Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Konica minolta bizhub 250 email problems
We had the machine set up to scan and then email. For some reason now, it will not do it. As usual our service provider said that was not part of our maintenance contract and so I had to pay to send their network expert down. After looking at it he determined my ip provider changed something although I was able to put the printer address in my outlook file and send and receive fine. He said he set it up with his company server and it worked fine and basically said it is not the fault of the machine. I just got an email account set up with our internet provider which is suddenlink and had the same problem. It will not go thru. I have been over all the setting with their network people and apparently everything is set up correctly but it still doesn't work.
  • 167 Answers
What type of error message r u getting?
cannot find server or login error?
Posted on Oct 24, 2008
Konica Minolta bizhub 250 jammed but no paper
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
I get the message "communication error occured" on my bizhub 250
this error usually occurs when the machine fails to make any connection with the computer or any other network, for example to send an email, through smtp, or while scanning using smb, if this message appears without these above mentioned reasons then its "communication board" problem.
Dec 17, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta 250 Bizhub scanning Operations
You need to create a "one-touch"
This can be done in the Admin Screen without having to enter a code.
Better yet is to just yype the IP address into your browser and create them there.
The copier will need an email address in order to send them and you may need to log out and then back into the 250 as an "Admin".
Jul 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 Scanned files
Try using the Comapct PDF option as a file type.
This should be used if file size is a concern.
It applies a mathematical compression so will affect the quality of the scans very little.
Jul 03, 2008 | Konica Minolta bizhub C250 All-In-One...
Cannot Scan To E-Mail
yes, you can, go to brauser and type your bizhub ip aadress, you'll get a webscope page, there log in as administrator and under network choose e-mailt - smtp and there shold be a place where you can mark, that youre smtp server requires authentication.
May 05, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Getting the ip address
To print out machine current ip address, go to utilities, user setting, printer setting, print reports, configuration.
Mar 12, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Cannot scan to email Konica Minolta 250 Bizhub
To scan to email, Administrator email address must be set in the machine (any bogus email address will work too).
Also, email server address must be input as IP address if DNS or WINS is not running in LAN.
Mar 03, 2008 | Konica Minolta bizhub C250 All-In-One...
Bizhub 250 scan to email error
Try re-entering user name and password or try a different user name and password for email account saved in the machine.
Jan 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Scanning a combination of one-sided and two-sided documents
Use the "Separate Scan" button on the panel. By pushing this you are telling the scanner that you have separate scans to scan as one document. Once all files are scanned, push the separate scan button again to indicate you are finished scanning.
Oct 17, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
367 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
