Question about Motorola Mobility RAZR V3xx Cellular Phone
Keypad not working
My cell phone keypad refuses to work minus the "End Call" button. Any other button I press does not respond. The keypad still lights up and actually the phone has worked a couple of times, but not consistantly. I thought it was because my battery had been low last night, but even after plugging in the phone to the charger, it still refuses to work consistantly. Can you please help?
  • shgj Dec 26, 2008
    The exact same problem. I attributed the error to connecting the phone to my pc.
    But i still have no idea.
  • Anonymous Apr 04, 2009
    All the buttons except the end call button do not work. If I hit another button, it takes me to the menu, but I cant navigate to anything.
I have a lf cookie kp 500 and it is all touch screen and none of the keys work i can receive calls but cannot make calls or use any of the features
Posted on Sep 11, 2011
  • 64 Answers
Good day,
if you are the techie type of guy, you can open the phone yourself and check for the allignment of your keypad and the contact points. you can do this by removing the casing and replacing it again, but make sure that the keypad is properly placed before reassembling your phone. while your phone is still open, try checking for dust or any foreign material inside that might have caused your keypad to malfunction.
however, if you are not the techie type of guy, have it checked by a competent motorola cellphone technician in order to verify other possible causes of the problem.
i hope this will help
Posted on Oct 13, 2008
My GTB3410 sometimes the three buttons below the touch is not working alternatively, some times call button is not working at the same the back and end button is working , some times end button is not...
unscrew your phone and remove the keypad. then try pressing the phone without the keypad, if it works very well it means you will have to buy another keypad for your phone.
May 12, 2011 | Cell Phones
My nokia 2680 slide phone had a problem it cannot press the ok buttons and call buttons pls help what can it do to resolve thes problem... tnx
hi torre,
the problem is with your keypad as the ok & call buttons are mostly used in the phone the pad inside the phone gets punched so it doesnt respond when we press it.
so, u have to visit the nearest nokia service centre to repair the handset.
Regards,
Prakash
May 08, 2011 | Nokia 2680 Slide Cell Phone
The down button the numbers 2, 3 and end call button have stopped working. when i press one of these buttons its shutting the phone down-any ideas or advice please?
Hi, it's the keypad IC or the keypad itself. So you can check the keypad if there is dirts that is stopping the keypad from working. Or the keypad needs to be replaced.
After checking the keypad if the keypad still did not solve the problem,
You will have to replace the keypad IC inside the board of the phone.
Take care. .
Aug 20, 2010 | Sony Ericsson K850i Mobile Phone
Keypad does not respond
their might be virus in ur phone that make ur phone hang,upload new phone software or format ur phone
Aug 08, 2009 | Motorola Mobility RAZR V3
Keypad acting up!
SURGICAL - you need to replaced the mobile flexcable in the phone also have the repair center flash the keypad flexfile back into the phone.
BRENNA - replaced the flexcable
VGETSON - you need to flash a file call keypad flex into the phone to correct the keypad freezing up on you.
Sep 27, 2008 | Motorola Mobility RAZR V3
Locking keypad
Press menu and then the star button. That usually locks all motorola phones
Jun 19, 2008 | Motorola Mobility L6 Cellular Phone
Locked cell phone keypad
first, take out the battery and press the RED end call key for 15 seconds, then put the battery back in and turn on the phone.
if that doesn't work then try this from the website.
How do I lock/unlock the phone's keypad? To lock and unlock your phone's keypad, press and hold the left navigation key.
Or, select Menu -> Settings -> Keyguard. Then highlight either of the options and press the OK button. You can set your phone to lock the keypad immediately, or automatically if no key is pressed after 30 seconds, 1 minute, or 5 minutes.
To unlock the keypad: Press 1-2-3 in that order."
good luck!
Apr 15, 2008 | Kyocera K10 Royale Cellular Phone
Keypad problem
see ur connecter with ur keypad must have got shooked up, so what u can do is u can go to the vendor they will fixit up for u.
Oct 17, 2007 | Nokia N73 Cellular Phone
Motorola ROKR e1 keypad problem
It's the problem with the keypad board, the hardware problem not software, clean the connector carefully and replace the keypad board with the new one. This will solve the problem. Regards.
Aug 23, 2007 | Motorola Mobility ROKR E1 Cellular Phone
Motorola Mobility RAZR V3xx Cellular Phone Logo
328 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
