Question about Intel D865GBF Motherboard
It is regarding sound problem in intel chipset 845 motherboard
I am using intel chipset 845 motherboard of gigabyte. windows has installed but sound is not working. it is not even showing the audio device info. in control panel
  • 781 Answers
Download Microsoft UAA drivers for you O/S install them
then go to device drivers from the control panel right click sound driver and upgrade driver
will go on net and find and install them
MUST install UAA driver first
Posted on Oct 13, 2008
Sound output is not available now in my PC, having gigabyte Motherboard and intel processor.
You have Intel chipsets and Realtek sound. The gigabytes link only seems to have audio and lan drivers here;
http://www.gigabyte.us/support-downloads/download-center.aspx
Outlined info
1-Product Catagory-motherboard
2-By Socket-Socket 775
3-By Chipset-Intel 945GZ
4-Product Model-GA-945GZM-S2
Click search and enter you o/s and it will list your updates.
Other updates canbe gotten here;
http://downloadcenter.intel.com/
You can ckick on "Run Intel Update Driver Utility" and Intel will scan your system and suggest and provide updates or, you can search for individual downsloads
1-Product Family-Chipsets
2-Product Line-Desktop Chipsets
3-Select Product Name-Intel 845 Series
A new window will come up to choose your o/s
You may want to check your operation first by clicking "start", then click on "control panel". Find and click on "device manager". Click on box with + next to "sound audio and game controllers". Do you see a warning ?, !, Or a yellow triangle? click on that and follow proceedure. Right click on your device and in the list you should see "disable". If you see "enable" click on that and exit.
Ther should be a speaker icon in your taskbar at lower right of your screen. Right click on it, then click on "open sound mixer" and adjust volume.
Apr 02, 2011 | Gigabyte GA-945GZM-S2 Motherboard
Installed windows xp professional on IBM desktop. motherboard is intel 845 . from where to install board drivers for better graphic display also the sound drivewrs for soundmax.
vga driver here
www.intel.com/support/chipsets/sb/cs-009236.htm
sound driver
http://download.cnet.com/SoundMAX-Integrated-Digital-Audio/3000-2120_4-170204.html
Jan 10, 2011 | Computers & Internet
I need display driver for my pc i am using intel 845 mother bpard i need driver for windows vista
If you are using Intel 845 Chipsets motherboard, FYI, 845 chipsets family does not support OS Vista, you will not be able to get any Vista drivers support from Intel!
You can read this thread from Intel @ http://www.intel.com/support/motherboards/desktop/sb/cs-008326.htm
Aug 04, 2010 | Intel Computers & Internet
Problem loading XP Serve Pack 2 in Gigabyte 8I845GVM-RZ
I know this may sound mundane, but did you load the correct set of windows drivers for the Intel 845 chipset? I mistakenly loaded the Home drivers onto a unit I tried to install Pro on and I got all sorts of errors.
Mar 26, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
USB2.0 to work
In the CMOS setup, on the Advanced tab, USB Configuration, enable "High-speed USB", according to this page. The instructions there may not be the same as yours, as Gigabyte may be using a different BIOS. On this page is the latest Intel INF Update Utility for your Intel 845 chipset.
It is also possible that your motherboard does not support USB 2.0. The manual I saw was suspiciously quiet about it.
Dec 06, 2007 | Gigabyte GA-8IRX Motherboard
Ram support for intel 845 motherboard
Ok. So you've defined the Intel 845 chipset on your motherboard.
But is it the 845 or 845G chipset?
Click HERE for the specifications of the Intel 845 chipset.
Click HERE for the specifications of the Intel 845G chipset.
Peepnklown is only HALF right.
The Intel 845 chipset does NOT support PC133 memory.
The Intel 845G chipset DOES support both DDR and PC133 memory.
The difference?
The 845 has a single memory controller for DDR memory.
The 845G has two memory controllers. One for DDR and one for PC133.
Although you're going to need DDR memory as it is FASTER and less expensive than the older PC133 memory. (Believe it or not.)
I do NOT recommend using Corsair's ValuSelect memory on this chipset. I have two boards with the 845G chipset and that type of memory does not allow the board to boot.
These boards typically come with DDR266 (PC2100) modules installed.
I would go ahead and buy DDR333 (PC2700) memory for it. The board you have may not utilize the full speed of that memory, but will use tighter memory timings if the RAM is clocked down by the board. This will result in better efficiency of memory use by the processor.
Think of it as giving the motherboard "breathing room".
I could recommend PNY memory for the most basic compatability. (Not that they manufacture their own RAM modules...) Or perhaps Nanya, Infineon or Microtek.
Look for memory compatability lists for your particular motherboard module online. You could also use PNY's memory configurator on their website.
Click HERE for PNY's memory configurator.
Good luck.
Cyryl
Nov 10, 2007 | Intel Motherboard
Intel D865GBF Motherboard Logo
96 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
