Question about Konica Minolta DiMAGE X50 Digital Camera
Dimage x50 - once turned on, will continue to take pictures every second.
I have a Dimage x50 and love the camera. I downloaded pics off of it yesterday and so the card is empty. I went to take pictures this morning and it went all by itself. It just kept taking pictures about every second. I turned it off and on again and even took the battery out and put that back. It didn't help. Is there something I can do to fix the problem? Thank you so much for your help.
Crumbs
SOURCE: Konica-Minolta Dimage Z2 can't turn on
Well, I also bought the DiMAGE Z2, and my problem was similar: It worked for some time, but then it started freezing sometimes, not responding to any button I pressed. One time, it froze, shut off, and I wasn't able to power it up again. In short, the camera was still under its warranty, so I gave it to their lab and they fixed the problem.
Posted on May 19, 2006
  • 3 Answers
SOURCE: My Dimage Z6 does not allow me to check the pictures taken.
i have the same problem. Did you get any answers? Thanks
Posted on May 21, 2008
Richie_asg1
  • 1036 Answers
SOURCE: dimage x50 konica minolta digital camera
If the LCD was physically cracked or broken, then yes you should be able to swap it for an undamaged one.
The cheapest option for you is to advertise or look on Ebay for an identical model - also with faults, but with an undamaged display. (maybe dropped - sold as not working)
See HERE - this is just like yours - but also has the cracked LCD. You need to search for one with a good display.
Take this "donor" apart first to see how it's assembled, then just swap the parts.
This method of repair is common for consumer electronics.
Thanks for using Fixya!. If this has provided a solution, plrease rate as such. Thanks.
Posted on Jul 03, 2008
SOURCE: Konica minolta Dimage x50 doesn't work
Buy the AC adapter plug the camera in without any battery, if it works then its the battery,if not its the camera.
Posted on Nov 18, 2008
SOURCE: Dimage E323 "system error"
remove 6 phillipscews open camera.There is a little drivemotor for the lens,next to it is a shaft activating the limit switch for lens opening and closing.Carefully spray plastic safe electronic cleaner into the opening.Now apply 3 volt to the motor reversing polarity a few times to activate the limits. Now use canned air to blow out any residue of the cleaner.This worked for me,camera working again.
Posted on Jan 03, 2009
Blurred pictures on dimage x 50... Re formated memory card and managed to get 1 print then the problem returned ...re- formated again solved nothing Help i love this camera
When taking a picture, first hold the button to allow the camera to focus then take te picture by depressing the button completly. It worked for me.
Sep 20, 2008 | Konica Minolta DiMAGE X50 Digital Camera
Jun 10, 2008 | Konica Minolta DiMAGE X50 Digital Camera
DImage G500 Grainy Pics
try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 21, 2008 | Konica Minolta DiMAGE G500 Digital Camera
Konica minolta dimange x50 problem..
Please advise, my dimage x50 wont focus clearly pictures are blurred is there a way to correct this?
Apr 02, 2008 | Konica Minolta DiMAGE X50 Digital Camera
PC does not recognize USB/camera plug-in
i just got a new camera the dimagne x50
and i brang it out today and it was working fine it didnt drop or anything
i took a picture then turned it off then i turned it on agian and when it was on the camera format the light kept on blinking yellow for the longest time and wouldnt let me take a picture so i tried the video format and it worked so im just wondering why the video format is working and not the camera ?
has this happened to you? is there any way of fixing it?
Dec 06, 2007 | Konica Minolta DiMAGE X50 Digital Camera
Software issue
You should be able to connect with a USB cable The male end may not be standard size, so you may need to locate a cable.
Once you connect the Computer will try to load your images or it will treat your Camera as another hard drive from which you can copy onto your existing system. To the process your photo just buy some image software, if your system try to open file but won't diplay image. Most printer (Ex: HP come with image software).
Nov 28, 2007 | Konica Minolta DiMAGE X50 Digital Camera
Camera only takes pics without flash
Same thing happened to me. Agreee with your conclusion. Hope someone can confirm, especially who/cost of repair. Thanks, tj
Dec 19, 2006 | Konica Minolta DiMAGE X50 Digital Camera
White Screen
Did you find a solution for this? I'm trying to find which LCD would work on this same camera.
Jul 26, 2006 | Konica Minolta DiMAGE X50 Digital Camera
Digital minolta konica x50
You are going to need proffisional technical help in order to fix it - probably the screen will have to be replaced. :( Good Luck
Apr 30, 2006 | Konica Minolta DiMAGE X50 Digital Camera
Konica Minolta DiMAGE X50 Digital Camera Logo
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
