Question about Poulan Pro Chain Saw 46cc 20"
Pp4620avhd (Oil pump does not work)
I have several saws but this one is my fav.(maybe because it was inexpensive and for two years has never let me down till now)
I've removed the oil pump several times in hopes to find dirt or something wrong.
The first time I completly disassambled the pump & removed the oil pickup and filter then washed the out tank and blew out the tank with compressed air still no oil, so I took it apart again to be sure i didn"t overlook something, still no oil.
The worm drive looks perfect, the shaft with the two flat sides that actually pumps the oil fits perfectly in the barrel, the two holes in the barrel are clean, the seals are in perfect shape the filter is clean, hell I even removed the filter & tried running it without, still NO OIL????????
If you can offer any assistance I'd appreciate it very mutch.
Thanx in advance,
Paul
  • geek1945ct Nov 05, 2008
    Same problem and did same as Paul. Is ther a pressure applied inside the oil tank to push the oil out and this "pump" is just a device to meter the oil?
    Ken
Poluan has redesigned the oil pickup from multiple pieces, to a single rubber piece that fixes this problem as well as the leaking after shut-off. Its only a couple of dollars, and actually works
Posted on Dec 30, 2008
    Sniper:
  • 52 Answers
Hi Paul,
If all these oil lines are clean and the spiral wire in the main shaft is not turning on the shaft is the plastic parts that mate with the spiral wire worn so thay don't pump? There is not that many parts in the whole assembly it's got to be something so simple that it's easy to overlook.
I hope this is some assistance - if so please rate the response - I can learn from your rating
Posted on Oct 26, 2008
How do you remove a clutch drum on Poulan Pro PP4620AVHD chain saw
YouTube can be a great help with video's of 'how to' do things.
I have attached a video from 'donnyboy73.' I found his video's to be very informative and well put together. The video link is not of your exact saw but is a Poulan and I hope will be helpful to you.
HOW TO Remove Clutch & Sprocket on Poulan 2150 Chainsaw. The same procedure can be applied to many other chainsaws.
http://www.youtube.com/watch?v=zf28-ztoHfg
Oct 17, 2014 | Poulan Garden
Oil no longer lubricates the chain on saw groove and oil hole are clear
Sometimes saw dust and shavings block the oil port and track strip down the bar and chain there maybe a cover over the oil port remove this and clean carefully replace all remember to clean the bar put the chain on do not over tighten run the saw if there is no oil you may have damage to the oil pump this can happen if the saw was used with no oil or a blocked oil way some of the pumps will overheat causing damage hope this helps good luck
Jul 24, 2014 | Makita UC4030A 16" Electric Chain Saw
Dear Sirs, I don't have a manual to look this
There are two holes in the end of the Bar, the oil comes though them from behind the bar and goes into the channel (oil passages) that goes around the bar, clean the small oil passages in the drive end of the bar that run out to the chain groove on each edge from the large holes.
My chain saw is doing the same thing. I have only used it about 5 hours since owning it, and it worked great last time I used it (year ago). I think maybe my pump is not working. Did you ever get your's working ? I was told to take the bar off and Start the engine and observe whether oil oozes out of the side port. If no oil comes out, then the oil pump, oil line, or oil tank filter may require service.
Nov 22, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My Poulan Pro PP4620AVHD bar oiler is not working at all. I have cleaned out the oil holes on the bar, but still no oil on bar. Is the pump located inside the oiler tank?
The pump should be located just behind the clutch assembly which needs to be removed to access the pump. Have you run the engine with the bar and chain removed? The oil should ooze out of the engine side port where the bar fits up to. If not, then the pump is certainly suspect. There is a filter in the oil tank which might be plugged. The clutch has left-hand threads and can be difficult to remove. Don't try to use an impact wrench with adapter as it will cause the flywheel key to shear. Hope this helps!
Oct 23, 2010 | Garden
Poulan Pro Chainsaw chain tensioner is junk -- chain now goes from tight to falling off in 1 cut. Model PP4620AVX. Looking for more foolproof mechanism!
Hammy if you scream loud enough Poulan may foot the bill for this.
Poulan “PP4620AVX” IPL (exploded parts list)
We are going to replace this page 2; item 70
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2009/NIUS2009-PP4620AVX-545103410-952802169.pdf
Poulan “PP4620AVHD” OM
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2005/NOUS2005_545047502.pdf
Poulan “PP4620AVHD” IPL
http://www.ordertree.com/modelinfo/PWE/PP4620AVHD-Gas-Saw/75.PP4620AVHD-Gas-Saw.1.59.1.html
With this; “Handle, Chassis & Bar Assembly” print; item 67; ChainBrake Assembly; $21.83.
You also need;
  • Item 68; Bar Mounting Nut; $0.56 each (need 2) and
  • “Engine Assembly” print; not illustrated; part number 545006011; Scrench; $9.75.
This is the configuration professionals have used forever. The only thing to remember here is to hold the nose of the bar up when adjusting and tightening the bar nuts.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 18, 2010 | Poulan Pro Chain Saw 46cc 20"
How to install/remove feul pump on a Poulan 295 pro, is it from the Tank side, or the worm screw side? I am familiar with the saw, just not this part of it, and I am fearful of just trying to pry it out...
Are you referring to the oil pump? If so start by removing the clutch and drum.Then there are 2 philips screws that hold on the oil pump.The gear is plactic and wears from the slightest bit of dirt. The entire oil pump assembly is inexpensive and should be replaced.
Dec 06, 2009 | Poulan Pro Chain Saw 46cc 20"
Need chain adjustment wheel part # for poulan pro model pp4620apx chsain saw
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
I think this is the what you seek:
http://www.ordertree.com/modelinfo/PWE/PP4620AVX-Gas-Saw/75.PP4620AVX-Gas-Saw.1.59.1.html
The "Handle, Chassis, and Bar Assembly" detail
Items 63 through 69 are parts, I think item 70 is a complete assembly ($22.78 without a kiss).
Your saw without tooless adjustment.
Item 64 (complete assembly) $2.53.
If my saw I'd ask if it can be modified!!!
http://www.ordertree.com/cms/parts-lookup-help/73.html
I suspect a vert simple modification. HTH
Lou
Nov 18, 2009 | Poulan Pro Chain Saw 46cc 20"
Oiler thus not deliver oil to the chain
Take the chain and bar off and run a small drill by hand into the hole where oil comes out. If it is not blocked you can "stretch" the hole a little bigger and hopefully resolve this.
Mar 25, 2009 | Poulan Pro Chain Saw 46cc 20"
Bar sprocket smokes, gets hot spot
Sounds like you're not getting enough oil to the chain. Basically you've got an oil pump, pickup and filter involved in getting oil from the resovior to the chain/bar. If you cleaned the obvious area and the chain is not coated with oil, you may have a clog further up (inside) the oil delivery mechanisms. Also, drain the oil from the tank, and see if you can "blow" air through there. With the saw running & pointed down, you should be able to see oil on the ground being slung off the chain, if not, you are not getting enough oil to the chain.
Nov 29, 2008 | Poulan Pro Chain Saw 46cc 20"
Bar oiling problem
Just a thought: Is it cold where you are? At this saw mill where it is my job to keep chain saws running, learned years ago that you cannot use "bar oil" in winter. Need thinner oil, like motor oil. ....preferably a "non-detergent" motor oil, plain 30-weight is OK, HD30W will work, but the HD part causes the chain to stretch more so than standard bar oil. The bar oil literally is so thick in cold that it stripped the worm gear out of a Poulan Pro oil pump (plastic gear, anyways, wasn't much to begin with.) But thought you may want to try thinner oil, if it is cold where you are. Oh yea we also have 2-Husqvarna 359's with 20-inch bar, and use thinner oil in winter. Our Husqvarnas have an oil adjuster located on bottom, on clutch side. Straight slot screw adjustment.
Nov 18, 2008 | Husqvarna Chain Saw 20" Bar
Poulan Pro Chain Saw 46cc 20" Logo
501 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
