Question about Cameras
Recently my Power Shot G-3 started washing out pictures I take outside. Here in my home it has diminished quality, but outside it gets nothing or very little. Is this something I can repair, or do I need to send the camera to a technician?
  • ellisfugate Oct 14, 2008
    When I said I could fix the problem, I was assuming that it could be fixed without opening the camera. I an not versed in internal repairs on cameras. If I could have some instruction what to look for and how to open the unit for inspection, I might make the repair, but the expert did not give me that. Thanks. Ellis
  • Cameras Master
  • 19,396 Answers
Ensure first that is not a setting problem. For example if camera is set to night picture, all the normal photos will be overexposed.
Reset camera to factory default, and try also removing battery for five minutes.
If the problem is not a setting problem, check if there is dust or dirt on the lens, this can cause blurry pictures, and also grayish pictures, like they are underexposed.
If you cannot fix it in this siple ways, then probably the lens are dirty from the inside.
In this case it will be better calling a technician, rather than risking to reduce your camera to a bunch of bits and screws.
You can call a technician, validate your guranty, or eventually ask a guaranty extension (if available) , by calling the phone number listed on the last pages of the owner manual.
Posted on Oct 14, 2008
  • 10,594 Answers
If you know how to open and check circuit of camera, you can make it.
Problem seems CCD Imager flexible board connectors to be removed and hooked in board. This must be done with care as flexible board can be damaged easily.
Posted on Oct 13, 2008
  • Shahid Electronics
    Shahid Electronics Oct 13, 2008
    You should try to set camera on default settings before to repair it.
    Here is link to guide you how to set default settings.
Sound quality has diminished after power outage
Tries unplug,replug an hour later,let the tv reset itself back to factory setting.After,turn on the tv,go to the menu,go to sound on ur menu go down to reset the sound.The functions should go back to normal,not than.Ur tv Tuner signal board have a short,in the power outage occurance.
Apr 14, 2010 | LG RZ-37LZ30 37 in. LCD Television
I have a Canon Power Shot SD1100IS. I get a
A 32mb card isn't very big. If your camera takes pictures larger than 6mps, the card will fill up fast. Why not buy a larger card? You can set the picture quality to a lower setting in the menu of the camera, but if you capture that once in a lifetime shot and you want to print an enlargement, the quality will suffer. My advice...shoot in the highest quality and use a big card.
Oct 09, 2009 | Cameras
Rear projection tv picture quality loss
most of these sets have 3 lens for the three picture tubes inside and also a mirror---if it has never had the lens cleaned they could be dusty and this will diminish the brightness and clarity of your picture---if real dirty the picture will look washed out------most of these sets you can remove the back cover(unplug set first) and gain access to the lens ; clean them with a lens cloth or a paper towel with glass cleaner.
Aug 16, 2009 | Televison & Video
Proview Monitor pic quality diminishing
It sound to me as if the focus on the moniter has changed. If so a couple of possible tihngs might be going on. You could have a dust build up due to the static charge difference the dust and the high voltage potential with in the moniter. If so you can open it up and clean it with an air sorce or vacumn. You might also try adusting the focus adjustment on the back of the moniter. The worst case is that some componet is becoming weak and will fail in the future. Good luck
budman630
May 14, 2008 | Gateway FPD2275W LCD Monitor
Picture taken is so bright and with trasparent horizontal line
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
It's need repair camera machine shutter.
more detail casio ex-s600 overexpourse
Feb 24, 2008 | Casio Exilim EX-S600 Digital Camera
DSC-W80 Pictures Pixel
your lighting may be set different on your camera.for example if you are outside the lighting is different inside.your camera should have amenu where you can change the lighting setting
Feb 12, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Recording
The microphone on most of these slip cameras are very small and it is possible your finger or hand was over it. And to be honest since this microphone is so small the quality is not going to be very good at all. I don't know if there really is a solution to this outside of buying a high end camera if sound quality is so important.
Aug 11, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Power shot A95
It is the setting on your camera ,if you set at (2592x1944) superfine ,you were only can take 11 picture.So if you want to take more pictures ,try set to lower resolution. Below is the setting table: Reso Quality Approx.file size # images on 32MB card Large (2592 x 1944) Superfine 2.4 MB 11 Fine 1.4 MB 21 Normal 695 KB 43 Medium 1 (2048 x 1536) Superfine 1.6 MB 18 Fine 893 KB 33 Normal 445 KB 67 Medium 2 (1600 x 1200) Superfine 1002 KB 30 Fine 558 KB 54 Normal 278 KB 107 Small (640 x 480) Superfine 249 KB 119 Fine 150 KB 195 Normal 84 KB 336
Aug 04, 2007 | Canon PowerShot A95 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
