Question about Canon i350 InkJet Printer
Nicolone I did change both ink, reset counters and try clean the head,but all fail.Thank you for help. If you have more solution i will be so greatfull
    Genius:
  • 2,035 Answers
Try to change the printer head unit in the printer as it may be defective ..............
Posted on Oct 13, 2008
My printer epson me 300series is showing service required"as printer is end of its life" ,what does it mean?
Inkjet printers have a thing called Waste Ink Absorber. It's a box with a felt pad that absorbs the ink "spat" out of the printing heads during head cleaning, both manually initiated and automatic cleaning run by the printer itself.
The printer has a counter that counts the number of times cleaning has run, thus preventing the absorber from overflowing with waste ink and spilling it onto whatever the printer is standing on.
This message therefore means, that the counter has reached it's maximum and demands replacement of the absorber. On wide-format, professional Epson printers the ink absorber is a user-replaceable consumable. In cheap home printers it's built in and can be replaced and the counter reset only by a service person, which in turn is usually not very feasible; it may be cheaper to purchase a new printer.
However, if you are an adventurous type, here's a tip. The counter is usually quite conservative, and the absorber can take much more ink than the counter would allow. There are methods to reset the counter in some Epson printers; consult this page to find a solution that may work for you:
http://www.fixyourownprinter.com/search/forums?q=epson+waste+ink&f=&u=&d1=mm%2Fdd%2Fyy&d2=mm%2Fdd%2Fyy&Disp=10
Please come back and rate the solution if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 24, 2011 | Office Equipment & Supplies
How to reset ink level canon iP 2772??
Download and run the ipTool to reset your ink level :
http://www.mediafire.com/?nmj5nnzzjaw
Features IP Tool software:
  • Showing all info on the printer such as ink level, ink counter number of cleaning, cartridge replacement and more.
  • Print test feature to test nozzle on the cartridge.
  • Cleaning and deep cleaning feature to clean head cartridge and cleaning the rollers.
  • Changing the delay value for drying.
  • Set the printer model manually.
  • Reading and reset EEPROM printer.
  • Reset counter and reset ink level on the color and black cartridges.
Ink Level - shows the level ink:
  • BK - black cartridge.
  • CY - Cyan cartridge.
  • MG - Magenta cartridge.
  • YL - Yellow cartridge.
  • WM - Waste ink counter status.
  • WP - "additional" waste ink counter status.
Port Name - displays the port where the printer installed.
Port S / N - shows the serial number of the printer port.
Power - shows the number of:
  • ON - inclusions printer.
  • OFF - to turn off the printer.
Cartridge Info - Displays information status of:
  • CL - colored cartridge.
Head Parking - displays the number of parking.
Head Cleaning - shows the number how many time the cartridge cleaned.
Head Deep Cleaning - displays the number of deep cleaning Printer cartridge.
Cartridge Replacement - shows the number of cartridge replacements:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 20, 2010 | Office Equipment & Supplies
Both the red and green light are on and blinking.What is wrong with my Epson C60?
kiryakitsa1 You should download the SSC Service Utility as pineworks says. Read the instructions and warnings. Go to Reset counter protection and press reset. You may recieve a warning about replacing your waste ink pads. I have always reset the protection counter without replacing the waste ink pads and I have never had a problem. If you see ink drainage then you should replace the waste ink pads and then reset the protection counter. I have never had a problem with ink heads and I have done this many times.
Feb 07, 2010 | Epson Stylus C60 InkJet Printer
Mp160
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly.
1. try to take out colour ink and then put in again to see ok or no
2.try to install new cartridge to see ok or no
3.try cleaning head just go to printer preferences go to find services and click clean head.
4.if this all can't is better you send you printer to authorized canon to check you printer is print head problem or no....
Error E5 means a problem with cartridge chipset, here follows reset procedure, it does not always work:
Error E5 is a problem with cartridge ink counter. This happens when you use refilled or not original crtridges.
Try removing cartridges and putting them back in place.
Here is the whole service procedure for Pixma, you must use this to reset the ink counter:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If it does not work you will need to buy a new set of cartridges, possibly original ones. If you just bought cartridges tell the seller they are faulty and ask an original set of cartridges as replacement
Sep 06, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink absorber full
Hi ....
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Do vote if this helps ... Cheers :)
Dec 20, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson R230 ink & Paper Lamp Blinking
my epson stylus photo R230 Printer problems always
two red light blinking
please help me
thank you
Sep 29, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson cx2900 3 in 1 printer
the problem might be the ink, change the cartridge maybe the ink dried out....
Sep 05, 2007 | Epson Stylus C84 InkJet Printer
Ink & Paper blink red at the same time
I managed to solve the problem, thanks to this fantastic freeware tool: http://www.ssclg.com/epsone.shtml The problem has to do with the porous inkpads which are expected to overflow after a fixed number of nozzle cleaning cycles. However the problem is a software, not a hardware one. This great tool resets countes as well as ink cartridge chips. Thank you very much FixYa all the same for trying. Too bad there are some lunatics who post unrelated topics to this forum. Kind regards, PM
Dec 10, 2006 | Epson C64 InkJet Printer
Canon i350 InkJet Printer Logo
35 people viewed this question
old marine
old marine
