Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
KitchenAid KP2671 - Spaghetti cutters stopped turning. Makes loud noise.
My KitchenAid KP2671 attachments - Spaghetti cutters and pasta sheet roller will no longer turn. The unit makes a loud noise. Has this been a common problem with KitchenAid KP2671.
  • mikesureda Oct 13, 2008
    Just a note: The mixer runs fine. However, the attachments no longer turn via the hub socket.
  • 905 Answers
This is common for any device that has a motor,either the gears are grinding or the motors contact brushes need replacing, it will have to be looked at to determine the exact cause
Posted on Oct 13, 2008
  • jason Oct 14, 2008
    then the motor is not grabing the spinng gear and grinding instead
My Kitchenaid mdl: KSM 155gbca is making a loud bumping noise with or without an attachment.
It is more than likely in the planetary or the fuse gear inside the gear box. Try it once you have the planetary off before you go looking inside the gear box. Easiest is planetary problem but far far more likely is the fuse gear.
Aug 08, 2014 | KitchenAid Artisan Series Tilt-Head Stand...
Broken input shaft
KitchenAid doesn't sell any internal parts for the KitchenAid pasta attachments, the only thing to do is buy a replacement, if it is just the pasta roller you can purchase the KPSA, if not the others are just sold in the KPRA pack
Mar 07, 2014 | KitchenAid Kitchen Aid KPRA Pasta Sheet...
Brass shearing pin
All of the KitchenAid pasta attachments are considered non-serviceable. There are not any parts available. You only option would be to buy a new pasta roller. KitchenAid has recently made the roller available by itself so you do not have to purchase it in a whole pack.
We carry the pasta roller, here is a link to the item on our website:http://www.mendingshed.com/kpsa.html
Thank you,
ColleenCustomer ServiceMendingShed.com800-339-9297
Apr 12, 2013 | KitchenAid Food Mixers
Kitchen aid pasta roller is locking up
You will need to follow your nose and carefully dismantle it to see where the fault is. As far as I am aware Kitchen Aid supply no parts for this accessory, it comes as a complete unit only.
Mar 24, 2013 | KitchenAid Pasta Roller Attachment
Kitchenaid Professional HP mixer, motor stopped while making dough. I let everything cool down and with no attachments it will not turn on. As soon as you turn it on the motor gets hot but no noise or...
Open the Transmission Housing and remove the two screws holding
the Motor. Lift it off the gears and test run it by itself. The motor
should run normally at different speeds. If it does, then you can move on
to the gears. Manually turn the Worm Gear and make sure nothing got jammed.
The Bevel Gear should turn smoothly.
Jul 18, 2011 | KitchenAid KP2671 Professional 6 Series...
Mixer makes a clicking noise and beater stops turning or mixing...gear seems to be slipping...
The only part that consistently wears out is the Worm Gear Follower located inside the Transmission housing. The teeth are wearing out and becoming chipped. The clicking noises you hear are made by the Worm Gear banging on the Follower. All the teeth of the Follower are now damaged and the Planetary stops rotating.
Removal and replacing of the Worm Gear Follower is no easy task. Let me know if you need help.
(Do not try to remove the Planetary assembly by forcing it with a screwdriver. That is not how it's done.)
Jan 23, 2011 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid mixer makes a lot of noise. The beater
Hi - I've been searching for general info on KitchenAid stand mixers and ran across this so I'm throwing my $.02 in... Since KA stand mixer bases are essentially made of cast metal parts, there is a very slim chance that there is a lateral misalignment (side-side) unless it got dropped...eek! Sounds like a head height adjustment issue. Check out this from KitchenAid Conversations:
http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=3032
Good luck.
DZII
Jan 02, 2010 | KitchenAid KP2671 Professional 6 Series...
Clicking noice in gears
A clicking noise is not indicative of a major motor issue with a Kitchenaid stand mixer. If the noise worsens or is accompanied with other symptoms, or if you are incredibly concerned with the development of clicking, I would suggest contacting Kitchenaid Customer Service.
Their toll-free telephone number is 1-800-541-6390.
Apr 04, 2009 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid pro 5 --dreadful noise; filings
the company jumped right in and helped me out. impressive.
Sep 08, 2008 | KitchenAid KP2671 Professional 6 Series...
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
356 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
