Question about Ricoh Office Equipment & Supplies
Functional Problem with RICOH Copier Error No-SC:541
  • 38 Answers
SOURCE: Functional Problem with RICOH Copier Error No-SC:541
Posted on Oct 22, 2008
  • 1555 Answers
SOURCE: Functional problem with the copier error
  • 1Press the "Clear Modes" button. This button will be on the main panel of the Ricoh copier.
  • 2Press the "1,0,7" keys in succession. You do not have to hold the buttons down at the same time but need to press and release them in this exact order.
  • 3Press and hold the "Stop" key. You will need to hold this button down until the Ricoh copier enters into service mode. The touch screen display will read "service mode" and three soft keys will appear.
  • 4Press the "exit" button. This button will be on the touch screen display in the upper right hand corner. Once pressed, the copier will return to normal operation mode.
  • 5Turn off the main power. The main power button will be located on the side or front of the copier, depending on which Ricoh model you are working on.
  • 6Turn the power back on. Once the copier is powered back up, the service code will be cleared.
  • Posted on Jan 30, 2011
    Daniel S
    • 4323 Answers
    SOURCE: We have service call sc548
    Sc548 is a fusing unit installation error which indicates that the unit is unable to detect the fusing unit when the front or right covers are closed. The issue is that either the fusing unit is not installed correctly or the connection to the fusing unit is bad. You have to check the sensor on the left side of the copier as these 2 sensors gets knocked and moved of position. You can try to reset it this ways:--- Enter SP 5810 (SC code reset), select "Execute", select "close", exit SP mode then turn main power switch off and on. To enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # select execute then power off and back on. Hope this helps...please post back for further assistance.
    Posted on Jul 26, 2011
    • 263 Answers
    SOURCE: Ricoh Affcios 3025 Functional problem with copier
    This code is related to a Fusing temperature error.
    You probably need to change Hot roller (or fusing roller), Pressure Roller and both thermistors.
    You can reset this code but it will pop-up again sooner or later.
    The best advise i can give you is to call a technician (if you do not have technical knowledge)
    If you still want to reset the code try this:
    Press yellow key
    Press in the key pad 107
    Press red key at least 5 sec.
    Press "copy SP"
    On the key pas press 5810 and #.
    On the touch panel press "execute"
    Exit all the way out.
    Turn the machine off and on.
    Hope this helps you
    Posted on Aug 04, 2011
    • 31 Answers
    SOURCE: functional problem with ricoh copier error no SC-541.Aboveis the main problem with ricoh copier no anyother key can be used. so if sir could share to me i will be gratful.BIBIN.
    Errors starting with 54x are anomalies found in fusion unit. You can start to reset the code but sooner or later it will jump again.
    after remove the fusing unit, you will want to check:
    _Thermistors- GENTLY! remove dry toner over it, or, better, replace it
    - Thermal fuse-check continuity
    _Fuser heater.Check continuity
    -lose connections (it happens some times), check continuity
    -the quality of fuser (upper) roller, as scratchs in the teflon are prone to get toner sticked and get the thermistor dirty( mind the copy quality and damaged scrappers)
    After all that, switch the machine on, press in sucession yellow button, 1 0 7 and hold on for some secs the red button (stop)
    You will get service mode
    enter it and exit it. you dont need to go further, as the machine already assumed you are a tech, and changing other values may be tricky. Switch the machine off and on again. you have reseted the code! If not, do all the procedures again.
    PS. i got one client with e547 and could not be erased, but due to a damaged Rom chip, very rare (thunder was its cause...). Ah, this "tips" are valid to all Ricoh machines, been working on them for ages... good luck!
    Posted on Sep 25, 2014
    Factional parablems ricoh aficio 400
    it really need to be wrote which specific functional problem is showing, as example SC 541.
    Feb 19, 2014 | Ricoh Aficio CL4000DN, SPC400DN, SPC410DN,...
    How to clear error code sc 541 on ricoh aficio 2015
    i want to make my nashuatec mp 500 copier to be dip in printig
    Oct 04, 2012 | Ricoh Aficio 2015 Copier
    Error cod sc 541
    This SC-541 code comes when the fuser thermistor fails ore contaminated or poor connecton finellay power supply bord defective most of this cases we find thermistor failure first replace the thermistor 90% your problem solves- thankyou
    Dec 15, 2010 | Ricoh Aficio MP 1600L Black and White...
    What is the sulution for e541 copier machine ricoh 5832
    SC 541 indicates a problem with the heating unit thermistor in the machine.
    This type of inquiry requires service support from your local authorized dealer or original point of purchase. This type of service code can not be reset by the user for safety reasons.
    Feb 23, 2009 | Ricoh Office Equipment & Supplies
    Error code sc 541
    I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
    Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
    Err0r sc 541
    fuser code your thermistor is bad
    good luck
    67 people viewed this question
    Top Ricoh Office Equipment & Supplies Experts
    Adorjani Laszlo
    Level 1 Expert
    Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
