FixYa.com
Tags:
IBM 9516 Monitor
IBM 9516-B23 LCD Monitor Blinks once, lamps turn...
By man1 - usenet poster
Have original power pack 20v 3a seems ok,
Changed both fuses on lamp p/supply also soldered ALL connections on
that board, Still just lights for about 1 second and goes off
any suggestions ??!!! Don't have print for Monitor
T.I.A. MikeZOD
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 27, 2006
Not Rated (0)
Powe33
Powe33 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I agree it is too expensive to have serviced,,,,,Oh that's not what
you said! Well for me it would be too expensive. My budget is way too
tight to even consider that, I was hopping to find someone that might
have experience with this model monitor and steer me towards a common
problem.
Thank you for your response, MikeZOD
p.s. I'm still on dialup !
On Sun, 4 Apr 2004 00:46:18 -0500, "Jerry G." <>
wrote:
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Peter1
Peter1 - usenet poster
Rating: 0%, 0 votes
This can be something somewhere that is shorted, and loading down the
supply. These monitors are only serviced at board exchange level only, not
component level. Schematics and replacement parts are not available to non
authorized servicers. You will have to send in the monitor for service.
LCD monitors are expensive to not service, unless the fault is a major one.
Greetings,
Jerry Greenberg GLG Technologies GLG
WebPage #
Electronics #
T.I.A. MikeZOD
Can you Help with these Monitors problems?
Monitors
my viewsonic E50c led flashing
my crt viewsonic encounter some... Answer This...
Monitors
MONITOR FAULT
my digimate does not switch on.... Answer This...
Monitors
3g_technology
i want to know that what is... Answer This...
Monitors
my monitor reads not optimum...
it stays on for 20 seconds then... Answer This...
Monitors
monitor flashing from power...
monitor flashing from power... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
