Do I have to eject icon before I shut down computer?
  • 1,879 Answers
Proper way to shutdown
Click Start button then locate and press the Shutdown button
Posted on Oct 13, 2008
How do I mount my sd card
You will insert the SD card into the SD card slot on your device then you will power on the device and tap settings from the main menu click free format and then pick mount SD card when reformatting has completed.
May 04, 2016 | HP Computers & Internet
How do I eject the Dvd
Press the eject button on the top right-hand of the keyboard. Be patient if the disc does not pop out immediately. Try pressing the button a few times or waiting a few seconds and then press the button again. If it doesn't eject, tilt the computer with the disc drive facing down and shake it gently as you press eject.[1]
Drag the disc icon into the trash. If the eject button isn't working, locate the disc icon on your computer's Desktop and drag it to the trash can. The trash can is located on the far right end of the Application Dock on the bottom of the computer screen.
Press and hold "Command" while simultaneously pressing "E."
Find the disc in the Finder. Open the Finder, located on the bottom left of the applications dock. Look on the left-hand side of the pop-up window under "Devices" for the name of the disc in your drive. Locate the eject button directly to the right of the disc name and click on it.
5
Eject the disc through an application if it is not in the Finder. In iTunes or DVD Player, click on the "Controls" drop-down menu located on the top toolbar and click "Eject Disc." You can also open iTunes and click on "Playlists" so that the left side bar pops up. Look for the CD icon with the appropriate name. Click the eject button directly to the left of the CD name.
Jul 11, 2015 | Televison & Video
How do i get my cd out of my computer?
You have two options:
1. Restart the computer while holding down the mouse button.
2. Push a paperclip down the lefthand side of the CD slit where you will find button that needs to be pushed in to eject the CD.
guides macrumors com
How force eject disc
Mar 11, 2015 | Apple Mac OS X
How can i remove my cd ?
In the Finder (on your Desktop), you can usually remove your CD by
  • simply dragging the icon for the CD to the Trash (Trash icon will turn into an eject icon).
  • You can also right-click (Ctrl-Click) on the CD icon and Select "Eject" from the dropdown menu.
If your CD doesn't eject,
  • shut down your laptop;
  • press and hold the mouse key (press the click on the trackpad);
  • while holding the mouse key (pressing and holding the click on the trackpad), press the power key to restart the computer;
  • let go of the click on the trackpad after the CD ejects.
Mar 11, 2015 | Computers & Internet
Ejecting a Stuck CD in Mac OSX
  • First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu.
  • If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X.
  • Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
  • If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar.
  • Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder
  • Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button.
  • Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism.
  • Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray.
  • Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. )
  • If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Sep 17, 2010 | Apple iMac G4 Desktop
I need to remove a disk from a Sony NEC Optiarc AD-7640S
CD Stuck in Device
First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu. If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X. Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. ) If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Dec 23, 2009 | Computers & Internet
Hi- I've just inserted a CD into my MacBook Pro
CD Stuck in Device
Oct 13, 2009 | Apple MacBook Pro Laptop Computer with...
My cd is stuck in macbook and is not being read by my computer it only makes a funny sound when i reload it
A CD or DVD disc can become stuck in your Macintosh. It may not be appearing on your desktop or could be causing the computer to lock up if the computer cannot recognize it properly.
[edit] Solutions
Sep 30, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
I put a mini disk in my macbook not knowing it would not load - now it will not eject
Be persistant-shake the F&^% out of it. Face it with the disk slot facing down and just shake it a few times. Worked for me.
Sep 15, 2009 | Computers & Internet
The door will not open and eject the cd. the amber light stays on all the time
Try going to "my computer" and right click on the icon that shows your cd drive. Then select eject to see if the cd will eject.
If it does not, then shut down your computer. Look for a small pin hole below your cd tray. Unbend a paper clip and insert it into the hole and press. The cd tray should pop open so you can remove that cd.
If the problem continues then it's time for a new cd drive.
Hank
Jun 29, 2009 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
