Question about Zebra 105SL Thermal Label Printer
Lable printer good day, I have a problem with a zebra printer which cannot print at all, I have checked all the possible causes but all my efforts proved futile, i did reistall drivers,reset the printer, pinged it to check if it is on the network, i do see it on the network. All i am getting when trying to print is the green light flashing and nothing happens. Your assistance will be highly appreciated. Thanks and regards, Ronald Modupo IT Network and PC Support
  • Rory Cardenas
    Rory Cardenas May 11, 2010
    Hello, Have to tried disconnecting the network card and doing an internal print test? Rory Cardenas
    Champion:
  • Zebra Expert
  • 285 Answers
Check if the setings from the printer are like PARALEL
check if is the correct driver ZPL, and if the firmware is ZPL.
Posted on Nov 13, 2010
Can't get the Zebra S4m printer to align? How should I trouble shoot this? Sonya
I am assuming you mean misalignment of lable top or start of print moving on label.
check sensor for lable debris.
if OK then perform media calibration:
Enter menu and scroll to ADVANCED
press enter and use password 9999
scroll to MEDIA and RIBBON CALIBRATE
Remove a few labels and remove ribbon
Press right arrow to continue display CALIBRATING PLEASE WAIT.
When complete reload ribbon and labels press right arrow printer will feed approx 39"
printer should now print OK.
Aug 08, 2011 | Zebra S4M Thermal Label Printer
My zebra id card printer p120i does not print very sharp
zebra p120i TROUBLESHOOTING LINK
Printing shows blurry printed image.
Possible Cause:
•Ribbon cartridge may not be correctly positioned.
Solution:
•Check that the ribbon is properly rolled onto the ribbon cores of the cartridge, with no wrinkles.
•Replace ribbon cartridge, making sure it locks in place, and print again.
Possible Cause:
•Ribbon may not be synchronized on the correct color panel position.
Solution:
•Open lid, then close lid to synchronize ribbon.
Possible Cause:
•Cards may not meet specifications.
Solution:
•Use a different supply of cards.
Possible Cause:
•Dust or embedded contamination inside the printer and/or dirty Cleaning Roller.
Solution:
•Clean the Print Head.
•Replace Cleaning Roller
Jan 30, 2011 | Zebra P120i Thermal Card Printer
Zebra printer feeds out to omuch of the lable to start so printing too low
Press the cancel button 5 seconds while power on. This will give you a config. printout. Check the top position, and tear off position for settings of 0. If it is anything else change it and save .
Jun 16, 2010 | Zebra 105SL Thermal Label Printer
Zebra LP 2844 Prints 30 pages of junk instead of a Dazzle mailing
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash2.gif (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time.
You've just set the printer back to factory default.
Jul 23, 2009 | Zebra LP 2844 Thermal Printer
I have a Zebra 160s lable printer & i want its installation S\W
You can use software such as Label Matrix, BarTender, EasyLabel or ZebraDesigner (free on zebra.com).
Jan 17, 2009 | Zebra Z4Mplus Label Printer
Label problems on a Zebra 220XiIIIplus
Check the parameters of length and width of printing in the printer, if you are right, then the program or its driver has a print area smaller.
Sep 15, 2008 | Zebra Printer 140-751-00000
Zebra printer not printing the expected quantity of output.
how are you connect (usb?) change to LPT port ou network. Possible the job go stuck on the quere.
what printer model? whath memory the printer have?
Thanks.
Aug 15, 2008 | HP DeskJet 930c InkJet Printer
Zebra 4m
If you are in rewind mode and don't rewind the printer will pause while the rewind spool tries to catch up.
Jan 10, 2008 | Zebra Z4Mplus Label Printer
Zebra S4M Thermal Lable Printer Not Printing Correctly.
Is the Media guide st corectly?
This link is for a datamax but all label printers are stuctured the same way.
check
http://www.posguys.com/download/88230401_a.pdf
Oct 26, 2007 | Zebra S4M Thermal Label Printer
Zebra 105SL Thermal Label Printer Logo
135 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
