Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
Refrigerator warm on top, cold bottom, blower fan top of freezer not turning
My GE profile refrigerator is 9 years old. It is cold at the bottom, warm on top in both refrigerator and freezer. I took off the fan cover and the fan is not turning. The compressor seems to be running.HELP!
  • jeffsolly Oct 13, 2008
    I moved the fan blades slightly and it started to turn with some help. It has been running for about 30 minutes now by itself. The upper part of the freezer is now at 20 degrees and dropping (it was much higher before) so it seems to be working. Thanks for the advice.
    President:
  • 1,462 Answers
Check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Posted on Oct 13, 2008
Have GE profile refrigerator. It is 3 years old.
OK check the Thermistor, the actual temperature sensor element, and or thermostat if it uses a separate feed.
Sep 10, 2011 | GE Refrigerators
@15 yr old GE top freezer fridge. Top freezer
check to see if an internal fan is fitted. This may have stopped/ burnt out. if fan is running try 24 hr defrost.
May 15, 2010 | GE GTS22KBP Top Freezer Refrigerator
GE Profile french door refrig not cooling but freezer is cold
your damper vent door is not opening to let the freezers cold air in to the refrigerator compartment,its located between the refrige and freezer,also make sure the evaporator fans are running to move the cold air
May 16, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
Freezer working but refrigerator is not cooling
if freezer is close to zero, top to bottom, and fridge is warm(ing), then you likely have a defrost problem, you will notice an abundance of snow/frost on back wall of freezer. it could either be your heater, thermistor, defrost safety thermostat, or your defrost control/main cpu, depending on model. if either or both sides are warm at the top, and cold at bottom, then your freezer fan is out. again depending on your model, it may just be the fan, or a combination fan/main cpu board hope this helps
Feb 15, 2010 | GE Profile PSW26P Stainless Steel Side by...
Freezer is warm at top and cold on the bottom.
Sounds as tho your evap fan is not running. Open door to freezer and should hear a fan running smoothly. If not most of the time the problems is with the main control board on back of refrigerator.
Jan 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
Freezer on bottom is cold,refrigerator on top is warm. 2 days before failure there was a vibration noise intermittently between fridge and freezer that stoppped if freezer door was shut hard
This is a little strange to hear but something caused the vibration. Closing the doors hard or soft may make big changes in sound because of pressure change. I just want to know if the compressor is purring away without overheating. Anytime there is a restriction in ventilation the evaporator fan will struggle to push the air to the freezer and enough to refrigerator side to maintain safe temperatures. On the bottom even if the fan stopped the bottom would work because it is below and cold is heavier than warm. I will look over your parts breakdown to see what vent, dampers or fans that may cause this, work with me on this and I will help you solve this. Thanks Sea Breeze
Jan 21, 2010 | GE Profile PDS20SFS Bottom Freezer...
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
498 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Stan Ford
