Question about Lexmark X1270 All-In-One InkJet Printer
Sdaras sefsrgrt drg erg dg
  • Anonymous Oct 13, 2008
    it will not print incolor
I CANT LOAD DRIVER
Posted on Oct 18, 2008
Do you know where I can find the firmware update (1.18) for a Bauhn 1Tb PVR?
http://tempoaustralia.com/sw/as-pvr1000r/AS-PVR1000R_IM.pdf
DG-DABVPR1TB
down load and put on a usb drive,
DGTEC firmware 2011 updates available
New updates available for service issues such as freezing and start up/ recording issues (firmware 2011) are also available from the DGTEC website.
Please update software first before replacing hardware...
From DGTEC Website Software Upgrades page: -
Click on the relevant link below to download the latest software update for your DGTEC product. For further help and assistance, please access the DGTEC Call Centre via the Support page.
Obsolete Products
* DG-FV500PVR Upgrade (zip file 4.3Mb)
* DG-HD6760 Upgrade (rar file 2.3Mb) Upgrade instructions DG-HD6760 (25Kb)
New Products
DG-HDMP1080
DG-HDMP1080P
DG-HDMP1080TT
DG-HDMP500TT
DG-DABVPR1TB
DG-DABPVR500GB
DG-HD2104AND
Models
DG-FV500PVR - 500GB HD PVR WITH TWIN TUNER (FREEVIEW)
DG-HD6760 - HD SET TOP BOX WITH USB RECORDING
DG-HDMP1080 - HD MEDIA PLAYER
DG-HDMP1080P - WIRELESS HD MULTI MEDIA PLAYER / STB
DG-HDMP1080TT - HD MEDIA PLAYER WITH TWIN TUNER
DG-HDMP500TT - (NEW MODEL RELEASE)
DG-DABVPR1TB - 1TB HD PVR WITH TWIN TUNER WITH INTEGRAT
DG-DABPVR500GB / DG-DAB+500PVR- 500GB HD PVR / TWIN TUNER WITH INTEGRATED
TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR
GG-HD1200PVR- BAUHN UNIT WITH TWIN TUNER
Note: - Master Override Password 1973
Instructions:
Read instructions carefully before commencing. Software needs to be carried out while the PVR is cold. Go to "Telefix" website and select "Service Guide" or "Download Service Manuals" and download software to a location on the PC Hard Drive.
Unzip file and copy "usb.upg" software onto a blank USB Memory Stick.
Plug USB Stick to USB port of PVR
Connect Power to PVR and switch on so that that the booting process commences.
Press 'Menu' button and scroll left or right by using the arrow buttons to find 'Installation' then press OK to select.
Note: PVR may freeze and not allow selection. Several attempts will be required to enable selection. If problem persists, switch OFF PVR to allow it to cool down then try again or use the alternative method.
Alternative Method
1a. Disconnect mains power.
2a. Plug USB Memory Stick to USB port.
3a. Press and hold the CH down arrow button on the unit and then connect mains power.
4a. When the display starts counting down release channel button and the upgrade interface will appear on screen.
7. Scroll down to 'USB Menu' by using the arrow down button then press 'OK' to select.
8. Scroll down to 'USB Upgrade' by using the arrow down button then press 'OK' to commence software update.
ยท Note: - Please do not shutdown PVR or remove USB Stick during the update process. When the update is complete the PVR will power down and reboot again as normal.
Once the update has completed, reset the PVR by restoring back to Factory Default.
Press Menu ? Installation ? Factory Default ? enter password 0 0 0 0 ? Select 'Yes' ? press OK to rescan channels.
Check Software Version, Press Menu ? Installation ? Version Info ? OK
download and put on usb drive
Software Updates
Apr 11, 2015 | Televison & Video
When will Frank Hodum's ERG 2012 Tool be available for download?
The Emergency Response Guide ERG 2012 being transferred to the web and iphone.
http://www.web-application-developer.com/erg2012/index.html
to save it on your iphone choose the center bottom button then "Add to homescreen" after that you shouldn't even need to have an internet connection to use it.
Apr 03, 2012 | Frank Hodum ERG Tool
What button do i press if i want to write something in degrees ? its in the trig chapter i have a sharp El-531w Thanks
To set the angle unit to degree you press the [DRG] key once or twice until a DEG indicator appears on the screen (where you cannot enter anything).
The key may be labeled [DRG] with an arrow sign.
Hope it helps.
Thank you using FixYa and for rating the solution.
Nov 30, 2009 | Sharp EL-531VB Calculator
Get rid of the RAD
You use the key combination [2ndF][DRG]. Every time you press the two keys in sequence it changes to the next angle unit. If your calculator is on RAD, you press [2ndF][DRG] once to change to Grads, and another time [2ndF][DRG] to change to degrees.
Hope it helps
May 09, 2009 | Sharp EL-531VB Calculator
Oracle Error
if it occurs after imported, it's because ctx'preferences was not imported. Try to get preferences from source (by reverse engeneriing or see with ctx_report.create_index_script package).
You will get severals scripts to execute on target db
Sep 08, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
How do i do "regular" math, calculator stuck on GRAD/DRG...
Pressing the DRG key toggles through using degrees, radians, grads
Instruction booklet page 9 explains...
http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=2&paneId=18#27
Aug 07, 2008 | Texas Instruments TI-30XA Calculator
Blocked Passage on ERG System, or Failed ERG Valve, or ERG solenoid Faulty
Very common on Ford engines with EGR codes is the tube inside the intake manifold that takes unburned exhaust gasses and recirculates them back into the engine for reburning,the tube becomes restricted from hydrocarbons and just plugs up.The intake manifold and tube has to be removed and thoroughly cleaned.
Jul 26, 2008 | 2000 Ford Focus
135-400mm lens on nikon d40
Unfortunately, this lens is not supported by the D40 due to Nikon's unfortunate decision to leave out the autofocus motor from this camera.  This is why I tell folks not to waste their money on the D40 - access to the many, many, many lenses that Nikon has made over the years, many of which are available used for a substantial savings, is lost on this camera.  The only Nikon lenses that work are AF-S lenses, and some third party lenses that have their own internal motors.  I got a list of Sigma lenses that are compatible with the D40 for you:
The list of compatible Sigma lenses for the Nikon D40 as of the current date is as follows:
  • 10-20mm F4-5.6 EX DC
  • 12-24mm F4.5-5.6
  • 17-35mm F2.8-4 DG
  • 50-500mm F4-6.3 DG
  • APO 50-150mm F2.8 EX DC HSM
  • 70-200mm F2.8 DG MACRO
  • 80-400mm F4.5-5.6
  • 100-300mm F4 DG
  • 120-300mm F2.8 DG
  • 300-800mm F5.6 DG
  • 14mm F2.8 EX
  • 30mm F1.4 EX DC HSM
  • 150mm F2.8 EX DG
  • 180mm F3.5 EX DG
  • 300mm EX DG
  • 500mm EX DG
  • 800mm f5.6 EX DG
from here:  http://www.imaging-resource.com/NEWS/1177682545.html
Sorry for the bad news.  The cheaper thing at this point may be to sell the D40 and get a D80.  I personally have a D70S, but that is no longer made.
Dec 06, 2007 | Sigma Zoom Tele 135-400mm f/4.5-5.6 APO...
Lexmark X1270 All-In-One InkJet Printer Logo
108 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
