I have a HPPavillion laptop with built in wireless. Is there anything I can buy to strenghten my signal to a wireless router.
  • 535 Answers
Its dipend on router range there is one way see the link for it  http://www.scottklarr.com/topic/117/make-your-own-wireless-router-range-extender/
Posted on Oct 13, 2008
  • 749 Answers
No , thers nothing to boost the PC unless you go with a wireless N card, BUT, there IS equiptment for boosting the signal from your router and it will depend on which router you have.
Since you didnt post the make and madel of your laptop or router , this is just going to be a general fix.
Go to Yahoo, google, ETC. Search for "xxxxxx wireless signal booster ". xxxxxx being the make of router you are using now.
For example, i searched linksysy and found one for linksys: http://www.bizrate.com/networkingproducts/linksys-wireless-g-range-expander-router-wireless-signal-booster--pid11678449/index__kw--wireless+g+booster__qcid--1402153.html
Belkyn g router does not connects with full strength. I have connected just a laptop and a tablet. Tablet gets average speed but laptop finds it hard to receive signal.
The reason your laptop may have trouble connecting at full speed could be due to the quality of its wireless card/motherboard (if built in). There are a few things you can try, first you can try updating the drivers for your wireless card/motherboard via windows update or alternatively from the laptop manufactures website. You will need to make a note of your make and model number of your laptop which is normally on a sticker underneath the laptop. This may improve things as there have been some minor signal issues addressed with driver updates on some wireless card.
Other options:
check if your router has detachable aerials (if they can be unscrewed) if they can you could buy some aerials with a higher dbi. Routers typically ship with 1-3 dbi aerials you can get them typically as high as 8dbi for indoor use, this will improve the signal slightly. If your router has more than one aerial you should replace each of them with the same type and dbi to ensure it works correctly.
buy a usb wireless adapter, these give you access to wireless if you don't have any built in, but can also be used as replacements for your in built wireless.
change your router (a last resort) but there are a number of advantages to this, newer routers a more powerful, faster and use "N" which is faster than G. N gives you speeds of 125mbps upwards. Wireless N routers are backward compatible for B and G devices so any older devices will work but they will still be subject to any limitations of wireless B or G.
Jun 30, 2014 | Computers & Internet
I would like to know when it say laptop with built in wireless. Does that mine i already got internet service on it. Or i have to buy USB modem.
Hello Blac,
All the laptops available in market have built in wireless 802.11 b/g/n or 802.11 b/g/n Bluetooth® wireless networking. It means that you can access the internet via Wi-Fi or through Wi-Fi hotspots. In wireless connectivity you do not require the wired connection to access the internet. In home you can connect the laptop via wireless connection using the home networking router available in market. The advantage of wireless connection is that you can use the internet in your home anywhere with in 100 meters of range with proper wireless signals. You will require to get the internet connection from the ISP(Internet Service Provider).
Please visit the link provided below for Home Networking Wireless Router :
http://www.netgear.com/home/products/wirelessrouters/
Jun 29, 2011 | Computers & Internet
Is my problem the internet signal or the wireless router?
Howdy,
If you have been using this router/laptop for 3 years successfully and then all of a sudden it does not work, you may attempt to try an external USB wireless adapter. Does your T30 have 802.11b connectivity built in? It is not unusual for these to go out. Before you buy one check first to see if you can still access wirelessly at other hotspots? Or does the problem follow you around? If you can successfully connect at other hotspots then this is not the problem and it may very well be your router. Is there any way you can get a substitute rouer to test with before you purchace one? A friend maybe? It is probably one of these 2 issues. If you find your wireless is out on the laptop and you go to purchace a USB wireless adapter, go for a Linksys and make sure it is at least wireless "g" or "n" and not "b". And if you do not have enough USB ports then you may want the flat wireless card adapter that plugs in to the PCMCIA slot on the laptop. This can be Linksys also - I use this one (flat card) - "Wireless G Notebook adapter with SRX" Model Number WPC54GX. It is great and has speed boost. If your built in wireless on the laptop is bad, then any of these external adapters you choose to use will simply take over the wireless reception. Good Luck.
J
May 30, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
How to install wireless
First, do you have a wireless router? I am assuming the AT & T service is DSL (am I incorrect?).
For a wireless network, you need a cable or DSL modem, then that is hooked to a wireless router that transmits the signal. The laptop is then set up to connect to the wireless network that you have created.
When you buy a wireless router, there is normally a setup disk that will help you do all of this.
Just give a shout if you need more help.
Jan 23, 2009 | Acer Aspire One PC Notebook
Need a wireless router for my talk talk broadband
You could use any brand wireless router with your broadband service for a wifi signal for your laptop or any wireless internet to any device that is compatible for it. You first need to make sure your laptop has built in wireless or if it needs an adapter(ex. Wireless notebook adapter, USB Adapter). and if its built in then all you would need to buy is a wireless router(Linksys has a really nice and user friendly setup. Model:WRT54G).
Sep 17, 2008 | Computers & Internet
Wireless Network?
The modern laptop and Wii will be no problem. Windows 98 will work but it can be much trickier to set up.
Parts needed
1 x Wireless Router - You can pick up a 2WIRE Router from around £20 on eBay
3 x Wireless LAN Network Adaptors - Around £20 each.
Firstly, the Router. This bit connects to your telephone line and broadcasts your broadband signal by radio and allows several computers to use one service. When you buy a router make sure it includes installation software. You can install routers without, but it's a whole lot easier if you have it.
Next you need to be able to receive the broadband radio signal on your computers and Wii.To receive the signal you need Wireless LAN Network Adaptors on each device. Network Adaptors also have software, which allows you to install the drivers needed.
Your laptop may already have a wireless adaptor built in.
You can check this by clicking
Start\Programs\Accessories\System Tools\Communications\Network Connections
Then see if a Wireless adaptor is present. If it isn't, you can install one inside the laptop by buying a laptop wireless network card. Easier, is to buy a USB Wireless LAN Network Adaptor which just plugs in to a USB socket on the laptop.
Look for LAN Network adaptors that are suitable for the Wii and a separate one suitable for Windows 98. Most will be ok for the laptop.
Install the router first. just do what the software tells you, then install the LAN adaptor drivers on each device you want networked.
Finally, make sure you secure your router signal. That stops the guy next door using your network and offers some security from hackers. Your router will include a firewall and you can set up a key code that your adaptors will need before they can connect. Unless the guy next door has the key, he won't be able to use
your network and play your MP3s...hoorah!
Follow the instructions given in the software to set up a WPA or WEP security key.
Great fun, you'll love it if you can get it all going.
Feb 24, 2008 | Computers & Internet
About wi-fi
Windows XP has a built in wifi configuration tool, previous versions of windows dont have this feature. But if you were to buy a wireless card it comes with software for wireless to work on all versions of windows from 98 - XP most if not all new laptops have wifi built in & that will be able to share your broadband connection through the netgear router. You can configure the laptop & pc to share files & printer between each other, easy way of doing that is by using the wireless network setup wizard which can be found in Start -> All Prograns -> Accessories -> Communications -> Wireless Network Setup Wizard.
Feb 10, 2008 | Computers & Internet
Netgear wireless adapter
When you say home bases, i assume you mean desktop pc's. If the channel you mention is the channel that the router works off eg channel 11 then all wireless adapters have to be set to channel 11, or the same channel as the router. The reason for one disconnecting from the internet will probably be the adapter losing the signal because of obstacles like walls and doors, as if the signal gets too low then the reciever cannot connect properly with the router, hence dropping the connection. Try the router in a different higher position or at a phone socket nearer the troubled pc. The connection accross the network should be atleast good and at 54 MBPS, anything less may not connect properly. The laptops will tend to have a stronger connection as most have a signal up booster built in the screen.
Apr 11, 2007 | NetGear WG111 802.11g/b Wireless Adapter
Wireless connection keeps falling
It may be just a problem of the signal bouncing around and your laptop is struggling at times to find the signal. Some earlier laptops don't have a wireless booster built in the screen. Go to your laptops' web site and see if there are any updated drivers for your wireless card. If still unhappy with results purchase a USB wireless dongle and dissable wireless card, it may have a better reception area, or purchase a signal booster that works in conjunction with your wireless router.
Dec 18, 2006 | Edimax BR-6114Wg Router (BR6114WG)
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
