Question about Nokia 2310 Cellular Phone
Solutions for nokia 2310 backlight
My nokia 2310 phone fell in water and i removed it dried it for sometimes but when i on it the backlight was off i wont the solution to this problem.
  • 64 Answers
Good day,
i suggest that you don't turn on the phone if it is not yet thoroughly dried, this might cause some short circuit on the system. you can use a hair drying in doing this.
however, if you're certain that your phone is already dry, try turning it on and check for errors. in the case that you stated, it seems that your phone has been damaged due to being submerged in water. if the backlight will not turn on again after making sure that your phone is thoroughly dried, have it checked by a competent technician and prevent further damage to your phone.
i hope this will help
Posted on Oct 13, 2008
My nokia e7 fell into water and won't turn on
Wet Cell Phone
Immediately remove the phone from the water, turn off the cell phone, remove the battery and SIM card. To dry out the cell phone put it in a large plastic bag with silica gel drying crystals then put it in a warm sunny place for several days or in front of a warm fan heater for several hours. Reassemble the phone and hope it will work properly again, but if does not work then it is faulty and you need a new cell phone.
Dec 26, 2012 | Nokia E7 (16 GB) Smartphone
My nokia 2310 fallen on water tub for 10 minutes after taking it out from water tub dried and then battery charged now mobile reas sometime and sometimes read sim card reject
Hello, clean every thing with solvent,
Hope this helps.
If you are helped you can rate on the 4 thumbs and post a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 24, 2011 | Nokia 2310 Cellular Phone
My nokia 6500 slide two days now no more displaying any thing and no more switch on again. please send me solution.
did ur handset fell in water or u are in a cold region.... ?! if it is so then switch off ur mobile, remove the battery and dry it in a hot place also dry ur mobile....
Dec 08, 2010 | Nokia 6500 Slide Cellular Phone
My nokia 6210 nav fell into water and i dried it off. now the problem is that i cannot see the backlight even though the phone is working fine. the display is therefore dark, and i'm able to see anything...
Hi, sorry about the water problem with your phone, Since you said the phone is already coming on but the display is still dark, What makes the display still dark is because the water it fell into has damaged an IC inside the phone,The IC makes the phone display.
So when you replace the phone IC that got damaged,the phone will display again,.
It was caused by water.
Take care.
Sep 27, 2010 | Nokia 6210 Navigator Cell Phone
I have a Nokia N90 and it fell in a bucket of water,it submerge for about 6 secs after grabbing it out.I dried it off and imediately run a blow dryer on it,but not getting any display on screen,but it...
The best way to treat a phone after water submersion is to remove the battery immediately and allow it to dry near a radiator or other gentle heat source. Sometimes burying the handset in dry rice will speed up the drying out process.
Be prepared to take it in for repair if the above doesn't work.
If it's insured you should be covered for water damage.
Jul 07, 2009 | Nokia Cell Phones
Says contact service 2310
hi thanks for using fixya!
Well, all I can recommend is to bring your Nokia 2310 to a Nokia Care Center in your area to further check the problem.
Regards!
Jun 07, 2009 | Nokia 2310 Cellular Phone
N70 Fell in water, Only White Screen is Shown
Don't put the battery / power on. Take the phone to the mechanic / nokia service center on urgent basis. They will remove the remnents of the water and salt over the circuit.
If the problem is still not solved, either the power supply or the motherbaord will require a replacement.
Dec 16, 2008 | Nokia N70 Cellular Phone
Plese my nokia 2310 is displaying contact sercive in the screen, plese tell me the solution.
take your mobile to the service centre re-install the software of your mobile or make a flash to your mobile .it takes within 10-5minutes to do that ..this s my exp
May 31, 2008 | Nokia 2310 Cellular Phone
Nokia N70 fell in the toilet
To help drying out the phone, I suggest taking the phone apart. (i.e. battery, sim card, back cover, etc) putting it all into a container of rice, Use a container that you can put a lid on. Let the phone set in the rice for a couple of days. The uncooked rice will draw the moisture out of the equipment. This will dry it out, but whether or not it shorted the unit out is your next step.
Please rate this solution
Nov 01, 2007 | Nokia N70 Cellular Phone
Nokia 2310 Cellular Phone Logo
263 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
Prashant  Sharma
Prashant Sharma
