Question about HP OfficeJet 7410 All-In-One InkJet Printer
Power light off
Printer screensaver on but no power light on and printer will not do any functions. i remove power cord and pack and installed on another printer and it will work
    Sergeant:
  • 352 Answers
Hi nbooker, I would suggest you update your printer drivers, try this, follow instructions exactly as written:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Posted on Oct 21, 2008
Printer won't turn off
Check the power supply cords; make sure they are attached properly. If you are using a power strip, surge protector or any other device where the power supply cord is not plugged directly into a wall outlet, bypass them and plug the printer into a wall outlet; see if that changes anything.
If that doesn't work, remove the printer's power cord from the outlet and all the other cables that the printer connects to the computer to.
Wait 5 or 10 minutes for the printer's CMOS and RAM chips to power off completely.
After enough time has elapsed, plug only the printer's power cord into the wall outlet (do not hook up any of the communication cables in e.g. USB, or serial cables, or network cables.)
Then press the power "on" button.
If the error message is gone, power off the printer.
Uninstall the printer and all its programs from the computer.
Do a clean install and follow the procedures of hooking up the printer as though you are installing it for the very 1st time.
You may have to obtain firmware and/or software updates from HP on your specific printer.
You may also have to check with your OS vendor to make sure you have all the updates/service packs on your PC or laptop
Nov 23, 2013 | HP Photosmart C7280 Printer
Malibu lights system 8 yrs old and always a-ok. Other night, lights noticed to be super-dim. replaced 200 watt transformer with a new identical model. Lights powered up ok, but only about half...
Since it is uncommon for a power supply to vary, it is more likely there is a variable drain on the system, such as a nick in the insulation, variably grounding depending on soil moisture.
I would suggest isolating most of the circuit, and only plugging in one light at first, and then adding more until you find a change.
The other way to do it would be with an inductive ammeter or audible pick up, and trace the circuit, detecting a drop in current or sound right after the drain.
Feb 28, 2011 | Intermatic Malibu 300W Power Pack...
I keep getting the following error on my Canon 980: C000 printer error has occurred what do i do?
C000 indicates to remove the packing material.
Remove packing material so that the print headholder can move. Confirm that the printer
is powered off.
Disconnect the power cord from the printer or at the wall outlet or both.
Open the paper output tray and then lift up the scanning unit cover until it locks into position.
CAUTION: The orange protective tape may prevent you from opening the paper output tray
    After the orange tape and plastic have been removed, remove the print head packaging (if it hasn't been removed already). 1.Close the scanning unit cover.Reconnect the power cord and then power on the printer.
Jul 18, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Orange light flashing in powercell pack.console not turning on. tried different powercell pack still not working .used power surge adapter
Hi,To troubleshoot this problem, try the following steps:
Examine the power indicator light that is located in the center of the Ring Of Light on your Xbox 360 console. If there is no power to your console, the indicator light is off and the fans are off.
* Press the power button. The power button and the power indicator light are located in the center of the Ring of Light on the front of your Xbox 360 console. If your Xbox is functioning correctly, the power will turn on.
* Press the eject button on your console disc drive. If your console turns on when you do this but does not start when you use the power button, there may be a problem with the power button or the console faceplate may not be attached correctly. Contact Xbox Customer Support for more help.
If the above step does not resolve the problem, examine the power cord where it connects to your console and to the power outlet. Disconnect and then reconnect the power cord at each end to make sure that you firmly connect the cord.
If this does not resolve the problem, see whether the power cord is plugged in to any device other than a typical power outlet. For example, the power cord may be attached to an extension cord. If this is the case, remove this device and then plug the power supply directly into a power outlet.
If the problem is not a connection problem, examine the light on the Xbox 360 Power Supply.
* A green light indicates that the power supply is functioning correctly. If the light is not green, contact Xbox Customer Support for more help.If these steps do not resolve the problem, your console needs service.
Thank you!
May 11, 2010 | Microsoft Xbox 360 Console
Canon printer MP980 error code c000 what does it mean
HiHi this code is.
Remove packing material so that the print head holder can move. Confirm that the printer is powered off.
spacer.gif mp620_removepowercord.gif spacer.gif spacer.gif spacer.gifOpen the paper output tray and then lift up the scanning unit cover until it locks into position.
Pull the orange protective tape (A) in the direction of the arrow and remove the white plastic (protective material) (C).
    spacer.gif mp980_packingbeingremoved.gif spacer.gif spacer.gif spacer.gif After the orange tape and plastic have been removed, remove the print head packaging (if it hasn't been removed already). 1. Close the scanning unit cover.Reconnect the power cord and then power on the printer.
    Found this code on the net hope it helps you.
    All The Best: Pineworks
Jan 30, 2010 | Canon Office Equipment & Supplies
How to install a new catridge
Instructions
  1. Prior to replacing or disposing of your defective unit, follow these instructions to ensure the right accessories are removed. Turn the printer off, and then unplug the power cord. Wait for the printer to cool and keep the following accessories: Accessory Graphic a) Print cartridge
    CAUTION: To prevent damage, do not expose the toner cartridge to light. Cover the toner cartridge, if is necessary. c01142622.jpg b) Power cord c01142623.jpg c) USB cord c00601271.jpg d) User Manual and CD c00601269.jpg e) Input tray cover c01142624.jpg
  2. Transfer the accessories mentioned above from your defective unit to the replacement product.
  3. Apply power to the replacement product and test all the product functions.
  4. For additional support information for your HP product, please visit www.hp.com/support .
Oct 18, 2009 | HP LaserJet 1018 Printer
Printer is HP Deskjet F380 All the lights comes on when I connect power cord and remains like that. None of the buttons functions after that and printer does not work also.
Try removing the cartridges, then unplug printer power cord, plug back , and restart.
Test different cartridges and look inside the printer for paper or foreign objects.
Try reinstalling printer software.
If still no luck, then test the printer on a different computer, installing software first. If it does not work, then the printer is faulty.
Jul 29, 2009 | HP Office Equipment & Supplies
My Satallite A100/A105 Laptop computer fails to come on at all.
Remove the battery pack and power up the laptop from the mains only....then replace the power pack when the machine has booted
Nov 24, 2008 | Toshiba Satellite A100-S8111TD Notebook
Usb cord
Each printer comes with power supply cord, install CD and user manual!!! USB cable must buy!!!
Jan 22, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
Ben Johnson
