Roper RAL6245AW0 Washer Won't Drain or Spin
My mother-in-law's Roper RAL6245AW0 washing machine quit draining or spinning. We bailed out most of the water and made sure the hoses were not blocked.
The washer fills and agitates fine, but it won't spin or drain on the rinse cycles. There are no noises of any kind (other than the timer motor), and the motor isn't even trying to turn.
The lid switch appears to be working fine, as it disables the agitation if we open the lid. (The wiring diagram on the washer is kind of hard to read, but it appears the lid switch on this model turns off everything, including the timer.) From what I could make out on the diagram, it appears to be a single pole switch, if true verifies it is working correctly.
I didn't see any belts on this model, it appears the motor attaches directly to the transmission and the pump attaches to the other end of the motor.
I tried all of the available cycles and none of the cycles will spin.
I'm guessing the timer is bad, though it seems odd the spin setting of all cycles would fail at once? And the timer is an expensive part to replace just on a "guess".
Any ideas?
  • dandanmaytag May 22, 2009
    My neighbors is doing the same thing. I took apart the control panel and found that the contacts on the timer had fried. i just need to find the replacement part now. hopefully before they get back in town :)
We have a Kelvinator Washing Machine that just won't drain , but fills , agitates , & spins just fine. What shall we do?
Posted on Aug 29, 2009
My roper RAX4232KQO washers but won't drain. What could be causing this?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Aug 27, 2011 | Roper RAX4232KQ Top Load Washer
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Washer does not drain and spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
May 20, 2010 | Roper RAX4232KQ Top Load Washer
Agitater spins around, water won't drain.
The model number is located under the lid.
Nov 17, 2008 | Roper RAS8445KQ Top Load Washer
Roper washing machine
does it spin? drain pump is directly mounted on motor, works in spin. may need new pump. Whirlpool standard pump.
Jun 03, 2008 | Roper RAS8445KQ Top Load Washer
Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
Washer won't drain
Mustache, sounds like you have a broken lid switch. No spin, no drain usually a sign of this. Check to see if the actuator is making the lid switch, or the switch itself is bad. Part number for the switch is 8318084. Catriver, post back.
Jul 30, 2006 | Roper RAX4233PQ Top Load Washer
Washing Machines Logo
487 people viewed this question
Top Washing Machines Experts
