Question about JVC Televison & Video
I have a JVC model AV-32750 TV. We were watching TV and suddenly the picture went out and the red light on the on off button in the front panel started flashing and clicking. The TV will not turn back on. I unplugged the unit waited for about 1 minute, plugged it back in and the same thing happens. I have tried to turn it on with the remote and manually, niether one works. CAN YOU PLEASE DIAGNOSE THIS PROBLEM FOR ME SO I HAVE AN IDEA OF WHAT I NEED TO DO. Thank You Very Much.....
  • 10,594 Answers
Problem seems in horizontal / vertical deflection circuits. If you have good knowledge of electronics and can test components then you need few tools like volt meter, service manual, screw driver etc to repair this model.
Or get help of local tv repair shop and ask an estimate.
Thank you.
Posted on Oct 13, 2008
  • 81 Answers
Hi.
Sorry but according to your explanation it seems a hardware problem.
I would advise to get it checked at a service center.
If you have any question do feel free to ask me.
Regards
Faraz
  • JVC Master
  • 19,396 Answers
Unplug the unit for more than just one minute, let say at least half an hour. Let me know how many times the led blinks, probably the unit need repair.
  • Ginko
    Ginko Oct 13, 2008
    The TV does not turn on because there is an internal problem, like a
    short, a bad voltage, or more commonly a faulty component (IC ,
    capacitor etc.).
    The tv is in protect mode, try first unplugging power cord for at least one hour, so to drain power completely from tv circuts, reset eeproms settings, and clear electrostatic charges, and see if this solve the problem.
    When the TV is in this state, the main Chip inside your TV
    detects that there is a fault, and send the TV in protect mode,
    activating a safety switch that prevents TV from turning on. The switch
    keeps turning off the tv, and that is the clicking noise that you can
    hear.
    Unless you have experience as a TV repair, try first
    keeping TV unplugged for one hour or more. This will reset TV circuts
    draining power completely, and sometimes can wake up the TV from
    protect mode.
    If it does not work, that means that there is a
    defective component inside the TV. In this case I suggest calling the
    phone number listed on the user manual to get support from manufacturer.
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
JVC model AV-32750..... The close caption feature is toggled on and a large black square is blocking picture. I have no remote to enter the menu settings so using buttons on bottom front. I am unable to...
just look in the section for closed captions----the box is the "text" feature and just needs to be turned off; if you did it without a remote it can be undone the same way.
SD TECH
May 13, 2011 | JVC AV-32750 32" TV
How much does the jvc standard tv model no. av-32750 weigh?
About 50 lbs,used to help friend tv shop fix alot of these standard tv.Carry them all the times.
Jan 13, 2011 | JVC AV-32750 32" TV
Jvc - av-27320 - no picture, no sound, red light comes on
you may just need to get rid of it and get a new lcd tv with the new tuner.
Jan 08, 2009 | JVC AV-27320 27" TV
Jvc av 36950 went off while watching, the same sound that you get when you turn set off. No sound, no picture, no red power light
This TV has a common problem. I've found dozens of owners with the same complaint. See the following blog for a simple fix for your set. I tried it and it worked and I spent under 2 bucks to fix it myself at home!
Good Luck......Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Dec 09, 2008 | JVC AV-36950 TV
Screen went black
Remove the front grey bottom panel of you TV (don't forget the 2 screws behind the front AV cover located just below the power button) then remove the panel behind the grey panel. You should see 2 heat sinks on the front right of your TV, place a fan near your TV and have it blowing on the heat sinks. Now turn on your TV and see if it stays on longer then it has been. If it does, your DC amps might be overheating. If they are, you might be able to fix your problem by adding in a little more heat sink compound between your DC amps and the heat sink itself. You can find the compound at Radio Shack for about $5. let me know if pointing a fan directly on the heat sinks helps.
Jul 25, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-56WP30 56 black screen blue light on no response
make sure your front panel lock in your menu is not lock if is then unlock it cause it will lock everything on the tv in front and can't move anything
Jul 15, 2008 | JVC AV-56WP30 56" Rear Projection...
Jvc tv on button flashing on av 48wp34
Use remote, sounds like Tv is in child lock
Dec 21, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-32750
Resolder the vertical deflection output IC421. It is located about three inches to the left of the flyback transformer which is the part with the red cable going to the picture tube.
Nov 12, 2007 | JVC AV-32750 32" TV
Televison & Video Logo
99 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
