Question about AOC LM729 17" LCD Monitor
How to open the back cover of the LCD monitor
At power on normal display will appear but for a few seconds display will disappear. Cable seems to be ok. I tried another but same type of cable but still the same problem. My cpu seems to be fine if use with another CRT monitor. I'd like to resolder possible loose pins or connection inside the lcd monitor but do not know how to open the back cover. Please help if u have any idea on how to uncover the back of the lcd....tnx
    Champion:
  • 293 Answers
Hi..there,
It's seems you got a backling inverter busted. Need to replaced a new one or repaired it. To repaired you need to replaced a bad capacitors with a bulged on top of each caps. Not sure...just replaced all the caps...:) Ok! to open the back cover, there are 2 types to open it. First unscrew the 4 corner screws. If there are some... First type it from the back. After you had removed all the screws. Get a good grip on the bottom R/H side with both hands pulling as hard as you can on the 2 joints. 2nd type from the front bezel. Laid your monitor screen upward and placed a piece of clothes to proctect the screen from smudged. Used 2 hands to lifted up the edged of a bezel...do the same on the other side... After that just removed the screws...and that's how to open the front and back cover... Have a nice day!
Posted on Oct 14, 2008
LG L222WS half bottom screen white
There is a problem with the capacitors in your monitor. This is a normal problem these days with flat screen monitors, I am trying to find out why it is always like tha. This will normally be caused by improper shut down or power fluctuations in your monitor. Capacitrs in your monitor are responsible for holding down the power from the supply, fr the proper display on your monitor. If a capacitor is damaged, or buldged, it no longer holds power long enough for your display, and that is why your screen goes black after a few seconds. This can be solved by opening up your monitor, using a sharp and flat object, opening it starting from the bottom working your way up until the cover is completely out. You will notice finger-like clips that are holding the two covers together. Once you are done, check on the circut board where you connect the power cable.... that is where you are going to find the damaged capacitor(s). You can identify them by noting their bulged head or if there is any liquid coming out of it. Before you replace the, take note of the polarity (+) and (-) so that whenever you replace with the new one it is in the same direction. This will fix up your problem. Note: make sure you let a Computer Technician to do this for you, unless you can do it yourself without damaging the monitor. Thank you
Dec 13, 2011 | LG L222WS-BN Wide-format 22 22 inch LCD...
Monitor cutting out
Follow steps in sequence:
1. Turn Off Monitor by pressing power button on LCD
2. Shut down computer
3. Unplug power cable from LCD, Once power cable is unplugged from LCD, press and hold down the power button on LCD for 15 seconds
4. Unplug the power cable from the back of Desktop Computer and Hold down the power button on desktop computer for 15 seconds
5. Plug the power cables back into the LCD and Desktop Computer
6. Power on computer and then power on LCD, it should work
Oct 06, 2008 | Samtron Computers & Internet
My syncmaster540n lcd power on normally but, every 10 seconds brightness comes and disappeared. power remind normally.please tell me how open back cover and solve problem.
Service manual: http://elektrotanya.com/?q=showresult&megnev=SAMSUNG&megnev2=540N&kategoria=monitor&kat2=all
Iuse thin flat blade screw driver to separate the case starting at the bottom edge and work your way around, watch out for any cable attached to the front bezel.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Feb 25, 2011 | Samsung SyncMaster 540N 15" LCD Monitor
Dell 1503FP works, but won't start up again for a few hours
Hello there.
Seems like electronics pack up but try an old one. disconnect all the data cables from your monitor side(HDMI, DisplayPort, VGA, USB etc.) or computer side if the ones on display are built-in. Leave only the power cable. Unplug the monitor`s power cable. Press the POWER button on the front of the display and keep it pressed for 45 secs. Plug everything back and give it a try.
Good luck.
Jan 18, 2018 | Dell 1503FP 15" LCD Monitor
I have a Dell 1707fp monitor. When I power the monitor on it powers on normally. After a few miniutes, even though the power button is still green the display goes blank. I have tested this on other known...
I just fixed my for less then 1 minute. Here was the problem, when turn on the PC with the monitor connected. The screen appear like normal for about 2 seconds then shut off black but the GREEN power LED stay on, if i press the power off and turn it back on the screen act the same thing.
Here how to fix it, turn off the PC, unplug the monitor power cable then plug it back. The power LED will stay amber. Hold down both brights minus - and plus + same time, turn on the PC, keep hold the - and + buttons press the power button turn on the monitor.
You will see the screen back on, just hold for about 10 more seconds till you see the screen seem to stay on fine then realse them. That's it how i fixed my.....GOOD LUCK
Oct 27, 2009 | Dell E173FP 17" LCD Monitor
Veiwsonic vx912 - ficking on/ off every few seconds
try different video cable or check it, if not power supply.
Apr 21, 2017 | ViewSonic VX912 19" LCD Monitor
Viewsonic VE170 dislay problem
Your LCD inverter is giving up. You can either buy a new inverter but its a bit expensive
http://www.lcdpart.com/Products/cpc1151r0015.html,
or you can have it fixed by some electronic expert.
Nov 19, 2008 | ViewSonic VE170 (Beige) 17" LCD Monitor
Dell 1907FPt picture appears for three seconds, then off, LED power remains
I have the same problem. I talked to a few people and it is believed that the condition has been caused by a power surge.
My monitor is out of warranty, so I intend to open it up to check the fuse(s).
I will post result of that soon.
Aug 21, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell E151FPb 15" LCD with power LED blinking.
The problem may be a loose connection. When I turn on my monitor, the green light blinks and a flickering white screen appears for a brief second every time. There must be a loose connection on the power board which may be causing this. The easiest solution is to tap at the back of the monitor. This will reconnect the loose end and the monitor will work fine until it gets disconnected again. I will open my monitor soon to find the real problem. But it will take some time to find it.
Aug 17, 2008 | Dell E151FPp 15" Flat Panel LCD Monitor
AOC LM729 17" LCD Monitor Logo
337 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
