Question about Linksys Wireless-G Broadband Router
Laptop with wireless router connection runs slower than PC wired direct same source
I have a laptop in my bedroom using my wireless router for Internet access. I have a PC connected to my dish service with the router spliced in. Both work on line but the laptop operates at half the speed, slower than dial up. I am not paying for the highest speed available from (wild blue) my provider but the PC runs it fast enough to please us. I feel there is something I can do on the PC to fix this but need help with it.
  • akdobkinza Oct 14, 2008
    Since the only response I received was in Spanish and I am an English speaking American, I submit the following solution I found on my own written in ENGLISH. I simply returned to the "Set Up" procedure for the router and placed my laptop on the desk next to my PC. I entered all new names, passwords and 26 digit code as if it was the first time installation on the PC. I utilized the "add new devices to the network" function and entered the 26 digit code on the laptop as well. When I was prompted to select a security level category, I chose the second highest level which allows some degree of possible invasion or actually accommodates older system operations mostly. My PC was not actually recognizing my laptop as being a member of my network even though I had Linksys tech support on the phone assisting me when I added it. Regardless of who tells you otherwise, it is not necessary to connect your additional devices directly to ethernet to splice them into your network. In as few as 2 calls to their tech support, I have found that solo experimentation is more effective and reliable. Just start the installation process again when adding devices to your network and read carefully and don't be paranoid with security unless your FBI or CIA or something like that. I could visit India in less time than it takes to communicate with those tech's.
PARAMETROS ESTANDAR DE CONFIGURACION
Posted on Oct 14, 2008
Tip
Getting the most out of a Home Network
A wired connection is still the best way to get maximum download and upload speeds because your computer is directly connected to your gateway/router via an Ethernet cable. While this method offers consistent speed, it might not be convenient running multiple PCs and Laptops with a wire in your home.
Improving your wireless connections:
1. Do not use wireless connections where it is not needed or not important.
Devices that are not moved frequently such as a printer or a desktop PC can use the ethernet cable to minimize traffic in the wireless connection. Some home users use a wireless adapter for their desktop PC to connect wirelessly which I think is irrelevant not unless your desktop PC is really far from the router. Most routers provide 4 ethernet ports which you can use for the printer and desktop PC.
2. Make sure that your Wireless Network has WEP/WPA enabled.
All routers are equipped with security features that can provide passwords to your network. A secure network is less susceptible to unathorized use of your network. The more users use your network, the slower it becomes.
Sample video on how to secure your network using a LinkSys Router:
3. Get a better range.
Depending on how your home is designed, your wireless gateway may not be able to reach certain parts of the home, but you may be able to improve access to those trouble spots. There are several companies that have developed wireless repeaters (sometimes called a signal booster), devices that can pick up the signal from your router and extend that signal to other parts of the house. It should be noted that any repeater has its own limitations and the greater your distance from the repeater the weaker your signal and the slower your speed will be.
4. Change your wireless channel to reduce interference.
You may experience weak or dropped signals if a cordless phone or any other electronic device and your wireless router share the same frequency channel. A potential fix for this issue is to change the channel, thereby reducing frequency interference. The wireless channel can be can be accessed in the wireless settings of your routers interface. Channels to choose from are Channels 1 to 11. This should be done in a trial and error method, choose whatever channel delivers the most speed.
Sample video on how to change the wireless channel on a Zoom Router:
5. Make sure that you are running the latest firmware and driver updates.
One of the easiest steps to improve your connection speed is to make sure you are running the latest software updates for your wireless adapter. If you are, the next step would be to check if your network card has been updated with the latest drivers. To confirm that you have the latest drivers available, go to the wireless card manufacturer's website and look for a Support and/or Driver link. If you have a built in wireless client (one that cannot be removed from your PC), check to see if your PC manufacturer has issued any updates.
The above tips has greatly improved our home network which consists of a Prolink router, 2 netbooks, 1 laptop, 1 desktop pc, 1 printer and an occasional use of mobile phones to connect to the internet.
Thank you for using FixYa!
Have a great day!
Jas247
on May 26, 2011 | Computers & Internet
Hi, I'm having problems connecting to the router (Virgin) to my bedroom from lost of signal strength, so i brought Sitecom Wireless Range Extender 300N to boast the signal. I've installed the Range...
1. did you first try to connect to the router via wire directly with it in the same room? then set up the wireless to work in the same room too.
2. once you've done that and it worked then move it to your bedroom. If it doesn't work there it could be that there is something inbetween the two rooms that is blocking the signal...ie a furnace can do that
3. if it won't work try relocating the router to another location. Try a different location in the same room first
but as i said , first get it set up and running in the same room so you know for sure it works.
Mar 21, 2011 | Computers & Internet
Why does the "7" inch netbook have problem,slow
spyware or a virus check is needed also open the browser goto internet options, conections, near the bottom will be lan settings make sure the box ( automaticly detect settings ) is ticked.
Mar 15, 2011 | Sylvania G-Netbook
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
I have internet connection but my laptop will not connect
Check your connections. 1. Wired: directly connected to the modem (not the router) If this works, the router is the issue. 2. Wired directly to the router If this works then wireless is the problem 3. Wireless Check Key for accuracy, Upper and lower case matters. Check that your router does not have MAC address restrictions 4. Clear the cache on the laptop IE. Use the Options menu to clear this.
Dec 12, 2009 | MSI U120-024US Notebook
I am running qwest DSL through a Linksys wrt160N that is brand new. it will work next to the router, but not upstairs or in the basement which is less than 15 meters. The upstairs bedroom is directly above...
If you have concrete floor slabs the the wireless signal from the Linksys will have a difficult time penetrating the floor slabs.
The wireless card in the computers will show a low signal strength.
Try altering the Linksys aerial to a horizontal position and also positioning the Linksys to another location.
You could be getting interference form other wireless sources, check the wireless channels of other wireless router/access points in your area. If they are broadcasting on the same channel then configure your Linksys to broadcast on an unused channel or one that has the weakest signal strength.
If none of these methods work then I would suggest you run network cables from the Linksys to upstairs and downstairs and not use the wireless connection.
If network cabling option is not an option then consider extending the wireless range with wireless repeater access points.
Nov 07, 2009 | Linksys WRT160N Wireless Router
D-Link 615 stopped connecting with wireless
If your laptop is not detecting the wireless router, can you try to get the laptop closer to the router ? If you have done that already, I would suggest you to try and power cycle the router once. If that doesnt work either, try to reset the router. Hope this helps
Thanks Ranjit ranjit@supportminds.com
Jun 17, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
My IMAC ethernet connection to my wrt54G is much slower than wifi
Then you have your settings wrong, as I have the same setup for many years. The setup page of your router should be set basically default, it should be all set to auto ip and other than your dns there should not be anything else to set. I have 3 wireless and two wired devices and all of the computers .And the speed is constant,,something is wrong with your settings, if you can take a screenshot by opening the router homepage and hitting the print screen button on your keyboard, you can then hit paste on here and it will past the entire thing on here to examine
Mar 20, 2009 | Linksys Wireless-G WRT54GS Router...
How to share internet connection using ADSL modem to two PCs/NBs
Hello
To use same internet connection you will need wired or wireless router, I would suggest wireless router since you don't have to mess with wires, you can buy these routers anywhere best one to get is Linksys and it comes with all the instructions.
Thankyou
Nov 26, 2008 | IBM ThinkPad T41 Notebook
Linksys Wireless-G Broadband Router Logo
182 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
