Question about Miele G880 Dishwasher
Dishwasher full of water at end of cycle
Solenoid seems to operate ok, there are no obstructions in the drain
I had a problem where the intake/drain port had an obstruction that caused the dishwasher to not drain which then shut the G880 Miele dishware down. I fixed by finding a loose piece of a rubber seal from the Miele that had become lodged in the intake port which then caused the impeller to cease. This intake/drain housing is accessible uncer the removable screen filter by pushing over a wire clip that holds a removable pipe leading from the intake to the lower rotating spray fixture. Slide (pull) this pipe out and inspect the impeller just underneath the pipe. Also inspect the pipe for any obstructions. Do not remove the ball bearing! Once I removed the broken off piece of rubber seal, it worked fine.
Posted on Jul 12, 2009
    Problem Solver:
  • 12 Answers
OK,,,,,,,,,,,seems to be the pump impellars or either clogged with grease ect. Find the pump amd remove the cover to it that you can have access to the inner impellar. I have seen this problem before and found that this was the problem , I hope this is yours. Goood luck RC
Posted on Feb 27, 2009
Doesn't drain
If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
HERE ARE SOME OTHER COMMON CAUSES:
H Drain impeller. The drain impeller is attached to the pump and pushes the water out of the dishwasher through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit. The drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve. The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced.
Clogged or Improperly Installed Garbage Disposer. If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug needs to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve. The check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball. The check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
HOPE THIS HELPS.
HOPES THIS HELPS.HOPE
Dec 17, 2013 | Kenmore 15129 Built-in Dishwasher
Neff dishwasher won't drain no sound
If your Dishwasher is not Draining check the following
PISTON VALVE
On some dishwashers that have a filter (screen) along the back wall of the tub have a piston valve. The piston valve commonly causes dishwashers not to pump out. if your dishwasher does have a filter, remove it. Now remove the piston valve located in the center behind the filter. Now to check the piston valve, press up on the spring. Once done the piston should stop up the hole in the top of the valve. When a piston valve, is bad the piston dissolves to the point that it can no longer stop up the hole, in this case replace it.
DRAIN SOLENOID
Another common problem on some dishwashers that will cause it not to drain properly is the drain solenoid. To check this, first disconnect power from dishwasher then remove the bottom panel of dishwasher. Once off, you should see the drain solenoid attached to the main pump then reach under the dishwasher and push down on the solenoid. If it will not move down it is bad and needs replacing. If it will push, down most of the time it is good but not always so follow these steps as well. Reconnect power to dishwasher, now start the dishwasher in to a cycle. If you have a mechanical timer turn it slowly until the solenoid energizes. If you turn the timer all the way around and the solenoid never energizes replace the solenoid. If you have an electronic control, start the dishwasher and wait a few minutes then push start/reset then the drain solenoid should energizes, if not replace the solenoid. At times the timer will cause this part to go bad especially if its melted or frozen down. So you may have to replace the timer as well.
CHECK VALVE
If your dishwasher is not draining properly, the check valve may be your problem. The check valve will be on some dishwashers with both a separatedrain pump and a drain solenoid (note if you do not have both you will not have a check valve). The check valve will be located where the black hose connects to the drain pump. To access the check valve, you must first remove the water from the dishwasher. A Wet-Vac works well. After the water is out, disconnect power to dishwasher. Now remove the dishwasher from under the cabinet. Now remove the black hose (even though you removed the water you will still have water in the pump so be ready).Once off you should see the check valve. It's the little red rubber flap. If it is torn off, the flap may have gone down the drain but you still should see the red ring left behind, in this case replace the valve. Sometimes the check valve will swell up and hang in the pump, if so replace it.
DRAIN PUMP
If your dishwasher is not draining properly, the drain pump may be your problem. As stated before, not all dishwashers will have a drain pump. To check this, First check to see if it is getting power. You should have 120 volts when the dishwasher is put into a drain cycle. If you have power and the pump does not run remove the pump and check for obstructions if none found replace the pump.
DRAIN HOSE
If your dishwasher is not draining properly, the drain hose may be stopped up. To check, remove all the water from tub. A Wet-Vac works well for this. After the water is gone remove the drain hose (even though you removed the water you will still have water in the pump so be ready) from the house plumbing and the dishwasher. Check for obstructions and remove. If you just installed a new garbage disposal check that the metal knockout was removed. Check the air gap if this is not right your dishwasher will siphon water back into it.
God bless you8f40db67-1c0d-4cd2-9a8c-eaef1ecc56e5.jpg6d070029-0e5b-496e-b38c-a20508611528.gif
Apr 02, 2013 | Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
Dishwasher won't drain completely. Several inches of standing water left after last cycle
Sounds like the wash/drain selector valve might be stuck. my Kenmore operating solenoid rusted and hung up. I cleaned and oiled it up. You can also have something that got into the valve and it won't close, or an obstruction in the drain hose or the drain pipe connector. Something is restricting the flow or the pump itself may have a bad impeller. Does it wash with vigor or has it lost a little oomph and sound different? Does it leave any debris on the dishes?
Jan 25, 2012 | Dishwashers
MY FRIGIDAIRE DISHWASHER WILL NOT DRAIN. MOTOR ONLY HUMS DURING DRAIN CYCLE. OTHER THAN DRAINING IT SEEMS TO WORK FINE. DAY IT QUITE WORKING SINK BACKED UP AND WOULD NOT DRAIN
if there is still water in the dishwasher take the drain hose off from under the sink and use a large pot or mop bucket and but the unit into a drain mode usually by cancelling the wash cycle if the unit still does not drain.Then use a wet dry shop vac and attach it to the end of the drain hose to remove the water
after the water is gone check the drain pump for any kind of obstructions you may need to replace the drain pump
Jun 06, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Dishwasher will not drain (water just trickes out) fill is good
Drain valve not opening or pump impeller loose on shaft - is it washing ok?
My guess would be drain valve not opening. It is a 110v solenoid and they get stuck or burn up. New solenoid costs ~$20.00
Mar 26, 2009 | GE 25 in. Nautilus GSC3400J Free-standing...
GE dishwasher GSD3200G00ww
HI, this seems to be an obstructed hose(drain). i recommend inspecting the hoses before replacing the pump.
To access the drain hose remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
The drain hose connects to the pump and runs to the sink drain (or to the air gap on top of the sink). The pump has a second hose that recirculates the water back into the dishwasher. The drain hose is roughly 1 1/2 inches in diameter. While inspecting the drain hose, check the recirculation hose as well.
When checking for blockages, disconnect the drain hose from the pump, pinch the wire clamp with pliers and slide it up the hose. Place a shallow pan beneath the pump to catch any spillage. Remove the hose from the pump; wiggling the hose may help to loosen it.
Check the hose and nipple to the pump for any debris. The only way to be certain the drain hose is completely clear is to disconnect it from the sink and run water through (such as spraying a garden hose through it at full pressure). Disconnect the recirculation hose and check it in the same way.
Reconnect the hoses and replace the clamps. Replace the lower panel and restore electricity to the dishwasher. If there are no obstructions found or debris, this will confirm a damaged pump and, it should be replaced.
NOTE(((Your model is equipped with a Drain valve(solenoid) i recommend testing this as well before swamping out the pump)))
The drain valve is typically near the motor although it can be located elsewhere. Look for a water hose running from the motor or underside of the tub. The hose should lead to the drain valve. The valve consists of the the gate arm mechanism and a solenoid (also called a coil). The gate arm allows the water to flow out of the dishwasher's tub through the drain valve. You should be able to move the gate arm up and down easily and smoothly. The gate arm also has two springs attached to it. If either of the springs is missing or damaged, they should be replaced.
The gate arm mechanism is engaged by the drain valve solenoid. The solenoid is connected by two wires. Label the wire placement on the solenoid before disconnecting the wires. The wires are connected with slip on connectors. Firmly pull the connector off of the solenoid's terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Test the solenoid for resistance using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to roughly 40 ohms when the probes touch the terminals. If the reading is infinity or substantially different from 40 ohms, the solenoid should be replaced asap.
Jul 19, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
BABHMJ's dishwasher husband
You need to pull out the D/W so you can get access to the water pump and remove the hoses to see if its clogged.
Apr 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Miele G880 Dishwasher Logo
351 people viewed this question
Top Miele Dishwashers Experts
Mike
Kolbrun...
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
