Question about Dryers
Thermal limiter you answerred a question regarding a thermal limietr that keeps tripping in my dryer. I think i solved the problem by removing several feet of flexible vent in the attick. As a follow-up to your description of the thermostats that regulate the heat: I know the thermal limietr is "one and done" meaning that once it trips it has to be replaced but what about the other 2? If I have already replecde the thermal does that mean that the other two are not functioning? Thanks
  • Dryers Master
  • 822 Answers
In most dryers there are two thermal fuses and two thermostats. If the vent hose was restricted it is most likely that the thermal fuse on the heater assembly has failed . The fuse and thermostat come as a set in that in most cases the thermal fuse blows as a result of the thermostat failing.
The second set of a thermal fuse and thermostat is located on the air exiting the drum closest to the vent and control the drum air temperature. A qualified repair person can easily with power disconnected check these for devices and the one that is open at room temperature needs to be replaced.
Hope this helps?
Components in blue box are the thermal cutoff fuses
Parts below are used in the heater assembly to control the heater maximum temperature. If the thermal cutoff fails the thermostat is also replaced. These parts come as a set.
Posted on May 30, 2017
  • 87 Answers
SOURCE: Dryer will not start. Ge DX4500EAoWW
You may have a bad timer: Also, there may be a separate thermal fuse for the motor, usually an inch long white plastic one attached to the blower housing.
Posted on Jun 08, 2007
  • 1314 Answers
SOURCE: frigidaire dryer
there are several issues that can cause this most common is the vent restricted backing up heat in the dryer if its as old as you say you need to check the whole vent system it has to be 4inches dia all the way if its mashed or drooping under the house its restricted if its folded over or mashed behind the dryer its restricted the thermal limiter is a safety thermostat it opens about 300 degrees to prevent fire the dryer has three thermostats an operating thermostat a safety thermostat and the thermal limiter if the operating thermostat fails then the safety thermostat takes over and cycles on about 165 on and off if both thermostats fail then the thermal limiter opens about 220-300 depending and it doesn't reset and cuts all the power to the dryer till a tech can check everything i just told you about so if your vent is clear and the best way to vent is 4inch pvc drain pipe 90 it up behind the drier then connect with a short peice of metel vent then just replace all three thermostats
Posted on May 21, 2008
  • 210 Answers
SOURCE: Runs but no heat
You can get the thermostats individually. High limit is part number 6931EL3001E and the safety is 6931EL3003D
Sgt 48
Posted on Jun 03, 2008
SOURCE: Maytag dryer: pye2300ayw
I had the same problem last month. My heater element broke in two places. This created an electrical open that prevented the heater from functioning. I replaced the heater element and my problem was solved.
In order to check your heater element: With the machine unplugged, disconnect one wire to the heater element and then use an ohm meter or multimeter across the heater element lugs to read resistance. Infinite ohms = open circuit.
Posted on Nov 04, 2008
  • 300 Answers
SOURCE: Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Posted on Mar 07, 2009
What's your problem? Check filter light keeps flashing
SERVICE MANUAL
NOTE:
I have several manuals on hand and they all read the same
That could be the lint has a partial blockage in the outside vent and the vent thermal limit is tripped.
DRYER VIDEO
Jun 18, 2012 | LG Dryers
DRYER STOPS/STARTS DOESN'T GET HOT ENOUGH
dryer duct blockage caused thermal limiters to trip. four t 20 screws remove the heater bank cover on the back of the dryer. unplug the dryer. unplug the dryer. did i forget to mention, unplug the dryer? remove the heater bank cover, and press the three red buttons in the center of each thermal limiter. at least one of them should click when you press it. replace the cover, plug the dryer in. it will now heat, but if you dont fix the blockage it will trip again.
Jun 14, 2012 | Miele T9800 Electric Dryer
Model RES7745PQ0 works great but no heat... what is most likely the problem... also I checked my breaker so that's not it...? HELP\r\nBest Regards
The problem is likely in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Disconnect power then remove the rear access panel to access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make.
The
thermal cut-off (cut-out) and high-limit thermostat are sold as a kit with part number 279816 and costs about $30.
In case the dryer still doesn't heat up with the
thermal cut-off (cut-out) and high-limit thermostat bypassed, bypass the cycling thermostat then replace it if the dryer heats up. Check the heating element for broken coils if the dryer still doesn't heat up with the three components mentioned above bypassed.
Jan 19, 2011 | Roper Dryers
It got extremely hot and tripped the breaker. The coil is not shorted, so I'm guessing a switch or heat sensor is. What do you think? It is model RED4400
There is a high limit thermal fuse on the rear of the machine.
Test it for continuity.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 01, 2010 | Whirlpool Dryers
My dryer will run but will not get hot. The trouble shooting guide says that on of the two house fuses in the circuit may be blown or the thermal limiter is tripped. Where are the fuses in the dryer. I...
First id make sure you have both phase of AC power coming into dryer.
Go to your house panel and reset yoru house breaker for the dryer. If in the USA the breaker should be a 240volt / 30amp breaker. It will have two breakers tied together at the trip switch.
If AC power is good at the dryer outlet then it could be one of the followings.
  1. Open Thermal limit fuse or trip switch.
  2. Open Heater Element.
  3. Control board is faulty.
Oct 26, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Thermal limiter stops dryer; replaced multiple times. Dryer dead.
I think you are working on the wrong end. Check the fan and inlet ductwork of the dryer, if the air isn't moving properly, it will not move enough to keep the coils and limiters cool and they will fail after working properly a few times.
Sep 03, 2009 | Frigidaire Dryers
Our Kenmore 87042 thermal limited tripped. Can we
This is repairable. Most dryers have a thermal fuse, or limiter, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 06, 2009 | Dryers
Whirl pool elect dryer keeps tripping breaker
Ok, this is the result of a failed High limit thermostat. you should replace this failed device asap.
Check for continuity in the thermal fuse as well. replace if no continuity is found.
May 31, 2009 | Whirlpool LEB6300 Electric Dryer
ROPER DRYER REX3615EWI
Hey billybob40s,
Does the dryer trip the circuit as soon as you push the start button or does it take a while to trip??
Oct 19, 2008 | Estate TEDX640JQ Electric Dryer
Hotpoint aquarius tdc32 condenser dryer keeps cutting/tripping out after 5 minutes usage. Press the start button immediately after and won't start. Have to give it 10 minutes or so before starts up....
It may be necessary to clean the condenser unit/module (heat exchanger). Often lint would accumulate reducing the efficiency of the condenser causing the temperature internally to rise above specs. Thermal cutoff senses and trips the unit.
In some instances, it could be the thermal sensor/thermostat. I think your particular model has two of them. To gain access inside, it would be required to remove 2~3 panelings. A continuity tester is needed to check the thermostats.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 25, 2008 | Dryers
Dryers Logo
75 people viewed this question
Top Dryers Experts
