Question about Microwave Ovens
Microwave repair One of two latches snapped off when removing food from oven.  Latch caught on my watchband.
  • angie34c Apr 17, 2009
    door latch hooks snapped how do I replace it
  • 185 Answers
Replace the door switches
Posted on Oct 13, 2008
Kenwood K30CSS10, combination oven has stopped working. Used to heat some food when used later, light was on, turntable was stationary. Found a broken door latch. Is that the trouble?
If you had a broken latch,that latch was not closing a switch that needs to be closed to tell the unit it is safe to run. So yes start with broken latch.
Aug 19, 2017 | Kenwood Microwave Ovens
Sticking Door
The door latch release or latch itself is the fault---most shops can take apart and replace or repair this----a number of units the replacement part is better made.
Aug 28, 2012 | Microwave Ovens
Microwave does not heat or turn
The problem may be in the door latch, "one or more is defective" often caused by food particle build up or latch failure, this will prevent the microwave from running.
Mar 05, 2012 | Whirlpool MH6140XK Microwave Oven
Cannot get door open (and there is food inside). Push button goes in all the way, will not release door latch
Disconnect from the mains supply.
Remove the cover and you will see how the latches lift.
Hope that helps.
Nov 15, 2010 | Panasonic NN-T993SF Microwave Oven
Plastic latches on door have no tension. Microwave thinks door is open, because latch is not ingaging. How do I access the latch hardware.
with butter knife or small flat head screw driver, carefully remove the plastic ring from ther inner door .cheap repair is to hook the spring to the metal fins inside the door if not order outer door panel
Jan 19, 2010 | Sharp R-1480 Microwave Oven
When microwave finishes light doesn't come on when door open; display keeps reading "food ready" after food is taken out--have to push the "clear/off" button to make "food ready" display go away; counter...
Shorted switch in the door latch assembly.wihout the full model number I can't tell how to get to it, but usually one needs to remove top grille, remove screw holding the control panel, remove control panel. Good luck.
Nov 26, 2009 | GE Profile Spacemaker II PEM31 Microwave...
The door latch broke, and I can't get the door open, or the food that was in there before the latch broke!!!
Remove the cover --- you shuld be able to release the lock from withinthe cabinet.
While you are there, you may want to replace the door safety interlock switch(s)
You may have to disassemble the door to get the latch fixed.
Oct 19, 2009 | Microwave Ovens
I opened the door on my sharp microwave and now it wont latch. it sounded like something snapped off where the door latches to the microwave, not the door itself . Even if the door is held shut the light...
It may be the latch head spring or the door open lever or button.
DOOR SPRING LATCH HEAD HOOK
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
you have to separate the door panels (as shown in the attached photo) and then you'll see how it goes together.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
DOOR OPENING BUTTON LEVER
What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can usually find exploded views and part numbers for Sharp models by entering your model number at the Sears parts site.
If not, let me know. We have many Sharp manuals and if we have yours, we can link you to it at no charge.
The best place to order Sharp parts is
Encompass (formerly Tritronics).
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Oct 10, 2009 | Sharp R-1480 Microwave Oven
MIcrowave
check the door latches inside the oven, open the housing and spray some lubricants on the latches.
Feb 21, 2008 | Frigidaire FMV145K Microwave Oven
Directions to remove and open door panel to repair safety door latch.
You don't have to remove door to remove panel. Panel is held in by an outer plastic retainer which can be removed by carefully prying with a small screwdriver. I can be replaced by pushing it back in place after repair is completed. If you cannot open door from the outside, remove cover and you can see latches. Pry up on latch which will let door open.
Jul 28, 2007 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
128 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
