Question about Kenmore 63942 Dryer
110.86427100 - 64271 Kenmore electric dryer.
Tub turns fine and no vent blockage. I have checked the heating element and it reads "short" on a meter as well as the Thermal Cut-Out
Hi-Limit Thermostat, temp adjust. I also checked the fuse and it also reads short as it should.
Just not sure what these should read with a meter and what is causing the problem.
Please reply if you have any idea what might be causing the problem or can tell me the correct readings I should get with a DVM on these components.
Thanks.
Ken
  • nukeman77 Oct 15, 2008
    drcool299
    I appreciate you feedback. Thanks for confirming my readings.
    The tub would turn, yet on heat. I finally pulled the heating element and found a break in the coil, which was still touching part of the coil giving me the reading I was getting. Of course once I moved the coil where the break was, my reading went to an "open". I puchased a new coil and installed it and now I get what I should get; tub turning and heat to dry clothes.
    Thanks for you help, I really do appreciate it.
    Ken
  • sjgeiger Oct 22, 2008
    dryer turns on but tub won't turn
  • 958 Answers
All of those you tested should read short. that is correct. now what is your prolem?. is it not heating or it would not start?
if it woud not start, check the door switch. that would prevent it from starting.
if it would not heat but turning, there is a contact at the cetrifugal switch of the motor that would prevent it from heating.
tnx 4 using fixya,
drcool
Posted on Oct 13, 2008
  • francis rivero Oct 16, 2008
    hello nukeman,
    glad to hear that you finally fix your dryer,
    since ratings are as important to us as answering your questions. can i just ask a favor that you rate my solution.
    thank you in advance,
    it will be greatly appreciated,
    tnx again 4 using fixya,
    drcool
Dryer will not produce heat to dry clothes
you first need to access the heating element case and with a multi-meter check the element for 50-250 ohms,then the hi-limit switch and cycling switch on this case,then on the dryer exhaust vent housing theres a thermal-fuse,check this for continuity all components will check 0 or near 0 ohms=good/infinity,no reading=bad/except the element and the above is just an approximation as each element has its own resistance
Mar 19, 2010 | Kenmore 800 6983 Electric Dryer
Kenmore electric dryer model number 86860100 dryer not heating.....cleaned out vents not the problem....everything else seems to work.. I had seen in the past it glow in back of the dryer so I turned out...
hello there:
Testing with an ohm meter checking on a dryer....
These are the places that pass voltage to the heater elements on an electric dryer. In order to check a dryer for no heat, here is a list of places to check. Remember to always unplug the appliance before starting testing with an ohm meter. Always remove wires from the part you are testing with an ohm meter ( write down what goes where first before removing any wires ).
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuity across a good element 8-12 OHMS
Jan 09, 2010 | Kenmore Dryers
Dryer won't dry
I would start by replacing the main thermostat. It is possible it may be reading low - and not allowing proper heating.
Is the fan actually working ? With no airflow - it may overheat around the heater quickly and cause it to turn off too soon.
Some models have awkward ducts to clean properly - they really need stripping and hosing out.
Aug 20, 2009 | Kenmore Elite HE4 Electric Dryer
No heat, dryer runs fine it will not heat up. vent is clear all the way to the outside. I think it may be the fuse but I don't know the location, can you help?
hi..
Check the dryer breaker pair in the house electrical box. Push off, then on. If the breakers trip immediately, then you have a direct short circuit in the dryer, usually the heating element which involves removing the drum to get at the element(s). If the breakers hold, then try the dryer. If you get heat--ok. If drum turns, but no heat--check with a voltmeter across the two slanted slots in the power socket. You should read ~220 volts AC. If near zero, then one of the breakers is probably bad. Get an electrician to replace the breaker pair...
thank u
rate me
Aug 18, 2009 | Kenmore Dryers
Kenmore Dryer 110.64632300 won't heat up!
vent pipe kinked not letting heat away from dryer, check vent , or the thermostt stuck and not cycling heating element cycle off
Aug 12, 2009 | Kenmore 63942 Dryer
Kenmore elite , no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 27, 2009 | Kenmore Elite HE4 Electric Dryer
Electric dryer does not heat to dry clothes
You need to check the vent hose for a possible blockage. This is usually the problem. The element in this is one continuous wire so it's either bad or good and no in between.
Apr 09, 2009 | Kenmore Dryers
Heating element continuity?
Unplug the dryer from the wall. There are 2 wires connecting power at the heating element. Take one of these wires off, doesn't matter which one, but take at least one of the 2 off. Then put your meter probes across the terminal of the heating element where you took the 1 wire off and the other terminal of the heating element that still has a wire on it. Your meter will pretty much read full continuity if good, no reading at all if bad. Also check from one of these terminals of the element with one meter probe going to the metal frame of the unit. You should get no reading. If you do the element is shorted and would have likely tripped your house breaker.
Better to test a heating element for voltage with your meter like I described to you in your other question. I've seen heating elements read good when just doing a continuity test, however once voltage is applied and they start to heat they can expand and open up, thus not work, even though testing good when doing just a continuity test. Not always, but sometimes, it does happen enough to note to you.
Mar 11, 2009 | Kenmore 62602 Electric Dryer
No heat
have you checked the heating elements? you say the tub turns, is there any air coming into the tub and if so is it cold? if it is then you may want to get the heating elements checked.
Feb 09, 2009 | Kenmore 63942 Dryer
Dryer blows cold air but no heat
The heating element is in the back of the dryer. Sometimes there is a small access panel that will allow you to check the terminals to the heating element. You will need an ohm meter or multimeter to check.
Jan 02, 2009 | Kenmore 62802 Electric Dryer
Kenmore 63942 Dryer Logo
88 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
