Question about Western Digital Computers & Internet
WD Passport appear as an unknown device
When I connect my Western digital external drive (passport WD1200U017) A pop up appear and say "USB Device Not recognized". I am using the original USB cable that came with the hard drive, The bleu light on the side is on. But the computer can not see the hard drive as it used to and it call it unknown device. When I connect it the drive spin normally with no unusual noise. The device was working fine few hours before. The only different thing I did is that I plug it in a usb hub insdead of straight in the usb port of the computer.
Thankyou for your help
  • Anonymous Dec 31, 2008
    same problem, help
  • Anonymous Jan 09, 2009
    Master:
  • 538 Answers
Try it again, after going to wd dot com, and getting and installing a new set of drivers..
Posted on Oct 13, 2008
Recommend me branded USB drives ?
Honestly, any USB brand will cut it for you. What you want to ensure is that you are purchasing the proper version (1.0, 2.0, or 3.0) for whatever device the key will be associated with. Also make sure you don't buy too little or too much memory. But if you know all this and you just want a reliable brand, I would go with SanDisk.
Aug 04, 2015 | Computers & Internet
When I connect my wd passport, this massage appears "usb not device recognized". although the cable is working with other devices and the wd passport is also working on other computers (not my...
there is NO problem on you external hard drive..the problem is in your own computer USB port..try to uninstall the driver of your usb port.then try it again.
Jun 15, 2011 | Western Digital My Passport Essential 160...
I have a 1tbexternal hdd drive and it stopped working. i tryed to switch the plug and put it on other computer but nothing.....
The Passport has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the W.D. web-site, and use "check warranty status", to see if W.D. will replace the Passport, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
Nov 07, 2010 | Western Digital Passport 160GB External...
I am using the passport essential 500gb on my macbook pro. I dont use time machine...i just backup files manually. I tried to transfer an item to the passport and it told me that it couldnt be moved...
i almost have the same problem, i bought the
Western Digital My Passport Essential 500GBfrom a week ago and i left the drve connected to the laptop and copying data from an old WD drive and after couple of hours i found an error appearing.......then i clecked okay and restarted the laptop and from then my
Western Digital My Passport Essential 500GBdoesn't appear in my computer drive list nor in the device manager.
i just cut my precious data from the other drive.
PLZ help
Mar 29, 2010 | Western Digital My Passport Essential...
Local disk error WD My Passport 250GB
Do you connect & disconnect the drive according to WD's recommendations here? Try another cable. (If yours was wearing out, that might explain why it only connected some times.) Try another usb port. Check the power supply (another receptacle) Unplug other usb devices from the system.
See this article. Good luck!
Aug 18, 2009 | Western Digital WD Passport 250GB Portable...
Western Digital External hard drive not appearing under my computer or anywere else apart from Device manager (USB mass storage device) and safely remove usb hardware, have tried another comp with no luck...
1st dismantle the hdd and change sata to usb adapter. Get cheap on ebay. Certainly, most wd makes hdd motherboard with usb straight away, but still worth to try. BUT, before all check if your pc usb is working, check with mouse or smth. If so, then try change cable. After cable try dismantle that hdd and change mentioned adapter. If none of these work, you then have a lesson, never western digital, seagate only1
Feb 18, 2018 | Western Digital Passport 320GB External...
WD Passport 250GB External cannot be recognized.
Go to BIOS (Press DEL or F2 to enter BIOS). Check if the Power state is in S1. Ensure that USB setting is in Hi-Speed.
Restart the computer and try using the device. this should fix. Let us know the result.
Thanx
Jan 16, 2009 | Western Digital Passport WDXML800UE...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
Computers & Internet Logo
1,578 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
