Ty 4 the advice...
Donnt know wherre tooo find the battery too reset the cmos tho... looked for it oon the back, maybe under keyboard? i dunnno... also thhe service tag number is 7TFGF51. thanks so much 4 any help
nessa
  • 240 Answers
You can go to BIOS setting and reset to factory default.
or use this to software if you forgot the BIOS password
This removes bios password from any Dell machine. unrar it and Burn the Boot CD, and then Boot to it.
http://www.4shared.com/file/82179383/4262ad3d/DELL_Bios_Pass_Killer_2008_By_Virility.html
Password: www.dl4all.com
Posted on Mar 20, 2009
  • Vincent  dela cruz
    Vincent dela cruz Apr 02, 2009
    its LAPTOP..to find the battery you need to open the Hinge cover, remove the keyboard, remove the LCD ..remove the CASE..un screw the motherboard ..flip the board..now u see the battery...its easier if she will use the software to reset the BIOS password...software is for DELL only
    Problem Solver:
  • 7 Answers
Hi, the cmos battery is not under the keyboard, take the side off your PC and on the motherboard, (the first thing you should see) there should be a 3 volt battery (about the size of a 20 cent coin), remove to reset cmos. If you need any more help locating the motherboard just ask, Cheers
Posted on Oct 14, 2008
Reset bios password
You'll need to find out which screws hold the keyboard in. Usually three or four and are on the bottom of the laptop. After unscrewing them you'll have to pry off the plastic part (carefully) that is just under where your laptops screen is. Then you will see two, three, or four screws that hold the keyboard in. Unscrew those, then gently lift up the keyboard and you should see a small round button battery somewhere on the exposed part. That is the CMOS/BIOS battery. (Note you might have to take more screws out on the back if the battery is hidden under a part, but usually it is visible and you can get to it) remove that battery for 1/2 hour or longer, and put it back. This usally will reset the bios and its password. Also note tho, that some newer boards that won't work on, and you'll need to buy software especially for reseting the password in the BIOS. Youtube has some 'videos' that advertise those softwares. Try the battery thing first tho. If uncomfortable doing that first part to get to the battery yourself, you will want someone who knows how to take apart a laptop to do it for you.
May 30, 2013 | IBM ThinkPad R31 2656 Notebook
How to reset bios password
May 29, 2013 | HEWLETT-PACKARD 630 Notebook
Reset bios
May 28, 2013 | Toshiba Satellite M35X-S163 Notebook
Bios password
May 28, 2013 | Fujitsu LifeBook T5010 (A1M2H3E605451001)...
How to remove the cmos battery
The CMOS battery maybe under a palel on the bottom of the laptop or under the keyboard.
The CMOS battery maybe a coin size 3V lithium battery type CR2032.
Apr 21, 2013 | Acer Aspire One PC Notebook
Bios password removals
The most common way that most of us know on how to reset or clear the BIOS password is to
physically remove the power from the computer by disconnecting the power plug and then
removing Cmos battery for 30 minutes from the motherboard.
You need to open the PC case, then look for a 20mm (3/4") shiny lithium button cell.
some motherboards cmos batteries are soldered in
Another way is to reset the clear CMOS jumper on the motherboard itself.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the
BIOS/CMOS settings for the motherboards PROM chip.
So by cutting off the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop -
If you are working on a laptop computer the location of the dipswitch
(almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
http://www.tech-faq.com/reset-dell-bios-password.html/comment-page-24#
hope this helps
Jul 14, 2012 | Dell Latitude D830 Notebook
Clearing cmos
The BIOS battery maybe under one of the panels on the bottom of the laptop or under the keyboard.
To reset the BIOS ack to the default settings, go into the BIOS configuration and look at the various configurations, usually there is a setting to load the Default settings, then save and exit, and this would not change the Date & Time setting.
The other way to set the BIOS default setting is to remove the BIOS battery (it is probably a lithium 3volt button battery), wait 1/2 hour and replace the battery, the go into the BIOS configuration and set the Date & Time setting etc.
Jul 04, 2009 | Compaq Computers & Internet
Try to clean the Cmos password from acer aspire 5315
What ever you do, do not use soap and water!!
Really, this is a little tough. There is a jumper someplace close to the cmos battery that will allow you to clear the password. First thing you have to do is find the cmos battery, and it could be under the keyboard, or under a cover on the bottom of the machine.
Looked for a service manual for you, but unable to come up with one.
Mar 20, 2009 | Acer Aspire 5315 Notebook
Keyboard and mouse not working
it is likely the keyboard or mouse is putting out erroneous data and windows is then ignoring the ports,
try disconnecting the mouse pad or the keyboard and run with only one connected at a time if re-seating them has no effect.
there is sometimes a combo of software that may also effect the keyboard mouse input.
click on run / type msconfig
uncheck load startup group items.
click ok,
restart , check don't show this again.
and test system.
Jun 04, 2008 | Acer Aspire 5100 Notebook
Where to find the CMOS battery
take out the keyboard from the bottom side with a flat screw driver under it there´s a few screws take it out lift the cover and there is the battery.
Oct 27, 2006 | ASI CL51-15 Notebook
Computers & Internet Logo
513 people viewed this question
David Payne
David Payne
