Question about Broan-NuTone Allure III QS330SS Kitchen Hood
Fan and lights come on and go off all day long on their own
Everything was working fine but all of a sudden the fan started coming 'on" on its own and runs and then shuts off on its own and this keeps happening continuously. The lights will do the same but not as often. They "blink" rather than staying on. When the fan comes on and runs I am not able to turn it off. It has a mind of its own. This has never happened before and started for no apparent reason.
  • 1 more comment
  • Anonymous Oct 24, 2008
    I have the same probleme
  • Greg
    Greg Dec 23, 2008
    Exactly the same problem. Nutone Allure WS2 model. Was hoping fuse replacement might help?
  • Glenda Fay Harris
    Glenda Fay Harris Feb 06, 2014
    that is my problem it blinks all the time for the blower
We installed our Broan-Allure range hood about ten years ago. On three seperate occasions since, the fan has randomly turned on and none of the control buttons would turn it off. After a while it turns itself off. During those same times, when you turned the lights on, they would blink before finally staying on. On each occasion, I have removed the screens and metal underpieces to gain access to the circut board. Once you can see the circut board, remove and replace the 3 Amp fuse that is mounted on the board. (Radio Shack part # 270-1054)...even if the fuse looks good, replace it. Each time this has work for about three years, then it acts up again..
Posted on Aug 31, 2010
  • Janelle Schneider (painbetty e)
    We may have a different model (Braun allure) but I dont see how to remove anything to access a circuit board?
  • 38 Answers
Its definetly the electronic control board. I've repaired plenty.
Part # R111632
Price: $110.00
1-800-363-0566 Inventex Inc
Posted on Nov 06, 2008
Ceiling fan light delay
How do you change the speeds? Pull chain ,dual control on wall or remote.
Sep 15, 2013 | Hampton Bay Dryers
Make buzz noise & fan comes on
1) Tes the voltage tension from you outlet wallet.
2) if the voltage is low from 10% , you must use stabilizer voltage.
3) If everything is o.k , you need to lube the fan motor, and tight the connectors
May 08, 2012 | Microsoft Metrologic MS7120 ORBIT Barcode...
It is a Bryant Legacy AC unit. Model #123RNA060-B. It has been running fine, now it has suddenly shut down. The interior fan is working, but the fan at the compressor shuts down. It will work fine for...
I had a unit do the same thing to me, everytime I would leave, it would stop working again. I had a bad fan motor that would spin fine and work for a little while, but would shut down. It was the motor windings that would overheat and shut off, as soon as they cooled, it would start back up. One way to check is to feel the top of the unit where the base of the fan mounts and see how hot it is, best to check while it's not working how it should, but try not to run it very long or you could damage the compressor. Hope this helps!
Jun 27, 2011 | Bryant Heating & Cooling
My unit has been running great up till now. Just
Check compressor for high current consumption.Check capacitors. Check fan speed.
If fan speed is low compressor will over heat and trip safety circuit in the compressor. If there are independent fans check both of them.
May 26, 2010 | Mitsubishi MS-A12WA Air Conditioner
A/C FAN MOTOR SHUT OFF, BUT CONDENSER KEEP ON RUNNING
The condenser fan might be going out. It'll start when cool but shuts off as soon as it starts to warm up.
Jun 28, 2009 | Heating & Cooling
Broan-NuTone Allure III QS330SS Kitchen Hood Logo
1,313 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
