Question about Lexmark Office Equipment & Supplies
Clear paper jam will not go away after clearjng jam
    Scholar:
  • 74 Answers
When you cleared the paper jam did you remove it in one piece? If not you may still have a small piece tripping one of the sensors and it may require you to remove the cover to examine it closer.
Posted on Oct 13, 2008
Printer has new ink & wont print also has paper jam
The paper jam is the problem.
Clear the paper jam, recycle (Turn off, then turn on the printer) , and the other problems will go away by themselves.
Oct 25, 2015 | Office Equipment & Supplies
Paper jam c4100 photosmart printer
Step 1:
Step one: Remove any loose paper
Step 2:
Step two: Clear the jam from the All-in-One
CAUTION:Clearing a paper jam from the front of the product can damage the print mechanism. Gain access to and clear paper jams through the rear door whenever possible.
Step 3:
lear the jam from the back of the All-in-OneFollow these steps to clear the jam from the back of the product
  1. While the product is still on, disconnect the power cord from the back of the product.
  2. Press in the tab on the left side of the rear door to release the door. Pull the door away from the product to remove it.
Step 4:
  1. Gently pull the paper out of the rollers.CAUTION:If the paper tears, check the rollers and wheels for torn pieces of paper that might remain inside the product. Remove all the pieces of paper from the product to prevent more paper jams.
  2. Replace the rear door. Gently push the door forward until it snaps into place.
  3. Connect the power cord to the back of the product.
  4. Press the OK button to continue the current print job.
Mar 18, 2013 | HP Photosmart C4100 series
How to clear paper jam copier printer
The message Paper Jam may appear on the display if the Brother machine is not feeding paper correctly, paper scraps have become stuck in the print head path, the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
To resolve this issue, please follow the steps listed below:
  1. Disconnect the machine from the power supply.
  2. Turn the unit around and remove the Jam Clear Cover from the back of the machine by grasping it at the Center and pulling it straight away from the rear of the machine.
  3. Look for any paper scraps, jammed paper or foreign objects in the rear of the unit. If anything is found, remove it. Be carefull not to touch the feed roller.
3. Remove the paper tray feeder from the front and look inside for bits of paper and check the paper is flat in the tray.
4. Replace tray and back cover and all should be fine.
rover620
Sep 21, 2010 | Brother DCP-330C All-In-One InkJet Printer
Printer says to clear paper jam and press OK there is no paper jam
If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not
in the rear rollers, check the top door.
To clear a paper jam from the rear door
1. Turn off the HP All-in-One.
2. Press in the tab on the rear door to release the door. Remove the door by pulling it
away from the HP All-in-One.
CAUTION: Trying to clear a paper jam from the front of the HP All-in-One can
damage the print mechanism. Always access and clear paper jams through the
rear door.
Page 148 of manual here will show you more info as well as photos on hoto.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
May 01, 2010 | HP Photosmart C8180 All-in-One InkJet...
Lexmark x6575 printer error message clear paper jam
Success and relief at last!
Thanks to Dinky on another web site who had the same problem with his Lexmark X6575 printer (a similar printer). The resolution of the problem once I had read Dinky's explanation took less than 30 seconds!
Dinky's exact words on the issue are as follows:
" Dinky commented 5 months ago
Hooray!!!...after lots of hours trying to fix my printers 'Paper Jam' message, even tho' there was no paper jam in my lexmark x6575, but the message refused to go away...I have finally got it to work!!!...
WHAT I DID......
There is a long silver metal bar that the ink cartridges run along. Well just underneath this there is 8 little roller feet that sit on top of another silver/cream roller. Well in between these, in the very centre, you will see a little black plastic nib like thingy...While the machine is turned on, press this little black thingy (best to use a pen or something like, as it's small) and what should happen is the silver/cream roller will make a quick rolling motion....Hey! presto the 'jam message' disappears and the lcdmag-glass_10x10.gif screen should show set-up options (like date, time, ect).
I hope these instructions are clear enough to follow, and I also hope this solves that dreaded 'Paper Jam' message for you all....Good Luck!
Regards, Dinky "
Sep 14, 2009 | Lexmark X6575 All-In-One InkJet Printer
Clear Paper Jam, then Press OK
Have you checked the access door in the rear of the machine?
Jan 05, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My hp 1315 all in one had paper jam
1. Remove any loose paper
a. remove any loose paper from the In tray and Out tray
b. press the cancel button (x) on the product control panel to clear the paper jam
2. Clear the jam from the back of the printer
a. press the Power button to turn off the product
b. unplug the power cord from the back of the product
c. remove the rear access door. turn the knob one quarter turn to the left, and then pull the door away from the product
d. gently remove the paper
3. Clean the rollers with a lint free cloth that is moist with water
4. Try printing again
Aug 07, 2008 | HP DeskJet 5652 InkJet Printer
Could you please tell me how to release paper jammed in a hp photosmart c3175 ALL IN ONE printer scanner copier,if I pull the paper it just tears away. Thank You . RAY WINCH. EMAIL...
Clearing a paper jam from the rear door Follow the steps below to clear a paper jam through the rear door.
  1. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the unit. Figure 1: Removing the rear door c00652942.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all of the pieces of paper from the unit, more paper jams are likely to occur.
  3. Replace the rear door. Gently push the door forward until it snaps into place.
  4. Press Cancel to continue the current job.
Clearing a paper jam from the front door
  1. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door c00652943.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all the pieces of paper from the unit, more paper jams are likely to occur.
  3. Close the print cartridge door. Figure 3: Closing the print cartridge door c00652944.gif
  4. Press Start Copy Black or Start Copy Color to continue the current job.
Aug 06, 2008 | HP Office Equipment & Supplies
Paper jam
Very frustrating ... checked all over for remaining jams - but the message "paper jam" just won't go away after clearing a paper jam. Eventually, it goes away but no way to predict how long it will take!
Feb 10, 2008 | Brother MFC-8440 All-In-One Laser Printer
How do I clear misfeed.
In most cases where the machine says there is a jam, and there is no paper in the paper path, it's because the paper never got out of the paper drawer and didn't reach the 1st jam sensor. If you can open the machine and it resets, then chances are the paper feed roller is either slipping or in some cases not turning at all. If you can't clear the jam by turning off the machine, and back on, then you have a bad jam setect sensor or perhaps a small piece of paper lodged on the jam sensor. This will take some additional troubleshooting on your part. Need to know if the jam indicator goes away when you restart the machine. Let me know and I'll try to guide you from that point. Aloha, Bill Monroe
Sep 17, 2007 | Ricoh Aficio 1018D Copier
135 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
