Question about Panasonic Workio DP-2310 All-In-One Laser Printer
"replace waste toner box" error
My copier's error message "replace waste toner box" will not shut off even though the box is nearly empty. I believe it is a sensor problem. I am looking for a quick solution. thanks
    Sergeant:
  • 284 Answers
Sorry there is no quick solution you need a tech to go into service mode and reset the counter
Posted on Nov 03, 2008
How do I clear the 'dispose of used toner' error message?
Clean well the toner box or better replace with a new toner box.
Sep 24, 2014 | Toshiba Dp3580 Dp2570 Dp2460 3560 2060...
WASTE TONER IS FULL ERROR
You have to empty out the waste toner bottle... The bottle is a milky white plastic and I believe it is right under the fuser unit. It should slid out toward you. Carefully dump the toner out of the bottle into a plastic garbage bag and re install the bottle and you are done....
Dec 07, 2012 | Ricoh 4506 Copier
I have an ir6570 giving me an error code e0013, e0004 please help
This is an error code dealing with the toner auger motor being bound up. Has the waste toner message been on for along time and the waste toner bottle not being emptied. Sometimes the waste toner counter has been reset several times without the bottle being emptied. This will cause the waste toner to back up in the auger mechanism. Thsi will have to be taken apart ( very tedious job ) and the toner removed from the tube. The auger spring and even some gears may have to be replaced. I've never had to replace the motor on any copier yet. Good Luck.
Sep 07, 2012 | Canon IMAGERUNNER 6570 Copier
Kyocera km-2550 check toner container error
Set toner container. The toner container is not set properly. Set the toner container properly. See page 5-5 of the operation guide.
Replace Waste Toner Box The waste toner box is full. Replace the waste toner box with a new one. See page 5-5 of the operation guide.
Jun 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
I need to reset the waste toner until I receive a replacement for my ImageRunner C5051, is that possible?
This is incorrect. You can manually empty the waste. Make sure you remove the small clear plastic part that is on the side and empty it as well (this is what the sensor looks at to tell the macine it is full)
Sep 23, 2010 | Canon imageRUNNER 5570 Copier
Hi, My Toshiba E-Studio 3511 color copier has a error message of 'dispose of used toner.' Even if I followed the direction, the error message is still there and the copier can't work. Would you help me...
I am assuming you have emptied the old waste toner "box" and not replaced it with a new box. This is not a problem, just clarifying. If this is the case then you have toner packed into the sensor block which is telling the machine that the waste toner box is still full. Just look behind the waste toner box and look for a little set of wires. They lead to a small black sensor. Now look at the waste toner box where it mates up with the sensor. You will see a small square box area on the waste toner bottle. The sensor looks thru this block and if it is blocked with toner it will tell the machine the box is full. Just tap on the little block and make sure there is no toner in it and re-install the waste toner box and the indicator should go away.
Good Luck and Thank You for using Fixya.
Aug 11, 2010 | Toshiba E-Studio 3511 Color Copier
My Canon IR3100N shows error code E000013-0000. I tried restarting, but error message remains.
I believe that may be the waste toner is full.
Remove the panel on the lower left side of the copier pull out the plastic container and empty it .
turn the machine off and the back on.
Apr 08, 2009 | Office Equipment & Supplies
Gestetner DCS424 error message: replace used toner bottle
There are 2 waste toner cartridges, be sure to empty these 2 cartridges . If you remove the waste toner in both cartridge it will automatically clear the error message.
Feb 27, 2009 | Gestetner Copier
DCS424 error message replace used toner bottle
Waste Toner Light won't go off?
The waste toner is usually a bottle near the toner cartridge which collects excess toner powder from the cartridge. It is usually present in more heavy duty laser printers, not all printers have them as a replaceable supply. You would need to refer to your manual for replacement instructions, they vary from printer model. For this machine, the Waste Toner supply number is #420131. In the case of the first poster, my best guess would be there was spillage of toner on the sensors to detect the waste basket overflowing, hence why the error message is constant. This would require cleaning of the sensors, a relatively simple task but for proper access, the machine would need to be partially disassembles for thorough cleaning. It would be best done at a repair centre.
Aug 04, 2006 | Ricoh Aficio CL2000N Laser Printer
Panasonic Workio DP-2310 All-In-One Laser Printer Logo
1,461 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
