Picture on TV blinks on and off when you first turn on. Now it blinks on and off sporatically. The color changed before this started. Reds and greens are off. It's a Sony about 10 yrs old. Is it on it's last leg?
  • Dixie Drawl Oct 13, 2008
    Model # is KV-27 S 26
    Manufactured March 1998
    Thanks for any help you can give me.
    I'll try when I get home and let you know tomorrow.
  • 38 Answers
Can u give me a model number for u set and u may just have a bad connections on the if pack witch is comon for sony minor problem easy fix. please let me know marty
Posted on Oct 13, 2008
  • dkreavis Oct 13, 2008
    this is what u can do it may sound dum but it works. where u hook up the cable when the tv set is on hit the right side of the tv with your hand if u have a bad connection u will see the picture blink off and all u have to do is pull the tuner or if pack out and re solder the pin connections and that shoul fix it u dont need any parts for it. i hope this will hp u marty
    np that shoul work for u
No picture. Monitor blinks 4 reds. Tv would come on for a few seconds then turn off. Now nothing but blinking lights. what do I do. Thanks
You have may be broke the system cable, the dvi-d cable is broke...
In my pdp-5030hd have the same problem, probe changing the only the dvi cable and works perfect...
The monitor blinks 3 red and the 4 blinks still in red...
Now i will try to put in the dvi-d input another source like a pc...
You need always the Pdp03u box for control...
Sep 12, 2010 | Pioneer PureVision PDP-5030HD 50 in....
It sounds to me like it's stuck in service mode.There is a button combination with the remote to return it to normal. I would call Vizio support and they should be able to help you.
I think it's a combination like [volume -], [channel -] and power but I could be wrong.
Dec 19, 2009 | Vizio L32 32 in. LCD HDTV
The tv will not come on . The power led is blinking 3 greens and then 2 reds. I have changed the light but still can not get the tv to do anything. I can't even shut the power off with the buttons.
Most likely its not the lamp thats bad but the color wheel is stuck. Check if the color wheel starts or not. You can make this out from the typical dlp switching on whine. If you have already changed the lamp, and there is no color wheel start noise, you have a bad color wheel.
Aug 28, 2009 | Sharp 56DR650 56" Rear Projection HDTV
Picture is pale, yet reds are bright. checked color, brightness, and conversion settings. TV seems unresponsive to the color, tint, and brightness adjustments.
open the back and look into the projectors red blue and green should be clear picture if its blurry need to change the coolant if its not on need to replace the projectors
Aug 22, 2009 | Philips 50P8341 50" Rear Projection...
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
My phillips model 60pp920217f has a horrible green to the color
The green CRT coolant has congealed thats whats giving you the green halos. Change the coolant in the green and blue and your set will be fine. red is never affected so the red coolant should be fine.
May 07, 2008 | Philips 43PP9202 43" Rear Projection...
Dlp tv picture flickers and reds have yellow blotches after the TV is on for more than an hour.
Could be color wheel problem--but u'll prolly have to change out the light engine $$$--Causes blotches---Good luck
Feb 05, 2008 | Televison & Video
Panasonic T.V...
What is your tuner source? Cable,Satellite, antenna?...accordianman
Nov 13, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Philips hdtv color distortion
your tv has a prolem in the color circuit there is a ic that controls this circuit changing it will restore your tv to normal.since you are not a tech have a tech look at it for repairs.good luck.
Aug 03, 2007 | Samsung TXM3296HF 32" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
