then youll get more of a supprise than you barginned for,
Misterdj
May 03, 2010 | Technics SL-1200MK2 Turntable
My turntable is Technics model SL-DD33 and all of a sudden stop working I changed the power supply cord and it didn't fix the problem. Will you please advise or where I could take it for repair and if it...
Define what isn't working. Is it dead (no motor, lights, anything)?
Or is there just no sound. The output of the cartridge is independent of any power. A basic test to see if it's alive is to lift the tonearm, select the Phono on your electronics, TURN THE VOLUME WAY DOWN TO JUST A SKOOTCH OFF OF SILENCE, place the tonearm somewhere over the platter and lightly brush the stylus (BACK TO FRONT) with your finger tip. You'll hear objectionable noise from both channels if the conenctions are all intact.
Dec 12, 2009 | Technics SL-BD22 Turntable
Just bought a new technics sl-1200 turntable and the pitch speeds up and down causing music to sound funny....
You will need to check your belt for wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
Dec 03, 2009 | Technics SL-1200 Turntable
Technics SL-5 Turntable will not turn.
try gently pushing the tone arm (actually the piece of plastic holding the tone arm) over to the right a little. works for me, but it still gets stuck often
Apr 06, 2009 | Audio Players & Recorders
Technics SL-D303 motor noise
CHECK TONEARM GROUND TO SIGNAL GROUND WIRE OR SOCKET FOR CONT.
Mar 13, 2009 | Technics SL-1200MK2 Turntable
Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
May 03, 2008 | Technics SL-1210 Turntable
Technics SL-1200MK2 Turntable Logo
602 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
