Question about Apple iPod nano 3rd Generation
Ipod Nano can't unlock volume lock
HELP!!! I have tried everything! I can't un lock the volume lock, that appears on screen when I adjust the wheel to the far right/maximum volume. I have tried entering two, different default codes... 1234 & 0000 and still no luck... CAN SOMEONE PLEASE HELP ME? my volume limit can't unlock
I cannot unlock the volume limit settings on my ipod. I have tried default number, and none seem to work.
  • gr8_coolboys Nov 07, 2008
    the ipod is lock and pause
    Sergeant:
  • 196 Answers
On my ipod the volume limit is a software setting in the menu that does not require any kind of passcode so you have me a bit confused as to what you are asking
Posted on Oct 13, 2008
  • 638 Answers
  1. Enable hidden folders.
    In Windows Explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders".
  2. Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked".
  3. Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds.
  4. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Posted on Nov 01, 2008
SOURCE: Ipod Nano can't unlock volume lock
_volumelocked not found on ipod control
Posted on May 27, 2008
  • 6 Answers
From my experience with iPods, the only way to get rid of lock codes that you can't remember is to do a restore on your iPod. This will result in all data being removed from it however. But if you have a backup on your computer of everything you have, then you should be fine. You will have to reload all your music and stuff.
Posted on Jul 11, 2008
mastersaintx
  • 928 Answers
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data."
Posted on Aug 04, 2008
can any one help me because my ipod volume is lock and i am trying to unlock i forgot my code and can anyone show me how to unlock volume on a ipod nano
Posted on Aug 07, 2008
I can't unblock..
Posted on Oct 10, 2008
Volume wont turn up
Resetting the volume limit on your iPod Nano affects everything you listen to, from music to audio books. You can adjust the volume for each individual item on your Nano using the click wheel, but the highs and lows of the sound will depend on the overall volume limit setting. Volume levels will vary with different ear buds and headphones, and using external devices like docking stations to play your iPod Nano will also cause variation in the volume.
Instruction:
1 Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu.
2 Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button.
Select "Playback" from the menu choices that show up.
4 Select "Volume Limits." You will reach a screen with a speaker icon and dots indicating the level of volume your iPod is currently set on.
5
Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Goodluck
Dec 10, 2011 | Apple iPod nano
Volume wont turn up on my mp3 - volume too low
How to Reset the Volume Limit on the iPod Nano
Instructions
3 Select "Playback" from the menu choices that show up.
5 Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Tips & Warnings
If you set up a combination and forget it, you can reset your iPod Nano and start over again. Resetting will not lose any of your downloads, but you will need to restore or reset many of the settings you initially chose when you first set up your iPod.
Changing the volume limits on your iPod Nano covers everything on your player, but the sound levels for songs, audio books and shows will vary based on how they were recorded.
I assume your music is stored safely in iTunes on your computer? If so, just do a Restore on the iPod through iTunes to reset your iPod to the factory defaults. You will have to copy your music back, but the lock will be removed.
If your music is not saved on a computer, use software such as ephPod to get the music off - then do a Restore. (see: http://www.engadget.com/2004/11/02/how-to-get-music-off-your-ipod/)
Good luck.
Jan 03, 2009 | Apple iPod nano
Sounds like you need a New ON/Off switch which is connected to the headPhone Jack. We can definetly do this for you. Please give us a call to set up a Repair at 661-619-5928 or Email us at sales@ipodrepairz.com
We look foward to your Business and also repairing your iPOD
Thanks Again
ipodrepairz
Also check us out on Ebay.com under ipodrepairz
Sep 19, 2008 | Apple iPod nano 2nd Generation MP3 Player
Hey,
see this tip I have posted few months ago
http://www.fixya.com/support/r538899-unlock_ipod_volume_control
that should solve it
Let me know how it goes.
Thanks,
Ekse
Aug 14, 2008 | Apple iPod nano
Aug 03, 2008 | Apple iPod nano
Jul 11, 2008 | Apple iPod MA446LL/A MP3 Player
Heres how
Remember to rate my solution as fixya, becouse I know this will fix your problem as it has for many others before you!
May 16, 2008 | Apple iPod nano
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
If that doesn't work, try a restore. This will return it go factory settings.
How to restore iPod
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Jan 01, 2008 | Apple iPod nano
Apple iPod nano 3rd Generation Logo
177 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
