Question about RIM BlackBerry 7250
Wheel The wheel won't push in (feels like the spring has sprung), so the Bberry is rendered useless. Suggestions?
    Problem Solver:
  • 15 Answers
Well if you're really in love with your BlackBerry and the warranty has expired you have two options:
1) Fix it yourself - Trackwheel will cost about 10 bucks (you can order it from Horizon Wireless. I hear it's tricky but doable)
2) Horizon Online Wireless - They can fix it for about for about 20-22 bucks (trackwheel and labor) BlackBerry Repair Center
**Ask for Steve and tell him Dave sent you.
Posted on Oct 13, 2008
Fix turn signal that stays on
there is a cancelation spring either metal or plastic that breaks and will cause this problem. also if the steering wheel is not centred it could be off enough that the signal will not be canceled by the spring as it won`t be pushed to the off position with the spring. it could also be a bad signal switch under the steering wheel.
Feb 06, 2015 | Cars & Trucks
1985 chevy blazer steering wheel removel
Remove the horn button, it should pop off unless you have the deluxe wheel in which case it is held on with 2 Philips screws on the back of the wheel. There is a large nut that has to come off as well as some bits and pieces for the horn. PAY close attention to how these pieces come apart or your horn won't work when you reassemble it. Attach the steering wheel puller and remove the wheel. It helps to give the bolt on the puller a rap with a hammer as you tighten it. Don't bother to try to do this without the puller... it don't work.
With the wheel out of the way, you will see a plate with grooves in the edge of it. This is the locking plate. There is a special tool to remove this but you probably won't be able to rent it. Try to borrow it if you can. If not, it can be removed without the tool. BE WARNED that THIS PLATE CAN HURT YOU as in break teeth or a nose. It is spring loaded with a very heavy spring. To remove it get a piece of boomstick or bar about 16 inch long. Enough so you can use your shoulder to push down on it and hold it while you pry the lock ring off the center shaft. Then ease the plate up until you feel it break contact with the spring. then remove it and the spring. Don't bother trying to put it back together without the spring. You'll just have to take it back apart and put the spring in. Hope this helps.
Oct 02, 2011 | 1985 Chevrolet S-10 Blazer
Hi, got a 1988 chevy blazer, can't get the steering column back together, any suggestions?
hello, usually when pulling steering wheel u need to rent a steering wheel puller, the spring that is inside is hard to push in. once you get off it is almost impossible to put back on with out puller, you have to push spring in then put the nut back on and then the clip, that keeps steering wheel from coming off
Feb 06, 2010 | 1988 Chevrolet Blazer
How do I re fit a Tissot calendar wheel?
Take an eyeglass and read the small letters and numbers under the balance wheel. This is calibre number. Submit it here = then I probably will be able to give advise.
Jan 12, 2010 | Watches
Key switch is bad
Take the top and bottom cover off the steering wheel column. Under the front of the steering wheel is a littlebracket that has 2 screws in it. Remove it with little vise grips [this pevents you from having to remove the steering wheel]. Take out the little nylon peice that the bracket held in. Then turn the key to the run position and push in the pin behind the key switch and pull the switch out. Feel behind the switch on the dash side to feel the spring loaded pin. It is rectangular.
Oct 01, 2009 | 1996 Pontiac Grand Am
Describe how to remove steering wheel of skoda fabia 2001. What kinds of tools needed for this?
triple squares are what the center bolt uses you need a small flat hbladfe to remove air bag there are 2 hole at 9 and 3 on backside of steering wheel get screw driver in there and move until you feel springs put pressure on spring you can only do one at atime so be carefull no to push bag back on once that is off uno bolt steering wheel will slide right off
Jul 21, 2009 | 2001 Volkswagen Passat
My garage door won't close. I push the remote and
If your springs were sprung it would not be that easy to open.The reason it crashes down is because they have the door balanced good for the door opener.Check on the door opener itself and see where the reset button is.Maybe something was obstructing to not let it open..Look for the reset and that should get you going on the door opening and closing.Just going to have to figure it out why it did that..
Mar 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Changing drive belt
ensure that the tensioner pulley wheel is also part of the belt loop and that it is properly sprung to take up slack. sometimes, this pulley looks good mounted in reverse, giving no tension to belt. try it the other way, against the spring force.
Sep 23, 2007 | Dryers
RIM BlackBerry 7250 Logo
264 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
