Whirlpool Cabrio  WTW6600SBT Top Load Washer
Problem for Whirlpool Cabrio WTW6600SBT Top Load Washer
Cabrio Washer LD error code
By kimosabie on Oct 13, 2008
I have a Cabrio washer and have been getting LD error. I took the pump out and the water came gushing out , the hose is free and clear so there are no plugs, but when I have it drain and rince, the hose jerks once but no water comes out, then the LD error comes back.
kabrosta@rockwellcollins.com
Same Problem
May 16, 2009
-   I have the same problem I hate this washer-   Guest
Apr 20, 2009
-   The LD error wont finish the rinse cycle and spin -   paulac59
Apr 20, 2009
-   My machine washes one load usually with out problems...then I am out of luck, because the ld light comes on and I am stuck ! Sometimes, after waiting a while, the rinse & drain cycle will work. Other days I have to unload tne wet laundry and finish at my neighbors. My husband took the enite machine loose trying to fix the problem, but to no avail... -   bknewmoon
Jan 04, 2009
-   My Cabrio gets ld and I have to cancel and start the wash several times and then it works. How do we fix this probelm once and for all.-   abbyaaaa
Nov 29, 2008
-   My cabrio started this today, the LD code. It will not do anything. It won't drain, spin...nothing. I'm a little upset about this.
-   insulator97
Best Solution
posted on Oct 17, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
same problem here
Solution #2
posted on Apr 05, 2009
Very Helpful)
comseven
Rank: Apprentice
Rating: 97%, 9 votes
Is there water in the bottom of the tub? If yes then open back of washer and remove drain pump (on left side) and pull off of tub and clear whatever is blocking its impeller.
If the water is all gone and drained but pump stays on for several minutes and then gives "LD" fault then open back and check the small clear tube that is attached to the tub. Make sure is not blocked with debris and check tube and tub for anything that could block the small clear tube. If these are ok then remove 3 screws in back of the control panel, pull open control panel and check the clear tub all the way up from the tub to the washer controller board (computer) make sure it is not kinked or disconnected. If not then the problem is most likely the pressure sensor on the (computer). This unit will have to be replaced.
You can test the sensor by doing the following: 1. When the "LD" fault comes on start by pressing the pause button. then pull the clear tube off of the computer board. Then attach a tight fitting drinking straw over the sensor. Press the start button and wait for 60 seconds - If the washer does not start the spin cycle on its own after the 60 seconds then **** on the drinking straw that you attached to the pressure sensor earlier. The sucking action should reset the sensor thus telling the computer that the water is drained and it will start the spin cycle. Just remember if you have to do this to get the washer to spin - that means the sensor is damaged most likely from moisture traveling up the tube over time. The computer board will need to be replaced. I believe it costs $205 without shipping. Hope this helps.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #3
posted on Jan 24, 2009
Very Helpful)
abbyaaaa
Rank: Apprentice
Rating: 100%, 2 votes
It appears that the pressure switch that monitors the water level is not working correctly. So I called Whirlpool and had them send me a new controller board. I replaced it and the machine works GREAT!
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Oct 16, 2009
Somewhat Helpful)
acptexas
Rank: Apprentice
Rating: 75%, 1 votes
I had to call a repair service a couple of months ago due to error code. When washer was ready to spin it stopped. They had to replace the brain of the washer. Cost me over $400.00 bucks. That was the second time it broke. The first time it wouldn't drain. Drain pump was replaced. Now it got an error code again today. I just sat and paused and started about 20 times and it finally finished my load. Will call repair on Monday. This is the worst washer (Cabrio top loader) I have ever purchased in my life. My moms 300.00 dollar roper from Lowes works better. The dry ...no problems yet (knock on wood) If yours wont drain or spin get ready to spend some cash for the repair. I always though Whirlpool was a dependable brand. Never again will I purchase them again.
Was this helpful?
Yes
No
Solution #5
posted on Nov 10, 2009
Not Rated)
lilroosma
Rank: Apprentice
Rating: 0%, 0 votes
LD code.Took mine apart, found a hair pin stuck in the propeller of the water pump.Removed it and a big lint ball, works great!
Was this helpful?
Yes
No
Solution #6
posted on Oct 15, 2009
Not Rated)
bknewmoon
Rank: Apprentice
Rating: 0%, 0 votes
bknewmoon's problem was finally fixed when the control board, the brain, on my cabrio washer was replaced. now it's as good as new
Was this helpful?
Yes
No
Solution #7
Not Rated)
chrystalrowl
Rank: Apprentice
Rating: 0%, 0 votes
i fix my ld problem by just taking the hose and blowing in it no joke!!! it unclogged and even sucks better!!
Was this helpful?
Yes
No
Solution #8
Not Rated)
Tridewebsr
Rank: Guru
Rating: 86%, 55 votes
if there is no blockage replace the pump
Was this helpful?
Yes
No
Popular Solutions for Whirlpool Cabrio WTW6600SBT
Questions and Unsolved Problems for Whirlpool Cabrio WTW6600SBT
Do you recommend Whirlpool Cabrio WTW6600SBT Top Load Washer?
Answer
Answer
What does HC stand for on the CABRIO WASHING MACHINE by Whirlpool. It comes on at the end of every... (More)
Answer
Went thru it's wash & rinse cycles but then the load (3 T-shirts) became unbalanced... (More)
Answer
The washing machine does not drain / spin...water sitting in the bowl
Answer
My washer stops at either 20 mins or 8 mins. The first load always goes good and after that... (More)
10 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Oct 30, 2008
I have a cabrio washer and after starting it I also get the dl and just flashing lights. I would not recommend this washer
Comment by billyo44, posted on Oct 30, 2008
the LD light comes on when washers on.all my drains and lines are clear.washer quits and starts peeping
Comment by soccer860, posted on Oct 28, 2008
I get the LD error intermittently during wash cycles. The pump is clear as well as the drain tube. I can unplug the power for a few minutes and then rinse/spin or drain/spin and it will drain perfectly. It may or may not work fine the next wash, but the problem will return.
Comment by Guest, posted on Oct 19, 2008
We had an authorized worpool repair man look at our machine. He told my wife that he could not repair the problem until we started using higrade washing detergent. We currently use ultra Tide. I thought Tide was good soap????? Whay kind of soap should I be using????????
will not spin gaves a ld error
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
