Question about Yamaha DVR-S200 DVD Player
Dvr-200 cinema station shutting down
Read your thread about auto shutting down was very interesting please can you advise i have one of these units that develope this problem this morning but before that has been fine i removed all of the speaker cables and still showed the problem but used your method of plugging headphones in and it has worked should i try the refridgerator method as one i remove headphones turns off instantly also one more point the speakers you say check the + - poluritys are the same surely they must of been the same to be working before but will do anything to try and sort this out does sound like an audio output fault thou as your headphone method got my dvd out and works everytime you plug them in any help richard from torquay uk email richerrich12345@aol.com thanks in advance for any help you can give
3 Suggested Answers
Falling Down
  • 67 Answers
SOURCE: Auto shut down of unit
the audio amps may be overheating and shutting down. a lot of electronic devices don't receive heat sink compound when being assembled and the heat doesn't transfer as it should. Try cooling the unit either in a plastic bag in the refrigerator or placing it in a cool airstream directed at the rear of the unit. If it's in a stack of other electronic devices, place something between the units to allow air to circulate. I hot-melt glue tinkertoy wheels to the bottom of the units myself to separate them.
Posted on Nov 30, 2007
  • 66 Answers
SOURCE: Yamaha DVR C300
check all the wires and replace them if so needed, i would just replace the speaker wire with the good stuff from the radio shack and if it is not that then it could be a loose wire in the sub and or speakers
Posted on Jun 28, 2009
LG blue ray home cinema fault error reads: open,reading,error,open,close.
If this is the DVD withing the unit, try playing a CD. If that works, most likely, the Optical Pickup(laser) in your unit has worn out. These are two lasers in your Optical Pickup, as the wavelength of light between the DVD and CD, so although your DVD doesn't work, the CD may.
If you are interested in having your LG repaired, please look to my website at audioserviceclinic.com. Thank you.
Mar 12, 2015 | LG Audio Players & Recorders
How do I run channel auto scan
Press MENU, use left/right buttons to get to input, then select AUTOSCAN using up/down keys and SELECT/ENTER button. This will take a while, 3-5 minutes. When it finishes, it will default to channel 2. At t.his point, push LIST button to see all stations it found.UP/DOWN buttons will let you select station of interest.
Dec 20, 2013 | ViewSonic N1630W 16 in. LCD TV
I hvea 42 plasma tv. I have bought a cinema
Please checked Sound System with your remote menu it should be B/G,D/K,I,M which is not proper.
Dec 08, 2009 | LG 42LC2D 42 in. LCD HDTV
After couple of hours unit shut itself down please help
in the manual it says the DVR will shut down after 3 hours of inactivity . The DVR should put up a message to " press enter " to reset .
hope , it helps .
Jan 20, 2009 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Dvr docking station
I had the problem that the record feature was not available in or out of the docking station and therefore i could not record. Archos connector on bottom of unit senses a change in the resistance of the device it's docked with and knows if it's the DVR station or not.
Turned out to be a hardware fault - i had to RMA both the Archos and the docking station (while in warranty) and Archos fixed it/them.
That may not help you much.
PS: I think i zapped my DVR station with static one day and that might have been the original cause.
Dec 31, 2008 | Archos 604 WiFi Digital Media Player
Zone code for Yamaha DVR-S150 Cinema Station...
Most of these units are made for regional use only. Contact Yamaha.
Dec 21, 2007 | Yamaha DVR-S150 DVD Player
Nov 24, 2007 | Yamaha DVR-S200 DVD Player
Archos 604 not recognizing DVR Station
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
Oct 29, 2007 | Archos 604 Digital Media Player
Yamaha DVR-S200 DVD Player Logo
48 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
