Question about HP Office Equipment & Supplies
My printer keeps flashing 'check print cartridge' but both of the cartridges are new
    Scholar:
  • 98 Answers
Remove the inkjet cartridges from the printer and clean the circuit with brown dotted objects .clean it with tissue paper.and also clen the circuit of the printer which also looks same like the one in the cartridges where you install the cartridges.
shut off the printer remove the power cord of the printer from its back.wait for 10 minutes.then plug the poer cord wire in the printer.then when prompted on the computer screen reinsert your print cartridges.
it will work.
thanks.
Posted on Oct 13, 2008
Empty cartridge light keeps flashing
These cartridges don't have anything internally to check for new ink. They simply work on a basis of counting pages and page coverage to estimate ink levels. As such it is perfectly normal for your printer to warn of low ink once the cartridge has been refilled.
A low ink warning in itself should not stop your printer from printing though. If it does it is likely that the light is actually indicating a problem recognising the cartridge after refilling. I would recommend cleaning the copper contacts on the front of the cartridge and checking for any messages on the connected PC or laptop for more information.
Oct 16, 2012 | HP DeskJet F380 All-In-One Printer
Help! My machine won't copy or print
check the old cartridge was empty or it was just showing wrong indication.( flashing ).
Aug 29, 2008 | Sharp AL-1540CS All-In-One Laser Printer
It won't print and the light keeps flashing. I lost the instructions!
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Feb 13, 2012 | Lexmark X1240 All-In-One InkJet Printer
Left ligh keep flashing. after installing new ink.
  • Make sure cartridge is placed in properly,
  • Re seat the cartridge and check.
  • It should work
Please rate my response!!
Jan 29, 2010 | HP DeskJet 940c InkJet Printer
Orange cartridge keeps flashing after cartridge
Are you using a factory new HP ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Also take a moment and make sure that all of the protective tape coverings have been removed from the cartridge.
Don
Oct 22, 2009 | HP Deskjet 6980 InkJet Photo Printer
Check Printer Light Keeps Flashing on C3180 PhotoSmart
No, you do not need 3 cartridges or anything like that. Some cartridges have chips. Yours do not. If the light keeps blinking it means that one of the electrical contacts on the cartridge has blown and now the printer doesn't recognize it. Try printing something, you will get a message "problem with color cartridge" or "color cartridge missing". That means that the printer doesn't recognize it. I suggest you buy a new one. Or, if you have an old one, try putting it in and see if the light still blinks.
Jun 02, 2009 | HP Photosmart C3180 All-In-One InkJet...
Check print cartridge flashing
cartridge circuitry damaged, replace with new one
May 26, 2009 | HP PSC 1401 All-In-One Printer
Put in new ink cartridge -- won't print
Try lifting up the cover. If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing. If the problem is not related
to low ink, the light continues to flash after the cover is opened. It might be that the new cartridge is defective. Check the connections and see if there isn't anything keeping it from making contact.
Jan 26, 2009 | HP DeskJet 920c InkJet Printer
Printing Dillema
Flashing resume light also can mean:
1. cartridge is missing or an incorrect print cartridge is installed
2. cartridge is out of ink
3. dirty cartridge contacts
4. paper jammed
Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
Oct 30, 2006 | HP DeskJet 690c plus InkJet Printer
358 people viewed this question
Seeker5211
Seeker5211
