Question about Samsung CLP-500N Laser Printer
2 Errors Hello, I have a Samsung CLP-500N printer w/ Transfer Belt Error and Lever Unlocking Error. Can some one help? Kendall
Thanks jimed98.. That's what I thought! I will try and get a replacement.
Kendall
Posted on Oct 27, 2008
    Problem Solver:
  • 13 Answers
Transbelt is a part replacement-plain and simple. Samsung sucks for this, they give you no warning and just shut down the printer. www.samsungparts.com
Posted on Oct 26, 2008
Transfer belt
Try to take out transfer belt and reinstall. You might have to tell the machine that a new transfer belt has been installed.
Sep 09, 2013 | Samsung Image Transfer Belt...
"Lever Unlocking Error" Message
Probably a bad connection between the transfer belt contacts and those inside the machine - clean any dirt/toner off them and make sure they aren't bent out of position and try again.
Dec 30, 2008 | Samsung CLP-500 Laser Printer
I have a Samsung that say Transfer Belt Error
Hi
I have a utility to reset the consumables errors on this printer, but only if the component is past its lifecount. (60k for transfer belt)
Its called CLP-300_Reset_RLCv04.exe or just RLCV-04.exe (if you can find a copy)
If you need a copy, let me know and I'll find some way to get it to you.
I've used it for transfer belt reset and it works.
Dec 19, 2008 | Samsung CLP 300 Laser Printer
Invalid New Toner Black
is it a genuine toner?
some printers will not work with certain "reman" toners.
Dec 10, 2008 | Samsung CLP-500N Laser Printer
Error Code on Samsung CLP 500N
I don't enjoy these lovely cryptic messsages from Samsung either. Have you searched the Samsung support site? I have found some answers there that weren't in the manual.
Oct 26, 2008 | Samsung CLP-500N Laser Printer
Samsung printer error
Time to buy a new transfer belt. samsungparts.com
Apr 29, 2008 | Samsung CLP-500N Laser Printer
Phaser 6100 - lever unlocking error
This printer is same as Samsung CLP-500. So the problem is the same: Contaminated transfer belt sensor.
Do as follow:
Lift transfer belt assy from printer(Drop down back door 90 degree, press white button, lift top cover and release 2 locking levers, grab handle, pull the belt unit out), turn upside down & rotate plastic roller until small clear "window" appears along one edge of belt. Clean both sides of clear window with cotton bud. on same side as window, remove 2 screws securing flimsy plastic cover to gain acess to sensor, (follow red/black wires)remove a screw and pull out "U" shaped sensor(light transmiter and receiver), cotton bud and blow away dust on slits on inner surfaces of sensor. Reassamble and everything should be ok.If not, senser may be too contaminated, clean slits vigorousley with cotton bud, or maybe you just need a new sensor.
The theory is that printer detect transfer belt by transmit light through the clear "window". If either window not clear or sensor is contaminated, light will not reach the receriver part of the sensor, printer will report such errors.
Good luck.
Jan 26, 2008 | Xerox Phaser 6100/BD Laser Printer
Samsung CLP 500 series Laser Printer
If the messages are because the two units have reached their rated page count, you need to reset this via the printer menu system - see user handbook
Nov 12, 2007 | Samsung CLP-500 Laser Printer
Transfer belt errors
I saw this posted somewhere on the internet and it worked for me.
Take out the transfer unit and look at the bottom. One side has visible wires. Open the side panel on that side. Follow the 3 wires to a C shaped sensor held in with a screw. Remove the sensor and blow canned air in the slots on the inside of the C. Put it all back together and hope for the best.
Sep 30, 2007 | Samsung CLP-500 Laser Printer
Samsung CLP-500N Laser Printer Logo
183 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
