Question about Sony DCR-HC26 Mini DV Digital Camcorder
Sony mini dv camcorder
My cam.worked ok on vista.comp. crashed ,restored it to factory settings.now my firewire wont detect camcorder.
  • Anonymous Mar 31, 2014
    DV 106 camcorder.won't work
    Scholar:
  • 74 Answers
If you had it working before consider yourself one of the lucky ones. Vista is notorious for not recognizing firewire devices, especially camcorders. Try going to the Hardware Manager and updating the IEEE 1394 Bus Host Controller driver. When prompted, you can search in the WINDOWS\WINSXS directory and make sure the Subfolders box is checked. It may show that the driver is the incorrect one but continue to install it.
Afterward try plugging in your camcorder and see if it shows up.
Posted on Oct 13, 2008
My apple computer does not detect JVC GR-dvl 1020A camera
Go To Setting and turn off firewale then go to finder and then The Camra is there then drag the file into IMovie
Feb 21, 2013 | JVC Cybercam GR-DVL520 Mini DV Digital...
IMovie 09 / Mac OS X will not recognise Sony DCR-HC35 via firewire or USB? Do I need to download the correct driver?
mac doesn't support usb streaming so that leaves us with firewire. it should be a plug-and-play connection. no need to install any kind of driver for the camcorder (but try to check if there are any available driver updates for the firewire card).if possible try to check if your computer firewire port is working by using other devices.your imovie software should detect the camcorder once connected.if not, disconnect cam, open imovie, and connect again.if still doesnt,RESET camcorder.if still the same try restarting computer with cam connected and powered on.check if you have a dv in indicator on your screen.check if firewire cable connection is secured.try diff ilink cable if available.if still no go, try a diff computer. if everything fails might also be a service issue.hope this helps.tnx:)
Apr 16, 2010 | Sony DCR-HC35E Mini DV Digital Camcorder
Sony DCR-HC52E connected with Firewire not detected in moviemaker
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Sep 15, 2009 | Sony DCR-HC52E Mini DV Camcorder
I have a problem with my windows vista not working with my new Sony Handycam Mini DV camcorder. What do I do to get the computer to find and install the needed hardware so I can edit the video?
No extra softwares needed.
Check if cam has the firewire port. If so, you can get a 4 pin firewire cable and connect to the PC.
Switch on the Cam.
Open Windows Movie Maker and import video from device.
4 pin firewire would look like this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
You can use the Movie maker to burn it to the Disk
Dec 24, 2008 | Sony Handycam DCR-PC109 Mini DV Digital...
Cannot capture video from Panasonic DV Camcorder
Check if ur firewire cable is this:
Once connected,
Switch on the Cam.
Dec 18, 2008 | Panasonic PV-GS32 Mini DV Digital...
Panasonic NV gs 27 Vista Support
Vista is notorious for not recognizing firewire unfortunately. Here is a link to a Microsoft Knowledge Base article that should help your situation. Hope this helps. Good luck.
Microsoft's firewire solution
Oct 18, 2008 | Panasonic NV-GS27 Mini DV Digital...
JVC gr-d70 connection / uploading
wrong connection! you must use firewire to stream video and audio from your cam-make sure comp has connection-called 1394-on cam it's called dv and get proper cable and you will be fine-usb only for pics
May 23, 2008 | JVC GR-D70EK Mini DV Digital Camcorder
My camcorder
Mt computer with Windows Media, Premiere Pro 1.5, Imagewriter and a few other cannot see my GR-D250. I bought the correct firewire cable, plugged it into the cam and then the comp, nothing, no "new hardware detected", nothing, Screen is open, cam is on Play, blue screen working, nothing. I'm going to my room now.
Dec 26, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Problem in connecting Camcorder with Laptop
Use USB data cable which u get with ur cam.Install the panasonic software also packed with cam.And get ur video copied to pc.But this is a slow process because of Movie copied while playing.
Regards,
Sandeep
Oct 23, 2007 | Panasonic NV-GS15 Mini DV Digital...
Panasonic NV-GS15 Mini DV Digital How to capture recorded vedio from Panasonic NV-GS15 Mini DV Digital to Laptop. I have Windows Vista and firewire port.I try to connect it with 4 pin but Movie maker...
U get usb cable and a software cd with ur cam.Install the software and attach ur cam to pc with the help of USB cable and get ur movies copied from cam to pc
Oct 22, 2007 | Panasonic NV-GS15 Mini DV Digital...
Sony DCR-HC26 Mini DV Digital Camcorder Logo
141 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
