This VCR powers on, connects to TV ok, displays the Current status on TV ok but does not display the video on TV at all. TV is blank. Tried cleaning the head with soft cloth to no avail. Please help.
Hello!
Sorry to admit, but your VCR's signal processor is down. On screen display is generated by microprocessor, but video signal by different circuitry. Anyway, there is nothing you can do, except surrender to repair shop. Or, worst case scenario: buy another one. Even though I won't recommend to do so. "Modern" VCRs are cheap plastic toys, won't last too long, no replacement parts available, etc. If you have some technician's background, you may open the unit and look for "bloated" capacitors in power supply area or check electrolytic capacitors with "in circuit" capacitor checked, if you have one. If not: try to look for reputable repair shop, what stays in business for a while. there, still might be the people, familiar with VCR problems.
good luck with your project,
thanks,
Alex.
SOURCE: i need operating menual for my VCR
The Instruction Manual for this unit is listed below.
NV-SJ500 VHS Instruction Manual
SOURCE: I have a VCR and while playing an old tape the
The heads are inside the VCR. You can buy from your Local dealer a VHS head cleaning cassette that should solve the problem. Normally I would recommend going inside the VCR to clean it with Servisol Video 40, but in your case I would stick to the tape!
SOURCE: I took out some 2001 9/11 taped back then.
You can purchase a VCR cleaning tape that will do the job. However the best way is to buy a can of Servisol Video 40 (small one will do and it will last a long time) then remove the top cover of the VCR. Spray the VCR heads. Shinny Silver things and any moving parts that the tape touches. If your not certain what to clean, with the cover off insert a tape and press play. Remove the tape and spray small amounts on the surfaces. If you can see a lot of dust you can wipe the heads etc with a cotton bud. A VCR housed in a smokers house will need extra work to get it clean. Once dry you can test a tape. If you see flecks or spots the VCR will need further cleaning.
