Samsung DLP TV Built in Tuner Broken?
Hi, I have a Samsung HLS5065WX DLP TV with built in ATSC/NTSC digital tuner. Its worked fine picking up 10 or more HD plus regular channels daily for over a year. We have it hooked up to a outdoor HD antenna. We turned on the tv yesterday and it said "no/weak signal" on every channel. We arnt even getting regular channels in nothing. Just fuzz. We checked the antenna/cables by hooking it up to another tv and picked up channels fine. I called samsung and big surprise we are out of warrenty. They said it could possibly be the NTSC tuner. I called the repair shop and they want $275 labor plus part costs. Is there anywhere I can buy this part myself and have my husband install it? He is very good with fixing things and if we could fix it for cost that would be great. However, I cant find the part number or parts store or anyone that has even had this problem before for that matter.
Thanks for any feedback!
4 Suggested Answers
Taisha
  • 44 Answers
SOURCE: 52G786 ATSC Tuner no longer works
I have the same exact model tv...Love it...ATSC tuners is in definition an Analog tuner. As the broadcasting companies change over to Digital broadcasting before the deadline in Febuary 2009 more and more local or Non-Digital chanels are becoming obsolete. You would have to purchase a converter box for your tv if your not planning on getting cable. Another way to gois if you have an old cable line running through you house (no incomming cable) plug you tv into that jack. That also acts as a antenna. The sweet part of all this is that your tv do have a QAM tuner or Digital tuner built in just need that digital antenna to pair it up.
Posted on Jan 03, 2009
THETVDR
  • 5 Answers
SOURCE: Need a tuner for HDTV Samsung Model #HLR4667W
THERE IS A DIODE ON THE MAIN SIGNAL BOARD THAT HAS SHORTED OUT REPLACING THE TUNER IS NOT GOING TO HELP MATTERS
Posted on Jul 23, 2009
SOURCE: toshiba 46HM95 wont display 720p from dtv antenna other tv works
lets start with the easiest first.does your tv in the menu option offer an input output source like 720p or 480p?on my set i can change to any format.maybe yours does too.let me know and we go from there.
Posted on Mar 04, 2010
Is the Rca true flat digital
I'd need the model number to tell if the RCA TV has a digital (ATSC) or analog (NTSC) tuner. The mandate for inclusion of the ATSC tuner depended on the size of the TV and the year of manufacture. Small (<25" diagonal) TVs didn't need to have an ATSC tuner when they were built until 2007. The older TVs could still be sold with a "cable-ready" or similar NTSC only label. (The 32"+ TVs had to have the ATSC tuners in 2005 and the mid-size TVs had to have the digital tuners in 2006.)
For example the 27F530T was manufactured in 2003 and only has a NTSC tuner. However, the 20F424T was manufactured in 2008 and does have an ATSC tuner.
I hope this helps.
Aug 07, 2015 | RCA Televison & Video
How can i tell if my tv is digital
The iLo IWT3206 TV provides two built-in -- or integrated -- TV tuners: a National Television System Committee (NTSC) tuner and an Advanced Television Systems Committee (ATSC) tuner.
While the NTSC tuner allows iLo IWT3206-viewers to receive analog, free-to-air TV broadcasts, the ATSC tuner allows viewers to receive digital TV broadcasts via a cable or satellite provider.
The benefit of having an integrated ATSC tuner is that it negates the need for a separate cable box or satellite receiver, which can take up space.
Oct 24, 2013 | iLO IWT3206 TV
Does my toshiba have a built in converter
The Toshiba 46G300U TV has a built-in Digital QAM, ATSC & Analog NTSC TV tuner.
Apr 01, 2013 | Toshiba 46G300U TV
I have a Jensen TV, Model Number TS2050J. I need to know if it has a QAM tuner built in.
Hi.
No, your tv is an older model sdtv with an analog only NTSC tuner.
Newer model have an ATSC/Qam digital tuner, but not your model.
This means that if you want to watch tv, you'll have to get a converter box. It will have the ATSC/QAM tuner i it, and it converts the signal into lower definition NTSC, and then sends it to the tv through either coax cable, or rca cables.
Once in a great while you might even find one that has s-video output, but those usually are expensive.
I hope this helps you out.
Feb 08, 2011 | Jensen TS2050J 20" TV
How do you get the tv to search for digital channels
I need more info! How old is the television? when you say "standard" do you mean standard definition? CRT or "tube" model?
Older model TVs with the NTSC tuner will NOT pick up the digital over the air signal, you need a TV with ATSC/QAM tuner built in, or a set top box.
Dec 08, 2010 | Sony Televison & Video
Is the tuner built-in ATSC, or NTSC?
Your tv tuner is set to function on both NTSC and ATSC. See below for the reference
NTSC (National Television System Committee) is the analog television broadcasting standard used widely in North America. It is referred to as a 525-line standard, but actually displays only 480 lines. NTSC is to be replaced with new DTV (Digital TV) standards in the coming years.
ATSC (Advanced Television Standards Committee) creates the technical standards for the US digital television system (DTV). These standards are expected to be used in most new televisions, as the US television system shifts from analog to digital.
Nov 10, 2010 | Toshiba 57H84 57" Rear Projection...
What type of antenna do you reccomend cant get the tv to work at all no picture no sound not using cable no antenna tried auto PLEASE ADVISE!!!!!!!!!!!!!
Lets get started. First the TV you have does not have the new ATSC digital tuner built in. It uses the old NTSC tuner. You might find a few stations, however most major networks have gone Digital because the maximum power for NTSC is limited to 1000 watts. ATSC is the new digital standard for broadcasting both High Definition programs as well as standard definitions programs. So you will need a Digital converter box. They sell them at Radio Shack for around $60. You can get one on ebay for around $25. You will also need and antenna. A good old set of rabbit ears will work fine if you not to far (less than 25 miles) from the transmission towers. If your out in a rural area (greater than 25 miles from the tower) you may want to consider and outdoor antenna. Antennas Direct is a great source for antennas.
http://www.antennasdirect.com/
You can also get help estimating what kind of antenna you need at this web site:
http://www.antennaweb.org/aw/Address.aspx
However you may want to consider buying a new TV which will have a new ATSC tuner built in. You will still need and antenna.
Hope this helps.
Feb 23, 2010 | Philips 25TR19C 25" TV
Does this model have a built-in QAM tuner?
Yes it does.
  • Includes built-in ATSC/QAM/NTSC tuner for off-air HDTV and SD (standard-definition) reception
  • Accepts high-definition 1080i, 720p, and 480p signals from DTV set-top receivers and progressive-scan DVD players
  • Side-panel A/V hookups and controls allow easy connection with a camcorder, gaming console, or other device
  • Aug 15, 2009 | Samsung DynaFlat TX-P2775H 27" TV
    Tv Tuners
    Hey jp62388,
    According to information provided by the manufacturer, this model TV should have a built-in NTSC/ATSC and QAM tuner. These should allow you to receive locally broadcast digital TV signals without the use of a set-top box or digital converter box.
    If you're concerned about your TV's specifications, the most important thing you'll need to look for is a built-in or integrated ATSC tuner. NTSC is the old analog standard that is to be phased out in early 2009, while ATSC is the new digital standard that is to be used within the United States and Canada as NTSC’s replacement.
    Should you have any other questions or concerns, I'd strongly suggest checking out the FAQ section of the federal government’s official DTV transition website:
    http://www.dtv.gov/index.html
    Hope this helps you out.
    Sincerely,
    Aaron
    Go Ahead. Use Us.
    Jul 03, 2008 | Televison & Video
    How do i convert my dtv-5801 to the new free digital air waves
    My information indicates that the DTV-5801 has a NTSC (analog TV) tuner built in bot not and ATSC (digital tuner). It does have HDTV inputs to which an external tuner can be connected. For Off-Air Digital TV, add an HDTV (ATSC High Definition tunner) and you are set to go. Do not buy the DTV converters, they have down converters built in and only deliver SD to the outputs.
    May 26, 2008 | Runco DTV-5801 58 in. Rear Projection...
    Televison & Video Logo
    346 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
