Question about Garden
Interchange smaller bar & chain for existing chain saw
I have a poulan 22" chain saw - i would like to know if i can down size it to a 14 or 16 inch bar and chain ? how do i find out if I can down size & what is the part number
  • cfsimon927 Dec 01, 2008
    Are these part numbers for the chain ? I was inquiring about a part number for the bar...
  • 211 Answers
Yes you can(better for the engine).For14" the part number is 52 and for 16" is 60.
savumihai71
Posted on Nov 29, 2008
  • Savu Mihai Dec 01, 2008
    yes they are for the chain.Sorry,.I realy do not know the part number of the bar ,. Poulan chain saws are not so common in Romania.You can ask for at one of the shops who sales chain saws.
    best wishes savumihai71
Troubleshooting chainsaw
Sadly, the 3816 is not designed for larger timber. 38cc is only for smaller limbs, As a general rule also the largest timber to cut should only be 2/3 of the length of the bar
Jul 27, 2014 | Poulan/Pro 3314 3416 3816 3818 40184218...
My 18" Poulan Pro Wild
Sounds like your chain is to tight.Take the cover that is at right side of the saw motor off and loosen the two nuts a bit and look for a tension screw behind the bar and back it off,if the bar won't move loosen the two nuts that hold the bar on the saw.With the saw siting like you use it pull down on chain and get about 1/8 of an inch between the bar and chain.(use gloves)If the bar is blue by the chain groove You will need a new bar.Blue means the bar has over heated and lost its temper.The blue metal is brittle in other words.You should all so check the drive sprocket for wear.
If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions. Thank you for choosing FixYa.com and good luck.
May 20, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How to put the chain back on a 14" Poulan electric chain saw
Remove the cover that cover the rear of the chain bar.Now,loosen the nuts that attach the bar and slide the bar reward.Now set the chain in the slotted part of the bar,pull it forward until there is abut 3/8 of an inch slack in the chain an tighten the nuts.Re-install the cover.
Sep 12, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Feb 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What size chain does the Poulan Pro 4218 use?
It is an 18" chain .The user manual is at http://www.chainsawsdirect.com/manuals/PP_3516_4218_Man.pdf
On page 6 the part numbers for the bar and the chain are shown
Hope this helps .. if so, pls leave feedback, if not - let me know!
Jan 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My saw say on the side pouland 305 pro so how many cc is it
a pouland pro is a (low h.p. saw) and at 46cc i wouldn't run bigger than an 18 inch bar , its asking to much from the clutch and motor
May 03, 2009 | Poulan Pro Chain Saw 46cc 20"
I would like to go down A bar size our two on my poulan wildthing
I have a Poulan Pro 295 20".  When I bought it I also bought a 16"bar and chain and have been using those since.  They make the saw much easier to handle and are a better match to the available power. The key dimension is from the bar's mounting hole to its end.  At the store look at the normal replacement bar for your 18" saw, and pick out a 16" or even 14" bar with the same dimensions there.  This can be easily seen by laying one bar over the other.
Apr 02, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Too much oil on the chain
If you are using winter grade bar oil, then when the temps warm up, you are going to go through a lot more bar oil, because the winter grade is much more loose compared to the summer oil. I would not be to worried about using too much oil, because it just means that it is working and lubricating the saw well. About switching to a larger bar, I would not recommend going to a larger bar than what came with the saw, Unless the manufacture states what size bars can be used for the saw. Going to a 20" or 22" bar could bog down the machine, making cuts slower and not as clean, since the increased length of the bar would be too much for the motor to handle. with the larger bar the chain would be larger as well. So the power needed to move that chain has to be increased as well. So unless the manual says something like, "available bars lengths are..." Then I would just stick with the bar size it came with.
Mar 08, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
14 inch electric chain saw throws chain off
If a new chain ::
make and model is important here, as are guide bar length
a particular chainsaw, may be available with 12,14,16,18,20,22,24,26 inch guide bar,
likewise different saws (even from different makers) use the same size of chain
a chain for this saw may be sold in a variety of lengths or
may be sold in the longest length only and require links removed to suit smaller bars.
back to the store, with the saw, for confirmation
If an old chain::
stretched way beyond safety, replace
Sep 27, 2008 | Remington Electric Chain Saw
Garden Logo
231 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
