Question about Fuji Cameras
Suddenly the optical zoom stopped working. The digital zoom continues to work as does all aspects of the camera. No warning or alerts are displayed.. This is the Fuji S700 model
  • 1,879 Answers
Remove battery and use canned air to clean
Posted on Oct 13, 2008
  • 535 Answers
U have to your nearest service center of camera
    Genius:
  • 1,550 Answers
Lens error right . It is mechanical failure some thing is obstructing the movement of lens . With blower blow to remove dust particle blocking the movement of lens .
Hope this helps to solve the problem .
The camera turns on and immediately turns off. no warning signs!! just stopped working. is there any way i could format it or send it in somewhere? its practically brand new!!
It sounds like depleted batteries. If you've replaced the batteries, then you may want to pursue warranty replacement. A high Mega-Pixel camera like yours will drain batteries quickly.
Feb 01, 2010 | Kodak Easyshare M341 12.2MP Digital Camera...
Setting the ''digital Zoom''
The digital zoom works fine on mine. It sounds like your have encountered a couple of defective models.
However, even once you get the digital zoom to work, it gets really grainy, so I don't use it.
Nov 30, 2008 | Video Cameras
Optical zoom problem in movie mode
Your camera is not broken. That's by design. Canon cameras do not allow optical zoom use while in movie mode. Canon claims that using the optical zoom in movie mode would cause excessive noise in the movie. However, you can use digital zoom in movie mode. You'll need to go into the menus (press the menu button) and turn digital zoom "on" if it's currently off.
Oct 11, 2008 | Canon PowerShot SX100 IS Digital Camera
Digital Zoom Stopped Working
first of all why do you want to use digital zoom? it distorts your pictures! but if you insist, check the settings because it is possible to turn digital zoom off
Dec 25, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Digital zoom not working
Digital zoom is in the menu and must be turned on to activate it. When you use the zoom it takes 2 opperations to function. First opperation is to zoom all the way in then the camera should stop. This is the limit of the optical zoom. Then you let off the zoom button, and hit it again and then the digital zoom will start. Digital zoom is just a gimic if you learn how it works its not doing anything different then you can do in photoshop. All digital zoom is doing is like cropping.
Apr 24, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Optical / Digital Zoom
Press the "T" for telephoto and get closer to the subject. Optical telephoto zoom is like using a telescope to get closer to the subject before taking the picture. With optical Telephoto zoom you can maintain the full resolution and quality. After you have used all of the optical Telephoto range, the camera will continue to enhance the image with Digital Zoom. This enhances the image inside the camera by reducing the resolution and expanding fewer pixels to fill the same image space. Use the "W" Wide-angle button to back-up away from the subject or get a bigger area into your picture. You can even ZOOM IN on a picture in the playback mode for a better look at the details. Touch the Magnifying Glass Icon. Use the Arrow Keys to move around the display area.
Sep 11, 2005 | Toshiba Sora PDR-T20 Digital Camera
Press the "T" for telephoto and get closer to the subject. Optical telephoto zoom is like using a telescope to get closer to the subject before taking the picture. With optical Telephoto zoom you can maintain the full resolution and quality. After you have used all of the optical Telephoto range, the camera will continue to enhance the image with Digital Zoom. This enhances the image inside the camera by reducing the resolution and expanding fewer pixels to fill the same image space. Use the "W" Wide-angle button to back-up away from the subject or get a bigger area into your picture. You can even ZOOM IN on a picture in the playback mode for a better look at the details. Turn the Mode Dial to Playback, then press the "T". Use the Enter button to move around the display area. Press the middle of the ENTER KEY to see your images in thumbnail view and / or scroll through several images at one time to find a specific / special image quickly.
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Differences between Optical Zoom and Digital Zoom
When you change the focal length of a zoom lens, the subject is magnified. Optical zoom replicates the zoom of a 35mm camera. Digital zoom takes a portion of the image's data and displays it at full size, producing a magnification of the original image, similar to the effect of using a telephoto lens. However, the process is different from the magnification produced using the camera's optical zoom, and the stronger the digital zoom, the more the image will degrade.
Aug 30, 2005 | Panasonic Lumix DMC-F1S / DMC-F1K Digital...
Cameras Logo
96 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
